性能工具之 JMeter 5.0 核心源码浅析(下)
zuozewei 发表于 2021/12/23 00:57:37 2021/12/23
【摘要】 性能工具之 JMeter 5.0 核心源码浅析(下)
接上文性能工具之 JMeter 5.0 核心源码浅析(上)
四、JAVA运行JMeter示例
遵循以下规则:
  • 将JMeter文件安装在某个地方
  • 在项目lib或者JMeter安装的/ lib/ext文件夹中获取所需的 JMeter jar包。
JMeter的“压测引擎”就是 StandardJMeterEngine ,我们需要扩展此类或实现自己的JMeterEngine接口。
示例生成并读取.jmx文件并执行它,代码如下:
pom.xml引包
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <groupId>com.zuozewei</groupId>
    <artifactId>jmeter-from-code</artifactId>
    <version>1.0-SNAPSHOT</version>
    <packaging>jar</packaging>
    <build>
        <plugins>
            <plugin>
                <artifactId>maven-assembly-plugin</artifactId>
                <configuration>
                    <archive>
                        <manifest>
                            <mainClass>com.zuozewei.demo.JMeterFromScratch</mainClass>
                        </manifest>
                    </archive>
                    <descriptorRefs>
                        <descriptorRef>jar-with-dependencies</descriptorRef>
                    </descriptorRefs>
                </configuration>
                <executions>
                    <execution>
                        <id>make-assembly</id>
                        <phase>package</phase>
                        <goals>
                            <goal>single</goal>
                        </goals>
                    </execution>
                </executions>
            </plugin>
        </plugins>
    </build>
    <properties>
        <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
    </properties>
    <dependencies>
        <dependency>
            <groupId>org.apache.jmeter</groupId>
            <artifactId>ApacheJMeter_java</artifactId>
            <version>4.0</version>
        </dependency>
        <dependency>
            <artifactId>ApacheJMeter_http</artifactId>
        </dependency>
    </dependencies>
</project>
测试类
public class JMeterFromScratch {
    public static void main(String[] argv) throws Exception {
    	// 设置jmeterHome路径
		String jmeterHome1 = "/Users/apple/Downloads/performance/apache-jmeter-4.0";
        //File jmeterHome = new File(System.getProperty("jmeter.home"));
		File jmeterHome = new File(jmeterHome1);
        String slash = System.getProperty("file.separator");
        if (jmeterHome.exists()) {
            File jmeterProperties = new File(jmeterHome.getPath() + slash + "bin" + slash + "jmeter.properties");
            if (jmeterProperties.exists()) {
                //JMeter Engine 引擎
                StandardJMeterEngine jmeter = new StandardJMeterEngine();
                //JMeter initialization (properties, log levels, locale, etc)
                JMeterUtils.setJMeterHome(jmeterHome.getPath());
                JMeterUtils.loadJMeterProperties(jmeterProperties.getPath());
                JMeterUtils.initLogging();// you can comment this line out to see extra log messages of i.e. DEBUG level
                JMeterUtils.initLocale();
                // JMeter Test Plan, basically JOrphan HashTree
                HashTree testPlanTree = new HashTree();
                // 第一个 HTTP Sampler - 打开 baidu.com
                HTTPSamplerProxy examplecomSampler = new HTTPSamplerProxy();
                examplecomSampler.setDomain("baidu.com");
                examplecomSampler.setPort(80);
                examplecomSampler.setPath("/");
                examplecomSampler.setMethod("GET");
                examplecomSampler.setName("Open baidu.com");
                examplecomSampler.setProperty(TestElement.TEST_CLASS, HTTPSamplerProxy.class.getName());
                examplecomSampler.setProperty(TestElement.GUI_CLASS, HttpTestSampleGui.class.getName());
                // 第二个 HTTP Sampler - 打开 qq.com
                HTTPSamplerProxy blazemetercomSampler = new HTTPSamplerProxy();
                blazemetercomSampler.setDomain("qq.com");
                blazemetercomSampler.setPort(80);
