mysql源码安装详解
rivers 发表于 2021/12/22 22:35:07 2021/12/22
【摘要】 文章目录 MYSQL简介实验环境安装步骤总结mysql常用配置文件参数常见mysql 启动报错总结 MYSQL简介 查看mysql简介 查看cmake编译mysql 实验环境 数...
MYSQL简介
查看mysql简介
查看cmake编译mysql
实验环境
数据库 IP 系统版本 mysql版本
MYSQL 192.168.10.11 CentOS 7.4 5.7.20
安装步骤
  • 下载安装包
    [root@localhost ~]# wget https://downloads.mysql.com/archives/get/p/23/file/mysql-5.7.20-linux-glibc2.12-x86_64.tar.gz
    --2021-04-18 20:58:11--  https://downloads.mysql.com/archives/get/p/23/file/mysql-5.7.20-linux-glibc2.12-x86_64.tar.gz
    Resolving downloads.mysql.com (downloads.mysql.com)... 137.254.60.14
    Connecting to downloads.mysql.com (downloads.mysql.com)|137.254.60.14|:443... connected.
    HTTP request sent, awaiting response... 302 Found
    Location: https://cdn.mysql.com/archives/mysql-5.7/mysql-5.7.20-linux-glibc2.12-x86_64.tar.gz [following]
    --2021-04-18 20:58:12--  https://cdn.mysql.com/archives/mysql-5.7/mysql-5.7.20-linux-glibc2.12-x86_64.tar.gz
    Resolving cdn.mysql.com (cdn.mysql.com)... 184.86.92.235
    Connecting to cdn.mysql.com (cdn.mysql.com)|184.86.92.235|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 641127384 (611M) [application/x-tar-gz]
    Saving to: ‘mysql-5.7.20-linux-glibc2.12-x86_64.tar.gz’
    100%[===================================================================>] 641,127,384 10.5MB/s   in 61s
    2021-04-18 20:59:13 (10.1 MB/s) - ‘mysql-5.7.20-linux-glibc2.12-x86_64.tar.gz’ saved [641127384/641127384]
    [root@localhost ~]# ls
    anaconda-ks.cfg  back_yum  he.txt  mysql-5.7.20-linux-glibc2.12-x86_64.tar.gz
  • 解压 安装包
    [root@localhost ~]# mv mysql-5.7.20-linux-glibc2.12-x86_64.tar.gz /usr/local/
    [root@localhost local]# tar xf mysql-5.7.20-linux-glibc2.12-x86_64.tar.gz
    [root@localhost local]# ln -s mysql-5.7.20-linux-glibc2.12-x86_64/  mysql
    [root@localhost local]# ll mysql
  • 创建用户
    [root@localhost local]# useradd -M -s /sbin/nologin mysql
  • 修改目录/usr/local/mysql的属主属组
    [root@localhost local]# chown -R mysql:mysql mysql
    lrwxrwxrwx 1 mysql mysql 36 Apr 18 21:22 mysql -> mysql-5.7.20-linux-glibc2.12-x86_64/
  • 设置环境变量
    [root@localhost bin]# echo 'export PATH=/usr/local/mysql/bin:$PATH' > /etc/profile.d/mysql.sh
    [root@localhost bin]# source /etc/profile.d/mysql.sh
    [root@localhost bin]# echo $PATH
    /usr/local/mysql/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
  • 建立数据存放目录,并修改权限
    [root@localhost bin]# mkdir -p /data/mysql
    [root@localhost bin]# chown -R mysql.mysql /data/mysql/
  • 初始化数据库
    [root@localhost bin]# /usr/local/mysql/bin/mysqld --initialize --user=mysql --datadir=/data/mysql/
    2021-04-18T13:31:12.749412Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
    2021-04-18T13:31:13.310688Z 0 [Warning] InnoDB: New log files created, LSN=45790
    2021-04-18T13:31:13.376643Z 0 [Warning] InnoDB: Creating foreign key constraint system tables.
    2021-04-18T13:31:13.437436Z 0 [Warning] No existing UUID has been found, so we assume that this is the first time that this server has been started. Generating a new UUID: 584ca535-a04a-11eb-bee7-000c29e5f134.
