分离部署lnmp架构
rivers 发表于 2021/12/23 00:00:51 2021/12/23
【摘要】 文章目录 实验部署环境nginx 安装nginx安装后配置mysql 安装PHP网络源安装编译安装php安装后配置 实验部署环境 服务器类型IP地址应用操作系统nginx192.168.1...
实验部署环境
服务器类型 IP地址 应用 操作系统
nginx 192.168.170.16 nginx centos7/redhat7
mysql 192.168.170.14 mysql centos7/redhat7
php 192.168.170.13 php centos7/redhat7
  • 注意:本次实验,三台主机都关闭防护墙,selinux为disable状态
  • 关闭防火墙和selinux
    systemctl stop firewalld
    systemctl disable firewalld
    getenforce
    Disabled
nginx 安装
  • 创建系统用户、组nginx
[root@localhost ~]#groupadd -r nginx
[root@localhost ~]# useradd -r -M -s /sbin/nologin  -g nginx  nginx
  • 安装依赖环境
[root@localhost ~]# yum -y install pcre-devel openssl openssl-devel gcc gcc-c++
安装过程略....
[root@localhost ~]# yum -y groups mark install 'Development Tools'  #如果你安装虚拟机时,安装过开发工具,此步骤无需操作
Loaded plugins: product-id, search-disabled-repos, subscription-manager
This system is not registered with an entitlement server. You can use subscription-manager to register.
There is no installed groups file.
Maybe run: yum groups mark convert (see man yum)
Marked install: Development Tools
  • 创建日志存放目录
[root@localhost ~]# mkdir -p /var/log/nginx
[root@localhost ~]# chown -R nginx.nginx /var/log/nginx
  • 下载nginx
[root@localhost ~]# cd /usr/src/
[root@localhost src]# wget http://nginx.org/download/nginx-1.12.0.tar.gz
  • 编译安装
[root@localhost src]# ls
debug  kernels  nginx-1.12.0.tar.gz
[root@localhost src]# tar xf nginx-1.12.0.tar.gz
[root@localhost src]# cd nginx-1.12.0
[root@localhost nginx-1.12.0]# ./configure \
--prefix=/usr/local/nginx \
--user=nginx \
--group=nginx \
--with-debug \
--with-http_ssl_module \
--with-http_realip_module \
--with-http_gunzip_module \
--with-http_gzip_static_module \
--with-http_stub_status_module \
--http-log-path=/var/log/nginx/access.log \
--error-log-path=/var/log/nginx/error.log
[root@localhost nginx-1.12.0]# make -j $(grep 'processor' /proc/cpuinfo | wc -l) && make install
安装过程略....
nginx安装后配置
  • 配置环境变量
[root@localhost ~]# echo 'export PATH=/usr/local/nginx/sbin:$PATH' > /etc/profile.d/nginx.sh
[root@localhost ~]# . /etc/profile.d/nginx.sh
  • 服务控制方式,使用nginx命令
    -t  //检查配置文件语法
    -v  //输出nginx的版本
    -c  //指定配置文件的路径
    -s  //发送服务控制信号,可选值有{stop|quit|reopen|reload}
  • 启动nginx
[root@localhost ~]# nginx
[root@localhost ~]# ss -antl
State      Recv-Q Send-Q   Local Address:Port                  Peer Address:Port
LISTEN     0      128                  *:80                               *:*
LISTEN     0      128                  *:22                               *:*
LISTEN     0      100          127.0.0.1:25                               *:*
LISTEN     0      128                 :::22                              :::*
LISTEN     0      100                ::1:25                              :::*
mysql 安装
  • 安装依赖包
[root@localhost ~]# yum -y install ncurses-devel openssl-devel openssl cmake mariadb-devel
