Pytorch 实现NonLocalBlock
AI浩 发表于 2021/12/22 23:19:05 2021/12/22
【摘要】 import torch import torch.nn as nn import torchvision class NonLocalBlock(nn.Module): def __init...
import torch
import torchvision
    def __init__(self, channel):
        super(NonLocalBlock, self).__init__()
        self.inter_channel = channel // 2
        self.conv_phi = nn.Conv2d(in_channels=channel, out_channels=self.inter_channel, kernel_size=1, stride=1,padding=0, bias=False)
        self.conv_theta = nn.Conv2d(in_channels=channel, out_channels=self.inter_channel, kernel_size=1, stride=1, padding=0, bias=False)
        self.conv_g = nn.Conv2d(in_channels=channel, out_channels=self.inter_channel, kernel_size=1, stride=1, padding=0, bias=False)
        self.softmax = nn.Softmax(dim=1)
        self.conv_mask = nn.Conv2d(in_channels=self.inter_channel, out_channels=channel, kernel_size=1, stride=1, padding=0, bias=False)
    def forward(self, x):
        # [N, C, H , W]
        b, c, h, w = x.size()
        # [N, C/2, H * W]
        x_phi = self.conv_phi(x).view(b, c, -1)
        # [N, H * W, C/2]
        x_theta = self.conv_theta(x).view(b, c, -1).permute(0, 2, 1).contiguous()
        x_g = self.conv_g(x).view(b, c, -1).permute(0, 2, 1).contiguous()
        # [N, H * W, H * W]
        mul_theta_phi = torch.matmul(x_theta, x_phi)
        mul_theta_phi = self.softmax(mul_theta_phi)
        # [N, H * W, C/2]
        mul_theta_phi_g = torch.matmul(mul_theta_phi, x_g)
        # [N, C/2, H, W]
        mul_theta_phi_g = mul_theta_phi_g.permute(0,2,1).contiguous().view(b,self.inter_channel, h, w)
        # [N, C, H , W]
        mask = self.conv_mask(mul_theta_phi_g)
        out = mask + x
        return out
if __name__=='__main__':
    model = NonLocalBlock(channel=16)
    print(model)
    input = torch.randn(1, 16, 64, 64)
    out = model(input)
    print(out.shape)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
文章来源: wanghao.blog.csdn.net,作者:AI浩,版权归原作者所有,如需转载,请联系作者。
原文链接:wanghao.blog.csdn.net/article/details/121567739
评论(0
