.to(device)和.cuda()设置GPU的区别
AI浩 发表于 2021/12/23 01:28:28 2021/12/23
【摘要】 .to(device) 可以指定CPU 或者GPU 详见代码: device = torch.device("cuda:0" if torch.cuda.is_available() else "cp...
详见代码:
device = torch.device("cuda:0" if torch.cuda.is_available() else "cpu") # 单GPU或者CPU
model.to(device)
#如果是多GPU
if torch.cuda.device_count() > 1:
  model = nn.DataParallel(model,device_ids=[0,1,2])
model.to(device)
.cuda() 只能指定GPU
#指定某个GPU
os.environ['CUDA_VISIBLE_DEVICE']='1'
model.cuda()
#如果是多GPU
os.environment['CUDA_VISIBLE_DEVICES'] = '0,1,2,3'
device_ids = [0,1,2,3]
net  = torch.nn.Dataparallel(net, device_ids =device_ids)
net  = torch.nn.Dataparallel(net) # 默认使用所有的device_ids
net = net.cuda()
文章来源: wanghao.blog.csdn.net,作者:AI浩,版权归原作者所有,如需转载,请联系作者。
原文链接:wanghao.blog.csdn.net/article/details/118602874
