PHP——实现Zend Debug
wh_bn 发表于 2021/12/15 22:28:42 2021/12/15
【摘要】 zend debugger下载地址: http://downloads.zend.com/pdt/server-debugger/ZendDebugger-5.2.15-cygwin_nt-i386.zip   Zend Debugger installation instructions ---------------...
zend debugger下载地址:
1. Extract the Zend Debugger package.
2. Locate the ZendDebugger.so (Unix) or ZendDebugger.dll (Windows) file in the directory which
   corresponds to your version of PHP (4.3.x, 4.4.x, 5.0.x, 5.1.x, 5.2.x).
2. Add the following line to your php.ini file:
   Linux and Mac OS X:     zend_extension=<full_path_to_ZendDebugger.so>
   Windows:                zend_extension_ts=<full_path _to_ZendDebugger.dll>
   Windows non-thread safe: zend_extension=<full_path_to_ZendDebugger.dll>
   (*) The Windows non-thread safe binary is only used with Zend Core 2.0.
3. Add the following lines to your php.ini file:
   zend_debugger.allow_hosts=<host_ip_addresses> 多 个 IP地址用逗号隔开
   zend_debugger.expose_remotely=always
   (*) hopst_ip_addresses are the IPs of the hosts which will be allowed to initiate debug sessions
4. Copy the dummy.php file to your document root directory.
5. Restart your Web server.
以上英文相当简单
就不翻译了
有一点注意
5_2_x_nts_comp
中的nts 意思为 no-thread-safe
设置完zend debugger后,回到eclipse中,选择Window-Preferences-php-php executables里面添加一条记录,指向你的php安装目录;
设置完毕以上事项后,在eclipse中,选择Help-Help Contents-PDT User Guide-Getting Started-Basic Tutorials-Working with the Debugger,请参照此文档学习如何在该环境下调试php代码,需要提醒注意的是在进行php web程序调试的时候,一定要把工程文件复制到apache服务器目录下,并且做好与本地文件之间的对应关系,这样一旦开始进入调试模式,调试器才能找到源代码。
文章来源: blog.csdn.net,作者:fengda2870,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/fengda2870/article/details/5705576
