python中循环的技巧
坚果派 发表于 2021/12/15 22:33:13 2021/12/15
【摘要】 循环的技巧 在字典中循环时,用 items() 方法可同时取出键和对应的值: >>> >>> knights = {'gallahad': 'the pure',...
循环的技巧
>>> knights = {'gallahad': 'the pure', 'robin': 'the brave'}
>>> for k, v in knights.items():
...     print(k, v)
gallahad the pure
robin the brave
在序列中循环时,用 enumerate() 函数可以同时取出位置索引和对应的值:
>>> for i, v in enumerate(['tic', 'tac', 'toe']):
...     print(i, v)
0 tic
1 tac
2 toe
同时循环两个或多个序列时,用 zip() 函数可以将其内的元素一一匹配:
>>> questions = ['name', 'quest', 'favorite color']
>>> answers = ['lancelot', 'the holy grail', 'blue']
>>> for q, a in zip(questions, answers):
...     print('What is your {0}?  It is {1}.'.format(q, a))
What is your name?  It is lancelot.
What is your quest?  It is the holy grail.
What is your favorite color?  It is blue.
逆向循环序列时,先正向定位序列,然后调用 reversed() 函数:
>>> for i in reversed(range(1, 10, 2)):
...     print(i)
9
7
5
3
1
按指定顺序循环序列,可以用 sorted() 函数,在不改动原序列的基础上,返回一个重新的序列:
>>> basket = ['apple', 'orange', 'apple', 'pear', 'orange', 'banana']
>>> for i in sorted(basket):
...     print(i)
apple
apple
banana
orange
orange
pear
使用 set() 去除序列中的重复元素。使用 sorted() 加 set() 则按排序后的顺序,循环遍历序列中的唯一元素:
>>> for f in sorted(set(basket)):
...     print(f)
apple
banana
orange
pear
一般来说,在循环中修改列表的内容时,创建新列表比较简单,且安全:
>>> import math
>>> raw_data = [56.2, float('NaN'), 51.7, 55.3, 52.5, float('NaN'), 47.8]
>>> filtered_data = []
>>> for value in raw_data:
...     if not math.isnan(value):
...         filtered_data.append(value)
>>> filtered_data
[56.2, 51.7, 55.3, 52.5, 47.8]
文章来源: jianguo.blog.csdn.net,作者:坚果前端の博客,版权归原作者所有,如需转载,请联系作者。
原文链接:jianguo.blog.csdn.net/article/details/114241097