  • 安装编译工具
[root@localhost ~]# yum -y install gcc gcc-c++
  • 创建用户和组
[root@localhost ~]# groupadd -r -g 306 mysql
[root@localhost ~]# useradd -M -s /sbin/nologin -g 306 -u 306 mysql
[root@localhost ~]#
  • 下载安装包
[root@localhost ~]#cd /usr/src/
[root@localhost src]# wget https://downloads.mysql.com/archives/get/file/mysql-5.7.22-linux-glibc2.12-x86_64.tar.gz
  • 解压软件至/usr/local/
debug  kernels  mysql-5.7.22-linux-glibc2.12-x86_64.tar.gz
[root@localhost src]# tar xf mysql-5.7.22-linux-glibc2.12-x86_64.tar.gz -C /usr/local/
  • 创建软连接
[root@localhost ~]# cd /usr/local/
[root@localhost local]# ln -sv mysql-5.7.22-linux-glibc2.12-x86_64/ mysql
‘mysql’ -> ‘mysql-5.7.22-linux-glibc2.12-x86_64/’
  • 修改目录/usr/local/mysql的属主属组
[root@localhost ~]# chown -R mysql.mysql  /usr/local/mysql
  • 添加环境变量
[root@localhost ~]# ls /usr/local/mysql
bin  COPYING  docs  include  lib  man  README  share  support-files
[root@localhost ~]# echo 'export PATH=/usr/local/mysql/bin:$PATH' > /etc/profile.d/mysql.sh
[root@localhost ~]# . /etc/profile.d/mysql.sh
[root@localhost ~]#echo $PATH
/usr/local/mysql/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
  • 建立数据存放目录
[root@localhost ~]# mkdir /opt/data
[root@localhost ~]# chown -R mysql.mysql /opt/data/
[root@localhost ~]#
  • 初始化数据库
[root@localhost ~]# /usr/local/mysql/bin/mysqld --initialize --user=mysql --datadir=/opt/data
2019-08-20T04:36:47.124341Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2019-08-20T04:36:47.512965Z 0 [Warning] InnoDB: New log files created, LSN=45790
2019-08-20T04:36:47.568170Z 0 [Warning] InnoDB: Creating foreign key constraint system tables.
2019-08-20T04:36:47.710963Z 0 [Warning] No existing UUID has been found, so we assume that this is the first time that this server has been started. Generating a new UUID: 1ee4d515-c304-11e9-bd54-000c292184e7.
2019-08-20T04:36:47.711625Z 0 [Warning] Gtid table is not ready to be used. Table 'mysql.gtid_executed' cannot be opened.
2019-08-20T04:36:47.712295Z 1 [Note] A temporary password is generated for root@localhost: *!J3wNVfewsf    #复制这串密码,数据库初始化只能一次,用于第一次登录
[root@localhost ~]#  #这个临时密码是随机的
  • 生成配置文件
[root@localhost ~]# cat > /etc/my.cnf <<EOF
> [mysqld]
> basedir = /usr/local/mysql
> datadir = /opt/data
> socket = /tmp/mysql.sock
> port = 3306
> pid-file = /opt/data/mysql.pid
> user = mysql
> skip-name-resolve
> EOF
[root@localhost ~]# cat /etc/my.cnf
[mysqld]
datadir = /opt/data
port = 3306
user = mysql
skip-name-resolve
-配置服务启动脚本
[root@localhost ~]# cp -a /usr/local/mysql/support-files/mysql.server /etc/init.d/mysqld
[root@localhost ~]# sed -ri 's#^(basedir=).*#\1/usr/local/mysql#g' /etc/init.d/mysqld
[root@localhost ~]# sed -ri 's#^(datadir=).*#\1/opt/data#g' /etc/init.d/mysqld
  • 启动脚本
[root@localhost ~]# /etc/init.d/mysqld start
Starting MySQL.Logging to '/opt/data/localhost.localdomain.err'.
 SUCCESS!
