JDBC工具类(DButil)
坚果派 发表于 2021/12/15 23:34:47 2021/12/15
【摘要】 package lesson11; import java.sql.Connection; import java.sql.DriverManager; import java.sql.Prepared...
package lesson11;
import java.sql.PreparedStatement;
import java.sql.ResultSet;
import java.sql.ResultSetMetaData;
import java.sql.SQLException;
import java.sql.Statement;
import java.util.ArrayList;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
public class DBUtil {
	private Connection conn = null;
	private Statement st = null;
	private PreparedStatement ps = null;
	private ResultSet rs = null;
	private String url = "jdbc:mysql://localhost:3306/filmcenter_db";
	private String username = "root";
	private String psw = "root";
//1.加载驱动
static{
	try {
		Class.forName("com.mysql.jdbc.Driver");
	} catch (ClassNotFoundException e) {
		System.out.println("加载驱动失败!!");
		e.printStackTrace();
//2.获取连接
public Connection getConn(){
	try {
		conn = DriverManager.getConnection(url,username,psw);
	} catch (SQLException e) {
		System.out.println("获取连接失败!!");
	return conn;
//3.提供更新方法
public int update(String sql, Object[] objs){
	conn = getConn();
	try {
		ps = conn.prepareStatement(sql);
		for(int i = 0 ; i < objs.length ; i ++){
			ps.setObject(i + 1, objs[i]);
		return ps.executeUpdate();
		System.out.println("更新失败!!");
		return -1;
	}finally{
		release();
//4.提供查询方法
public List<Map<String,Object>> query(String sql, Object[] objs){
	List<Map<String,Object>> list = new ArrayList<Map<String,Object>>();
	try {
		ps = getConn().prepareStatement(sql);
		rs = ps.executeQuery();
		ResultSetMetaData rsmd = rs.getMetaData();
		while(rs.next()){
			Map<String,Object> map = new HashMap<String,Object>();
			for(int i = 0 ; i < rsmd.getColumnCount() ; i ++){
				String key = rsmd.getColumnName(i + 1);
				Object value = rs.getObject(key);
				map.put(key, value);
			list.add(map);
		return list;
		System.out.println("查询操作失败!");
		return list;
	}finally{
		release();
//5.批量更新
public void batch(String[] sqls){
	try {
		conn = getConn();
		conn.setAutoCommit(false);
		st = conn.createStatement();
		for(int i = 0; i < sqls.length ; i ++){
			st.addBatch(sqls[i]);
		st.executeBatch();
		try {
			conn.rollback();
		} catch (SQLException e1) {
			e1.printStackTrace();
	}finally{
		try {
			conn.commit();
		release();
//释放资源
public void release(){
	if(rs != null){
		try {
			rs.close();
			System.out.println("关闭结果集对象出现异常!");
	if(ps != null){
		try {
			ps.close();
			System.out.println("关闭预处理语句对象出现异常!");
	if(st != null){
		try {
			st.close();
			System.out.println("关闭语句对象出现异常!");
	if(conn != null){
		try {
			conn.close();
			System.out.println("关闭连接对象出现异常!");
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
文章来源: jianguo.blog.csdn.net,作者:坚果前端の博客,版权归原作者所有,如需转载,请联系作者。
原文链接:jianguo.blog.csdn.net/article/details/106889464
