C#三层架构第五课之DBUtil层设计
人工智能-张晨光 发表于 2021/12/23 00:00:00 2021/12/23
【摘要】 DBUtil层设计一般用来设计通用的数据库连接类或者其他字符编码处理、IO处理等通用类的设计。 参考代码如下: using System;using System.Collections.Generic;using System.Linq;using System.Text;using System.Threading.Tasks;u...
参考代码如下:
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using System.Text;
  5. using System.Threading.Tasks;
  6. using System.Data;
  7. using System.Data.SqlClient;
  8. namespace DbUtil
  9. {
  10. public class DBHelper
  11. {
  12. //增删改:可以封装到一个方法;
  13. /// <summary>
  14. ///
  15. /// </summary>
  16. /// <param name="sql">sql语句,insert update delte</param>
  17. /// <param name="parameters">list:集合;动态添加数据;长度不固定</param>
  18. /// <returns></returns>
  19. public static bool update(String sql,List<SqlParameter>parameters) {
  20. String url = "server=.;database=MyDb;uid=sa;pwd=123456";
  21. //1.链接对象;
  22. SqlConnection conn = new SqlConnection(url);
  23. conn.Open();
  24. //2.SqlCommand
  25. SqlCommand cmd = conn.CreateCommand();
  26. cmd.CommandText = sql;
  27. if (parameters != null)
  28. {
  29. //继续添加参数;
  30. for (int i = 0; i < parameters.Count; i++)
  31. {
  32. cmd.Parameters.Add(parameters[i]);
  33. }
  34. }
  35. int result=cmd.ExecuteNonQuery();
  36. if (result > 0)
  37. return true;
  38. return false;
  39. }
  40. public static DataTable query(String sql, List<SqlParameter> parameters)
  41. {
  42. String url = "server=.;database=MyDb;uid=sa;pwd=123456";
  43. //1.链接对象;
  44. SqlConnection conn = new SqlConnection(url);
  45. conn.Open();
  46. //2.SqlCommand
  47. SqlCommand cmd = conn.CreateCommand();
  48. cmd.CommandText = sql;
  49. if (parameters != null)
  50. {
  51. //继续添加参数;
  52. for (int i = 0; i < parameters.Count; i++)
  53. {
  54. cmd.Parameters.Add(parameters[i]);
  55. }
  56. }
  57. SqlDataAdapter da = new SqlDataAdapter(cmd);
  58. DataTable dt=new DataTable();
  59. da.Fill(dt);
  60. return dt;
  61. }
  62. }
  63. }
原文链接:aaaedu.blog.csdn.net/article/details/109038077
