Android学习笔记06:ListView的使用
wh_bn 发表于 2021/12/16 01:08:17 2021/12/16
【摘要】 [Android开发视频教学].01_13_Android常见控件(三)之二 学习使用ListView list.xml <LinearLayout xmlns:android="http://schemas.android.com/apk/res/android" xmlns:tools="http://schem...
list.xml
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="fill_parent"
    android:layout_height="fill_parent"
    android:orientation="vertical" >
    <ListView
        android:id="@id/android:list"
        android:layout_height="wrap_content"
        android:drawSelectorOnTop="false"
        android:scrollbars="vertical" >
    </ListView>
</LinearLayout>
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    android:orientation="horizontal" >
    <TextView
        android:id="@+id/user_ip"
        android:layout_width="180dp"
        android:layout_height="20dp"
        android:gravity="left" />
    <TextView
        android:id="@+id/user_name"
        android:gravity="right"
        android:layout_height="20dp" />
</LinearLayout>
package fengda.android09;
import java.util.ArrayList;
import java.util.HashMap;
import android.app.ListActivity;
import android.os.Bundle;
import android.view.View;
import android.widget.ListView;
import android.widget.SimpleAdapter;
public class Activity09 extends ListActivity {
	@Override
	public void onCreate(Bundle savedInstanceState) {
		super.onCreate(savedInstanceState);
		setContentView(R.layout.activity_activity09);
		ArrayList<HashMap<String, String>> mapList = new ArrayList<HashMap<String, String>>();
		HashMap<String, String> map1 = new HashMap<String, String>();
		HashMap<String, String> map2 = new HashMap<String, String>();
		HashMap<String, String> map3 = new HashMap<String, String>();
		map1.put("usr_ip", "192.168.0.1");
		map1.put("user_name", "一号");
		map2.put("user_ip", "192.168.0.2");
		map2.put("user_name", "二号");
		map3.put("user_ip", "192.168.0.3");
		map3.put("user_name", "三号");
		mapList.add(map1);
		mapList.add(map2);
		mapList.add(map3);
		SimpleAdapter ad = new SimpleAdapter(this, mapList, R.layout.user,
				new String[] { "user_ip", "user_name" }, new int[] {
						R.id.user_ip, R.id.user_name });
		this.setListAdapter(ad);
	@Override
	protected void onListItemClick(ListView l, View v, int position, long id) {
		// TODO Auto-generated method stub
		super.onListItemClick(l, v, position, id);
文章来源: blog.csdn.net,作者:fengda2870,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/fengda2870/article/details/8161598
