oracle诊断工具-RDA使用
snowofsummer 发表于 2021/12/18 17:57:53 2021/12/18
【摘要】 1、工具下载。下载地址:Remote Diagnostic Agent (RDA) - Getting Started (文档 ID 314422.1)2、支持操作系统Apple Mac OS X/DarwinHP OpenVMS Alpha 7.3-2 and aboveHP OpenVMS ItaniumHP Tru64 UNIXHP-UX ItaniumHP-UX PA-RISC (3...
1、工具下载。
下载地址:
2、支持操作系统
HP OpenVMS Itanium
HP Tru64 UNIX
HP-UX Itanium
HP-UX PA-RISC (32 and 64 bit)
IBM AIX on POWER Systems(32 and 64 bit)
IBM Dynix/Ptx
IBM Linux on POWER
IBM zSeries Based Linux
Linux Itanium
Linux x86 (32 and 64 bit)
Microsoft Windows 7
Microsoft Windows 2000 Workstation and Server
Microsoft Windows 2003 Server
Microsoft Windows 2008 (including SBS2011)
Microsoft Windows 2012
Microsoft Windows 2016
Microsoft Windows 2019
Microsoft Windows Vista
Microsoft Windows XP Professional
Sun Solaris Intel
Sun Solaris SPARC (32 and 64 bit)
支持的产品
OLAP Products (Express Server, Financial Analyzer, and Demand Planning Server)
Oracle Application Server (iAS 1.0.2.x/9.0.x/10.1.2.x/10.1.3.x,10.1.4.x,WebLogic Server (WLS) Release 9.x, 10.x, 11g and 12c (WLS), HTTP Server,WebCache,J2EE/OC4J)
Oracle Billing and Revenue Management products
Oracle BPEL Process Manager
Oracle Collaboration Suite (Email Server,Calendar,Discussions,Content Services,Workspaces,WebClient,and Wireless)
Oracle Data Integrator
Oracle Developer (Forms and Reports)
Oracle Ebusiness Suite 11i and 12
Oracle Enterprise Content
Oracle Enterprise Single Sign-on
Oracle Enterprise performance management (Hyperion) products
Oracle Guardian
Oracle Identity Management products
Oracle JDBC/PRO *C/ODBC and other development client related information
Oracle Management Server and Intelligent Agent (Grid Server, Agent Server, DB Control)
Oracle Networking products
Oracle RAC Cluster (Single/Multiple Nodes, Automatic Storage Management, Oracle Cluster File System, Data Guard)
Oracle RDBMS Server (Standard and Enterprise Editions)
Oracle Retail (Retek)
Oracle SQL*Plus/iSQL*Plus
Oracle TimesTen In-Memory Database
Oracle Universal Archive (11g)
PeopleSoft
Siebel
RDA的使用
在Unix操作系统中,oracle推荐在数据库创建用户下执行(一般即为oracle用户)
第一次使用需要做一个采集的初始配置。
执行命令:
./rda.sh -S
执行命令后,会有个向导化的界面让你根据当前数据库的实际安装的产品完成初始配置。 完成配置后rda目录下会生成配置文件 setup.cfg、setup.bak, 如果需要重新调整配置参数,可以直接修改该文件。
初始配置完毕后要采集数据,执行命令:
./rda.sh
如果要看到详细的采集过程,可以执行命令:
./rda.sh -v
在采集过程中有可能需要你输入数据库相关用户的密码。
采集完成后,在rda目录下根据初始配置文件会生成格式为zip的报告文件以及采集日志, 默认文件位置 ./output/RDA.$machine_name.zip。
解压缩该文件,访问 <report_group>__start.htm,就可以看到这次采集的数据的详细信息。
使用时的注意点:
1、有时不能生成zip格式的报告文件,这跟客户端是否安装压缩工具有关,需要自行解压缩相关报告文件。
2、如果需要安装已生成的配置再次采集,删除已生成的报告文件,然后执行命令:
./rda.sh -Svf 重新设置后再执行采集命令
./rda.sh -v
采集数据分析
报告文件主要包括数据库对应机器的操作系统软、硬件环境、用户设置以及数据库详细的信息(初始参数、运行事件、日常监控等)
在日常的维护当中,我们主要
1、关注RDBMS下的几个统计信息。
Database SPFile Parameters spfile中数据库相关初始参数的设置
SGA Information 查看系统全局区当前内存信息
Sessions and Processes 采集时间内的数据库会话相关信息
V$System_Event 数据库实例整个运行期间所有进程事件的等待统计视图
V$Session_Wait 会话等待事件以及相关定位信息数据
Latch Information 竞争相关信息(翻译不是很准确)
Tablespaces 数据库表空间信息(表空间类型、对应数据文件使用率、是否可扩展等等)
Database Files 数据库对应数据文件信息(文件位置、使用率等)
Invalid Objects 失效的数据库对象,日常监控如果发现有失效,需要维护人员手工重新编译
all errors 日常执行的数据库错误
在 V$System_Event、 V$Session_Wait 主要关注(buffer busy waits、db file scattered read、db file sequential read、enqueue、free buffer waits、latch free、log file sync、log file paralle write 这些事件。
【版权声明】本文为华为云社区用户翻译文章,如果您发现本社区中有涉嫌抄袭的内容,欢迎发送邮件进行举报,并提供相关证据,一经查实,本社区将立刻删除涉嫌侵权内容, 举报邮箱:cloudbbs@huaweicloud.com
