XML——读取文件夹下所有的Xml文件,并修改属性,保留上次打开文件的位置
AI浩 发表于 2021/12/23 01:55:20 2021/12/23
【摘要】 功能:读取文件夹下所有的Xml文件,并修改属性,保留上次打开文件的位置 using System; using System.Windows.Forms; using System.IO;using System.Xml; using Microsoft.Win32; namespace WindowsFormsAppli...
using System;
namespace WindowsFormsApplication1
    public partial class Form1 : Form
        public Form1()
        { InitializeComponent();  }
        private void button1_Click(object sender, EventArgs e)
            FolderBrowserDialog fb = new FolderBrowserDialog();
            RegistryKey myReg1, myReg2; myReg1 = Registry.CurrentUser;
            try
                myReg2 = myReg1.OpenSubKey("Software\\MySoft");
                fb.SelectedPath = myReg2.GetValue("1").ToString();
            catch { }
            if (fb.ShowDialog() == DialogResult.OK)
            { SearchDir(fb.SelectedPath); }
            myReg2 = myReg1.CreateSubKey("Software\\MySoft");
            myReg2.SetValue("1", fb.SelectedPath);
        private void SearchDir(string fileName)
            DirectoryInfo dirInfo = new DirectoryInfo(fileName);
            if (dirInfo.Exists == false){ return; }
            FileSystemInfo[] files = dirInfo.GetFileSystemInfos();
            foreach (FileSystemInfo file in files)
                if (file.Name == ".svn") { continue; }
                FileInfo fileInfo = file as FileInfo;
                if (fileInfo == null){ SearchDir(file.FullName); }//为null说明是文件夹
                else  { Update(file.FullName); }
        private void Update(string fileName)
            XmlDocument doc = new XmlDocument();
            doc.Load(fileName);
            XmlNodeList nodeP = doc.SelectNodes("MeasureItem/Params/Param");
            if (nodeP == null || nodeP.Count == 0)
            { nodeP = doc.SelectNodes("ScriptInfo/Param/Param"); }
            foreach (XmlNode node in nodeP)
                XmlElement xleP = (XmlElement)node;
                if (xleP.ChildNodes.Count > 0)
                    XmlNodeList nodeList = node.ChildNodes;
                    for(int i=0;i<nodeList.Count;i++)
                        if (nodeList[i] is XmlElement)
                            XmlElement eleNode = (XmlElement)nodeList[i];
                            if (eleNode.Name == "Rows" || eleNode.Name == "DefaultRows")
                                XmlNodeList nodeChildren = eleNode.ChildNodes;
                                for (int j = 0; j < nodeChildren.Count; j++)
                                    if (nodeChildren[j] is XmlElement)
                                        XmlElement eleChild = (XmlElement)nodeChildren[j];
                                        eleChild.SetAttribute("id", (j + 1).ToString());
                                        eleChild.SetAttribute("order", (j + 1).ToString());
                doc.Save(fileName);
文章来源: wanghao.blog.csdn.net,作者:AI浩,版权归原作者所有,如需转载,请联系作者。
原文链接:wanghao.blog.csdn.net/article/details/105593838