                blazemetercomSampler.setPath("/");
                blazemetercomSampler.setMethod("GET");
                blazemetercomSampler.setName("Open qq.com");
                blazemetercomSampler.setProperty(TestElement.TEST_CLASS, HTTPSamplerProxy.class.getName());
                blazemetercomSampler.setProperty(TestElement.GUI_CLASS, HttpTestSampleGui.class.getName());
                // Loop Controller 循环控制
                LoopController loopController = new LoopController();
                loopController.setLoops(1);
                loopController.setFirst(true);
                loopController.setProperty(TestElement.TEST_CLASS, LoopController.class.getName());
                loopController.setProperty(TestElement.GUI_CLASS, LoopControlPanel.class.getName());
                loopController.initialize();
                // Thread Group 线程组
                ThreadGroup threadGroup = new ThreadGroup();
                threadGroup.setName("Example Thread Group");
                threadGroup.setNumThreads(1);
                threadGroup.setRampUp(1);
                threadGroup.setSamplerController(loopController);
                threadGroup.setProperty(TestElement.TEST_CLASS, ThreadGroup.class.getName());
                threadGroup.setProperty(TestElement.GUI_CLASS, ThreadGroupGui.class.getName());
                // Test Plan 测试计划
                TestPlan testPlan = new TestPlan("Create JMeter Script From Java Code");
                testPlan.setProperty(TestElement.TEST_CLASS, TestPlan.class.getName());
                testPlan.setProperty(TestElement.GUI_CLASS, TestPlanGui.class.getName());
                testPlan.setUserDefinedVariables((Arguments) new ArgumentsPanel().createTestElement());
                // Construct Test Plan from previously initialized elements
				// 从以上初始化的元素构造测试计划
                testPlanTree.add(testPlan);
                HashTree threadGroupHashTree = testPlanTree.add(testPlan, threadGroup);
                threadGroupHashTree.add(blazemetercomSampler);
                threadGroupHashTree.add(examplecomSampler);
                // save generated test plan to JMeter's .jmx file format
				// 将生成的测试计划保存为JMeter的.jmx文件格式
                SaveService.saveTree(testPlanTree, new FileOutputStream(jmeterHome + slash + "example.jmx"));
                //add Summarizer output to get test progress in stdout like:
				// 在stdout中添加summary输出,得到测试进度,如:
                // summary =      2 in   1.3s =    1.5/s Avg:   631 Min:   290 Max:   973 Err:     0 (0.00%)
                Summariser summer = null;
                String summariserName = JMeterUtils.getPropDefault("summariser.name", "summary");
                if (summariserName.length() > 0) {
                    summer = new Summariser(summariserName);
                // Store execution results into a .jtl file
				// 将执行结果存储到.jtl文件中
                String logFile = jmeterHome + slash + "example.jtl";
                ResultCollector logger = new ResultCollector(summer);
                logger.setFilename(logFile);
                testPlanTree.add(testPlanTree.getArray()[0], logger);
                // Run Test Plan
				// 执行测试计划
                jmeter.configure(testPlanTree);
                jmeter.run();
                System.out.println("Test completed. See " + jmeterHome + slash + "example.jtl file for results");
                System.out.println("JMeter .jmx script is available at " + jmeterHome + slash + "example.jmx");
                System.exit(0);
        System.err.println("jmeter.home property is not set or pointing to incorrect location");
        System.exit(1);
测试结果
summary =      2 in 00:00:03 =    0.8/s Avg:   951 Min:   933 Max:   969 Err:     0 (0.00%)
Test completed. See /Users/apple/Downloads/performance/apache-jmeter-4.0/example.jtl file for results
JMeter .jmx script is available at /Users/apple/Downloads/performance/apache-jmeter-4.0/example.jmx
Process finished with exit code 0
本文源码地址:
