android - FlutterActivity MethodChannel和FlutterView
坚果派 发表于 2021/12/15 23:17:07 2021/12/15
【摘要】 android - FlutterActivity MethodChannel和FlutterView 因此,大约4个月前,我编写了Flutter应用程序。现在,我想做一个小小的更改,但是我不能再编译应...
因此,大约4个月前,我编写了Flutter应用程序。现在,我想做一个小小的更改,但是我不能再编译应用程序了,因为GeneratedPluginRegistrant.registerWith(this)不再起作用了,我没有更改Kotlin代码,只更改了Dart代码。
“GeneratedPluginRegistrant.registerWith( this )”中的“此”向我显示此错误:
Type mismatch.
Required: FlutterEngine!
Found: MainActivity
MainActivity类:
import android.os.Bundle
import io.flutter.app.FlutterActivity
import io.flutter.plugin.common.MethodChannel
import io.flutter.plugins.GeneratedPluginRegistrant
import io.flutter.view.FlutterMain
class MainActivity : FlutterActivity() {
  override fun onCreate(savedInstanceState: Bundle?) {
    super.onCreate(savedInstanceState)
    GeneratedPluginRegistrant.registerWith(this) // here is the error: Type mismatch. Required: FlutterEngine! Found: MainActivity
    MethodChannel(flutterView, CHANNEL).setMethodCallHandler { call, result ->
      if (call.method == "helloFromNativeCode") {
        val greetings = helloFromNativeCode()
        result.success(greetings)
  private fun helloFromNativeCode(): String {
    return "Hello from Native Android Code"
  companion object {
    private const val CHANNEL = "flutter.native/helper"
  • 26
  • 27
  • 28
如果使用:
import io.flutter.embedding.android.FlutterActivity
    代替
      我可以用
      override fun configureFlutterEngine(flutterEngine: FlutterEngine) {
              GeneratedPluginRegistrant.registerWith(flutterEngine);
      但遇到以下问题:
      因为我在 flutterView 上遇到错误:
      Unresolved reference: flutterView
        代码如下所示:
        import io.flutter.embedding.engine.FlutterEngine
            MethodChannel(flutterView, CHANNEL).setMethodCallHandler { call, result -> // here is the error
          companion object {
        • 26
        • 27
        • 28
        • 29
        • 30
        我希望有一个人可以帮助我。
        最佳答案
        代替flutterView,请使用flutterEngine.getDartExecutor()。
        关于android - FlutterActivity MethodChannel和FlutterView,我们在Stack Overflow上找到一个类似的问题: https://stackoverflow.com/questions/59323505/
        import 'package:flutter/material.dart';
        import 'package:flutter/services.dart';
        import 'package:flutter_package_demo/theme/themes.dart';
        class UserPage extends StatefulWidget {
          const UserPage({Key key}) : super(key: key);
          @override
          _UserPageState createState() => _UserPageState();
        const String CHANNEL =
            "www.luckly.work"; //这儿要与        MethodChannel(flutterView, CHANNEL)中CHANNEL名称一致
        const String invokeMethod =
            "breeze"; //这儿要与       call.method == invokeMethod中invokeMethod名称一致
        var channel = const MethodChannel(CHANNEL);
        class _UserPageState extends State<UserPage> {
          String _result = "";
          @override
          Widget build(BuildContext context) {
            final theme = Theme.of(context);
            return Scaffold(
              appBar: AppBar(
                title: Text(
                  "个人",
                  style: TextStyle(
                    color: theme.accentColor,
              body: Container(
                child: Column(
                  children: [
                    Text(
                      "个人",
                      style: TextStyle(
                    FlatButton(
                      onPressed: () {
                        setState(() {});
                        currentTheme.toggleTheme();
                      child: Text(
                        "多主题",
                        style: TextStyle(
                    Center(
                      child: RaisedButton(
                        onPressed: () async {
                          var result = await channel.invokeMethod(invokeMethod);
                          setState(() {
                            _result = result;
                          print(result);
                        child: new Text(_result),
        • 26
        • 27
        • 28
        • 29
        • 30
        • 31
        • 32
        • 33
        • 34
        • 35
        • 36
        • 37
        • 38
        • 39
        • 40
        • 41
        • 42
        • 43
        • 44
        • 45
        • 46
        • 47
        • 48
        • 49
        • 50
        • 51
        • 52
        • 53
        • 54
        • 55
        • 56
        • 57
        • 58
        • 59
        • 60
        • 61
        • 62
        • 63
        • 64
        • 65
        • 66
        • 67
        • 68
        • 69
        • 70
        • 71
        • 72
        package com.example.flutter_package_demo
        //import io.flutter.app.FlutterActivity
        //import io.flutter.embedding.android.FlutterActivity
        //import io.flutter.view.FlutterMain
        //        GeneratedPluginRegistrant.registerWith(this) // here is the error: Type mismatch. Required: FlutterEngine! Found: MainActivity
                    if (call.method == InvokeMethod) {
                        val greetings = successNativeCode()
            private fun successNativeCode(): String {
                return "我是android原生跑过来的数据"
            companion object {
                private const val CHANNEL = "www.luckly.work"
                private const val InvokeMethod = "breeze"
        • 26
        • 27
        • 28
        • 29
        • 30
        • 31
        • 32
        • 33
        • 34
        • 35
        文章来源: jianguo.blog.csdn.net,作者:坚果前端の博客,版权归原作者所有,如需转载,请联系作者。
        原文链接:jianguo.blog.csdn.net/article/details/119887580
