Python 只有int类型,没有long类型
千江有水千江月 发表于 2021/12/20 15:36:34 2021/12/20
【摘要】 环境信息ModelArtsNotebookmindspore1.2.0-openmpi2.1.1-ubuntu18.04  代码示例help(long) ---------------------------------------------------------------------------NameError T...
环境信息
  • ModelArts
    • Notebook
      • mindspore1.2.0-openmpi2.1.1-ubuntu18.04
代码示例
help(long)
NameError                                 Traceback (most recent call last)
<ipython-input-21-5610b93dd7ae> in <module>
----> 1 help(long)
NameError: name 'long' is not defined
type(2 ** 100)
int
源码学习
help(int)
class int(object)
 |  int([x]) -> integer
 |  int(x, base=10) -> integer
 |  Convert a number or string to an integer, or return 0 if no arguments
 |  are given.  If x is a number, return x.__int__().  For floating point
 |  numbers, this truncates towards zero.
 |  If x is not a number or if base is given, then x must be a string,
 |  bytes, or bytearray instance representing an integer literal in the
 |  given base.  The literal can be preceded by '+' or '-' and be surrounded
 |  by whitespace.  The base defaults to 10.  Valid bases are 0 and 2-36.
 |  Base 0 means to interpret the base from the string as an integer literal.
......(部分截取)
备注
  1. 欢迎各位同学一起来交流学习心得^_^
  2. 在线课程、沙箱实验、认证、大赛、论坛和直播,其中包含了许多优质的内容,推荐了解与学习。
