Android学习笔记04
wh_bn 发表于 2021/12/15 23:11:58 2021/12/15
【摘要】 [Android开发视频教学].01_12_Android常见控件(二) 主要学习 RadioGroup RadioButton CheckBox Toast的用法 布局文件  <LinearLayout xmlns:android="http://schemas.android.com/apk/r...
主要学习
RadioGroup
RadioButton
CheckBox
Toast的用法
布局文件
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    android:orientation="vertical" >
    <TextView
        android:layout_width="wrap_content"
        android:layout_height="wrap_content"
        android:text="@string/gender"
        tools:context=".RadioMain"
        android:layout_margin="10dp"/>
    <RadioGroup
        android:id="@+id/gendergroup"
        android:layout_width="fill_parent"
        android:layout_height="wrap_content" >
        <RadioButton
            android:id="@+id/male"
            android:text="@string/male" />
        <RadioButton
            android:id="@+id/female"
            android:text="@string/female" />
    </RadioGroup>
    <CheckBox
        android:id="@+id/up"
        android:text="@string/up" />
    <CheckBox
        android:id="@+id/down"
        android:text="@string/down" />
    <CheckBox
        android:id="@+id/left"
        android:text="@string/left" />
    <CheckBox
        android:id="@+id/right"
        android:text="@string/right" />
</LinearLayout>
<resources>
    <string name="app_name">Android07</string>
    <string name="hello_world">Hello world!</string>
    <string name="menu_settings">Settings</string>
    <string name="title_activity_radio_main">RadioMain</string>
	<string name="gender">性别</string>
	<string name="male">男</string>
	<string name="female">女</string>
	<string name="up">上</string>
	<string name="down">下</string>
	<string name="left">左</string>
	<string name="right">右</string>
</resources>
Java文件
package fegnda.android07;
import android.app.Activity;
import android.os.Bundle;
import android.view.Menu;
import android.widget.CheckBox;
import android.widget.CompoundButton;
import android.widget.RadioButton;
import android.widget.RadioGroup;
import android.widget.Toast;
public class RadioMain extends Activity {
	private RadioGroup genderGroup = null;
	private RadioButton male = null;
	private RadioButton female = null;
	private CheckBox up = null;
	private CheckBox down = null;
	private CheckBox left = null;
	private CheckBox right = null;
	@Override
	public void onCreate(Bundle savedInstanceState) {
		super.onCreate(savedInstanceState);
		setContentView(R.layout.activity_radio_main);
		genderGroup = (RadioGroup) findViewById(R.id.gendergroup);
		male = (RadioButton) findViewById(R.id.male);
		female = (RadioButton) findViewById(R.id.female);
		genderGroup
				.setOnCheckedChangeListener(new RadioGroup.OnCheckedChangeListener() {
					@Override
					public void onCheckedChanged(RadioGroup group, int checkedId) {
						// TODO Auto-generated method stub
						if (male.getId() == checkedId) {
							Toast.makeText(RadioMain.this, "男",
									Toast.LENGTH_SHORT).show();
						if (female.getId() == checkedId) {
							Toast.makeText(RadioMain.this, "女",
		up = (CheckBox) findViewById(R.id.up);
		down = (CheckBox) findViewById(R.id.down);
		left = (CheckBox) findViewById(R.id.left);
		right = (CheckBox) findViewById(R.id.right);
		up.setOnCheckedChangeListener(new CompoundButton.OnCheckedChangeListener() {
			@Override
			public void onCheckedChanged(CompoundButton buttonView,
					boolean isChecked) {
				if (isChecked) {
					Toast.makeText(RadioMain.this, "上", Toast.LENGTH_SHORT)
							.show();
		down.setOnCheckedChangeListener(new CompoundButton.OnCheckedChangeListener() {
			@Override
				if (isChecked){
					Toast.makeText(RadioMain.this, "下", Toast.LENGTH_SHORT).show();
		left.setOnCheckedChangeListener(new CompoundButton.OnCheckedChangeListener(){
			@Override
				if(isChecked){
					Toast.makeText(RadioMain.this, "左", Toast.LENGTH_SHORT).show();
		right.setOnCheckedChangeListener(new CompoundButton.OnCheckedChangeListener() {
			@Override
			public void onCheckedChanged(CompoundButton buttonView, boolean isChecked) {
				if (isChecked){
					Toast.makeText(RadioMain.this, "右", Toast.LENGTH_SHORT).show();
	@Override
	public boolean onCreateOptionsMenu(Menu menu) {
		getMenuInflater().inflate(R.menu.activity_radio_main, menu);
		return true;
最终结果
文章来源: blog.csdn.net,作者:fengda2870,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/fengda2870/article/details/8155412
