flutter中本地存储shared_preferences的使用
坚果派 发表于 2021/12/15 23:33:50 2021/12/15
【摘要】 首先在 pubspec.yaml 文件中添加 shared_preferences 引用并 Packages get dependencies: flutter: sdk: flutter ...
dependencies:
  flutter:
    sdk: flutter
  # The following adds the Cupertino Icons font to your application.
  # Use with the CupertinoIcons class for iOS style icons.
  shared_preferences:
然后封装 SharedPreferences 工具类
import 'package:shared_preferences/shared_preferences.dart';
 * @des SharedPreferences 工具类
 * @author liyongli 20190522
class SharedPreferencesDataUtils{
  // 保存数据
  Future setUserInfo(key, value) async{
    SharedPreferences sp = await SharedPreferences.getInstance();
    sp.setString(key, value);
  // 获取数据
  Future getUserInfo(key) async{
    print(sp.get(key));
    return sp.get(key);
  // 清除数据
  Future deleteUserInfo(key) async{
    sp.remove(key);
  • 26
  • 27
  • 28
调用方式
    SharedPreferencesDataUtils spDataUtils = new SharedPreferencesDataUtils();
    spDataUtils.setUserInfo("name","Flutter Flutter Flutter");
    spDataUtils.setUserInfo("type","Save Save Save");
    print(dataUtils.getUserInfo("name"));
    print(dataUtils.getUserInfo("type"));
运行结果
    I/flutter (13801): Flutter Flutter Flutter
    I/flutter (13801): Save Save Save
文章来源: jianguo.blog.csdn.net,作者:坚果前端の博客,版权归原作者所有,如需转载,请联系作者。
原文链接:jianguo.blog.csdn.net/article/details/120137673