    2021-04-18T13:31:13.438276Z 0 [Warning] Gtid table is not ready to be used. Table 'mysql.gtid_executed' cannot be opened.
    2021-04-18T13:31:13.439087Z 1 [Note] A temporary password is generated for root@localhost: !4wowa:8MipQ
    请注意,这个命令的最后会生成一个临时密码,此处密码是!4wowa:8MipQ。每个人初始化密码不一样,后面初次登陆用
  • 创建mysql配置文件
    [root@localhost bin]# cat > /etc/my.cnf <<EOF
    > [mysqld]
    > basedir=/usr/local/mysql
    > socket=/tmp/mysql.sock
    > port=3306
    > pid-file=/data/mysql/mysql.pid
    > user=mysql
    > skip-name-resolve
    > EOF
    [root@localhost bin]# cat /etc/my.cnf
    [mysqld]
    port=3306
    user=mysql
    skip-name-resolve
  • 设置服务启动脚本
    [root@localhost bin]# cd ../support-files/
    [root@localhost support-files]# \cp -af mysql.server /etc/init.d/mysqld
    root@localhost support-files]# sed -ri 's#^(basedir=).*#\1/usr/local/mysql#g' /etc/init.d/mysqld
    [root@localhost support-files]# sed -ri 's#^(datadir=).*#\1/data/mysql/#g' /etc/init.d/mysqld
  • 启动mysql
    [root@localhost support-files]# /etc/init.d/mysqld start
    Starting MySQL. SUCCESS!
  • 测试:
    [root@localhost ~]# ss -lant|grep 3306
    LISTEN     0      80          :::3306                    :::*
    [root@localhost ~]# mysql -uroot -p
    Enter password:
    mysql> quit
    Bye
    [root@localhost ~]#
mysql常用配置文件参数
参数 说明
port = 3306 设置监听端口
socket = /tmp/mysql.sock 指定套接字文件位置
basedir = /usr/local/mysql 指定MySQL的安装路径
datadir = /data/mysql 指定MySQL的数据存放路径
pid-file = /data/mysql/mysql.pid 指定进程ID文件存放路径
user = mysql 指定MySQL以什么用户的身份提供服务
skip-name-resolve 禁止MySQL对外部连接进行DNS解析 使用这一选项可以消除MySQL进行DNS解析的时间。 若开启该选项,则所有远程主机连接授权都要使用IP地址方 式否则MySQL将无法正常处理连接请求
常见mysql 启动报错总结
  • 报错1
    Starting MySQL... ERROR! The server quit without updating PID file (/data/mysql/mysql.pid).
    关于网上对这个错误的总结,很多人都说权限问题,其实不管我们怎么给权限,好像都报错,很多时候都是因为配置文件有问题,才导致的,如果出现此错误,建议检查配置文件
  • 报错2
    Systemctl restart mariadb.service
    Job for mariadb.service failed because the control process exited with error code. See "systemctl status mariadb.service" and "journalctl -xe" for details.
    解决方法:查看错误日志:journalctl –xe
    查看端口是否被占用:netstat -tnlp|grep 3306
    最终的判断,MYSQL进程已经存在,无法启动Mariadb,解决方法,停止原来的MYSQL服务;
  • 报错3
    Redirecting to /bin/systemctl restart  mariadb.service
    ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)解决方法:
    使用journalctl –xe查看MYSQL错误信息;
    关闭服务器selinux安全策略,关闭防火墙setenforce 0;
    检查MYSQL|Mariadb通过什么样的方式部署的;
    检查其配置文件/etc/my.cnf,datadir数据目录是否配置;检查socket是否配置正确
    确认数据库的数据目录mysql用户是否拥有读写权限;
    检查数据库目录是否初始化,是否包括mysql、test基础库;
    检查socket文件所在的路径,是否存在socket文件,权限是否正确;
文章来源: rivers.blog.csdn.net,作者:宝山的博客,版权归原作者所有,如需转载,请联系作者。
原文链接:rivers.blog.csdn.net/article/details/115840939
