XML——XML操作
AI浩 发表于 2021/12/22 23:59:48 2021/12/22
【摘要】 操作XML文件需要引用命名空间:System.Xml; 向Xml文件中添加信息 添加Student.xml文件,文件信息如下: <?xml version="1.0" encoding="utf-8"?> <Students>   <Student class="一班"> &nbs...
  1. 向Xml文件中添加信息
<Students>
    <Name>张三</Name>
    <Gender>男</Gender>
    <Age>19</Age>
  </Student>
  <Student class="二班">
    <Name>李四</Name>
    <Gedner>女</Gedner>
    <Age>20</Age>
  </Student>
    <Name>had</Name>
    <Gender>女</Gender>
    <Age>16</Age>
  </Student>
</Students>
代码:
  XmlDocument doc = new XmlDocument();
            //修改.exe文件夹下的Student.xml,需要单机程序中的Student.xml文件将其“复制到输出目录”属性,修改为“始终复制”
            //string exePath = Application.StartupPath+"\\Student.xml";
            //doc.Load(exePath);
            //将程序目录下的Student.Xml中添加学生信息。
            String exePath = Application.StartupPath;
            int idx = exePath.LastIndexOf("bin");
            exePath = exePath.Substring(0, idx) + "Student.xml";
            doc.Load(exePath);
            XmlNode node = doc.CreateNode(XmlNodeType.Element, "Student", "");
            XmlAttribute attr = doc.CreateAttribute("class");
            attr.Value = "一班";
            node.Attributes.Append(attr);
            XmlNode name = doc.CreateNode(XmlNodeType.Element, "Name","");
            name.InnerText = "had";
            XmlNode gender = doc.CreateNode(XmlNodeType.Element, "Gender", "");
            gender.InnerText = "女";
            XmlNode age = doc.CreateNode(XmlNodeType.Element, "Age", "");
            age.InnerText = "16";
            node.AppendChild(name);
            node.AppendChild(gender);
            node.AppendChild(age);
            doc["Students"].AppendChild(node);
            doc.Save(exePath);
  1. 删除Xml文件中的数据
            doc.Load(exePath);
            XmlNodeList list = doc["Students"].ChildNodes;
            foreach (XmlNode node in list)
                foreach (XmlNode nd in node.ChildNodes)
                    if (nd.InnerText == "had")
                        nd.ParentNode.ParentNode.RemoveChild(nd.ParentNode);
                        doc.Save(exePath);
                        return;
  1. 修改xml中的数据:
            doc.Load(exePath);
            for (int i = 0; i < list.Count; i++)
                XmlNode node = list[i];
                if (node["Name"].InnerText == "李四")
                    node["Gender"].InnerText = "男";
                    if (nd.InnerText == "张三")
                        nd.ParentNode["Gender"].InnerText = "女";
            doc.Save(exePath);
  1. 读取xml文件的所有数据
            doc.Load(exePath);
                String name = node["Name"].InnerText;
                string gender = node["Gender"].InnerText;
                string age = node["Age"].InnerText;
                listBox1.Items.Add(name + "," + age + "," + gender);
  1. 创建Xml文件,并向里面添加数据
  private void button1_Click(object sender, EventArgs e)
            CreateXmlFile();
        public void CreateXmlFile()
            exePath = exePath.Substring(0, idx) + "aa.xml";
            XmlDocument xmlDoc = new XmlDocument();
            //创建类型声明节点
            XmlNode node = xmlDoc.CreateXmlDeclaration("1.0", "utf-8", "");
            xmlDoc.AppendChild(node);
            //创建根节点
            XmlNode root = xmlDoc.CreateElement("User");
            xmlDoc.AppendChild(root);
            CreateNode(xmlDoc, root, "name", "xuwei");
            CreateNode(xmlDoc, root, "sex", "male");
            CreateNode(xmlDoc, root, "age", "25");
            xmlDoc.Save(exePath);
        /// <summary>
        /// 创建节点
        /// </summary>
        /// <param name="xmldoc"></param>  xml文档
        /// <param name="parentnode"></param>父节点
        /// <param name="name"></param>  节点名
        /// <param name="value"></param>  节点值
        public void CreateNode(XmlDocument xmlDoc, XmlNode parentNode, string name, string value)
            XmlNode node = xmlDoc.CreateNode(XmlNodeType.Element, name, null);
            node.InnerText = value;
            parentNode.AppendChild(node);
文章来源: wanghao.blog.csdn.net,作者:AI浩,版权归原作者所有,如需转载,请联系作者。
原文链接:wanghao.blog.csdn.net/article/details/105593826
