Android学习笔记05:ProgressBar的使用
wh_bn 发表于 2021/12/15 23:16:05 2021/12/15
【摘要】 [Android开发视频教学].01_13_Android常见控件(三)之一 学习使用ProgressBar <LinearLayout xmlns:android="http://schemas.android.com/apk/res/android" xmlns:tools="http://schemas.and...
学习使用ProgressBar
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    android:orientation="vertical" >
    <TextView
        android:layout_width="wrap_content"
        android:layout_height="wrap_content"
        android:text="@string/hello_world"
        tools:context=".Activity08" />
    <ProgressBar
        android:id="@+id/progressBar1"
        style="@android:style/Widget.ProgressBar.Small"
        android:layout_width="fill_parent"
        android:visibility="gone" />
    <ProgressBar
        android:id="@+id/progressBar2"
        style="@android:style/Widget.ProgressBar.Horizontal"
    <Button
        android:id="@+id/button"
        android:text="@string/button" />
</LinearLayout>
style="?android:attr/progressBarStyleHorizontal"
但是这个格式在Eclipse中没有提示,看了下帮助文档,也可以这样写的
package fengda.android08;
import android.app.Activity;
import android.os.Bundle;
import android.view.Menu;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.ProgressBar;
public class Activity08 extends Activity {
	private ProgressBar progressBar1;
	private ProgressBar progressBar2;
	private Button button;
	private int i =0;
    @Override
    public void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_activity08);
        progressBar1 = (ProgressBar) findViewById(R.id.progressBar1);
        progressBar2 = (ProgressBar) findViewById(R.id.progressBar2);
        button = (Button) findViewById(R.id.button);;
        button.setOnClickListener( new ButtonOnClickListener());
    class ButtonOnClickListener implements OnClickListener {
		@Override
		public void onClick(View v) {
			// TODO Auto-generated method stub
			if (i==0){
				progressBar1.setVisibility(View.VISIBLE);
				progressBar2.setVisibility(View.VISIBLE);
			} else if(i<100){
				progressBar1.setProgress(i);
				progressBar2.setProgress(i);
				progressBar2.setSecondaryProgress(i+10);
				progressBar1.setVisibility(View.GONE);
				progressBar2.setVisibility(View.GONE);
			i = i+10;
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        getMenuInflater().inflate(R.menu.activity_activity08, menu);
        return true;
文章来源: blog.csdn.net,作者:fengda2870,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/fengda2870/article/details/8160358