[root@localhost ~]#
  • 使用临时密码登录
  • 修改数据库密码
[root@localhost ~]# /usr/local/mysql/bin/mysql -uroot -p
Enter password:
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 2
Server version: 5.7.22
Copyright (c) 2000, 2018, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> set password = password('wyh123456');
Query OK, 0 rows affected, 1 warning (0.00 sec)
mysql>
PHP网络源安装
  • 配置网络源,epel源,php源
[root@localhost ~]# cd /etc/yum.repos.d/
[root@localhost yum.repos.d]# wget http://mirrors.163.com/.help/CentOS7-Base-163.repo
[root@localhost ~]#sed -i 's/\$releasever/7/g' /etc/yum.repos.d/CentOS7-Base-163.repo
[root@localhost ~]# sed -i 's/^enabled=.*/enabled=1/g' /etc/yum.repos.d/CentOS7-Base-163.repo
[root@localhost ~]# yum -y install epel-release
[root@localhost ~]#wget https://mirror.webtatic.com/yum/el7/webtatic-release.rpm
[root@localhost ~]#rpm -Uvh webtatic-release.rpm
  • 安装依赖包
[root@localhost ~]# yum -y install libxml2 libxml2-devel openssl openssl-devel bzip2 bzip2-devel libcurl libcurl-devel libicu-devel libjpeg libjpeg-devel libpng libpng-devel openldap-devel  libpcre-devel freetype freetype-devel gmp gmp-devel libmcrypt libmcrypt-devel readline readline-devel libxslt libxslt-devel mhash mhash-devel php72w-mysqlnd
  • 安装编译工具
[root@localhost php-7.2.8]# yum -y install gcc gcc-c++
  • 下载php
[root@localhost ~]#wget http://cn.php.net/distributions/php-7.2.8.tar.xz
编译安装php
[root@localhost src]# tar xf php-7.2.8.tar.xz
[root@localhost src]# cd php-7.2.8
[root@localhost php-7.2.8]# ./configure --prefix=/usr/local/php7  \
--with-config-file-path=/etc \
--enable-fpm \
--enable-inline-optimization \
--disable-debug \
--disable-rpath \
--enable-shared \
--enable-soap \
--with-openssl \
--enable-bcmath \
--with-iconv \
--with-bz2 \
--enable-calendar \
--with-curl \
--enable-exif  \
--enable-ftp \
--with-gd \
--with-jpeg-dir \
--with-png-dir \
--with-zlib-dir \
--with-freetype-dir \
--with-gettext \
--enable-json \
--enable-mbstring \
--enable-pdo \
--with-mysqli=mysqlnd \
--with-pdo-mysql=mysqlnd \
--with-readline \
--enable-shmop \
--enable-simplexml \
--enable-sockets \
--enable-zip \
--enable-mysqlnd-compression-support \
--with-pear \
--enable-pcntl \
--enable-posix
[root@localhost php-7.2.8]# make && make install
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
安装后配置
[root@localhost ~]# echo 'export PATH=/usr/local/php7/bin:$PATH' > /etc/profile.d/php7.sh
[[root@localhost ~]#source /etc/profile.d/php7.sh
[root@localhost php-7.2.8]# which php
/usr/local/php7/bin/php
[root@localhost php-7.2.8]# php -v
PHP 7.2.8 (cli) (built: Aug 16 2018 13:27:30) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies
  • 配置php-fpm(必须在此目录下操作)
[root@localhost php-7.2.8]# cp php.ini-production /etc/php.ini
[root@localhost php-7.2.8]# cp sapi/fpm/init.d.php-fpm /etc/init.d/php-fpm
[root@localhost php-7.2.8]# chmod +x /etc/rc.d/init.d/php-fpm
[root@2localhost php-7.2.8]# cp /usr/local/php7/etc/php-fpm.conf.default /usr/local/php7/etc/php-fpm.conf
[root@localhost php-7.2.8]# cp /usr/local/php7/etc/php-fpm.d/www.conf.default /usr/local/php7/etc/php-fpm.d/www.conf
  • 编辑php-fpm的配置文件(/usr/local/php7/etc/php-fpm.conf)最后添加以下几行内容:
[root@ php-7.2.8]# vim /usr/local/php7/etc/php-fpm.conf
pm.max_children = 50        # 最多同时提供50个进程提供50个并发服务
pm.start_servers = 5        # 启动时启动5个进程
pm.min_spare_servers = 2    # 最小空闲进程数
pm.max_spare_servers = 8    # 最大空闲进程数
[root@localhost ~]# tail /usr/local/php7/etc/php-fpm.conf
; file.
; Relative path can also be used. They will be prefixed by:
;  - the global prefix if it's been set (-p argument)
;  - /usr/local/php7 otherwise
include=/usr/local/php7/etc/php-fpm.d/*.conf
  • 启动php-fpm
[root@localhost ~]# service php-fpm start
Starting php-fpm  done
  • 查看9000端口是否启动
LISTEN      0      128                               *:111                                           *:*
LISTEN      0      5                     192.168.122.1:53                                            *:*
LISTEN      0      128                       127.0.0.1:631                                           *:*
LISTEN      0      128                       127.0.0.1:9000                                          *:*
LISTEN      0      128                              :::111                                          :::*
LISTEN      0      128                             ::1:631                                          :::
文章来源: rivers.blog.csdn.net,作者:宝山的博客,版权归原作者所有,如需转载,请联系作者。
原文链接:rivers.blog.csdn.net/article/details/100111138
