Python 时间码与帧数的互换
wh_bn 发表于 2021/12/16 00:04:45 2021/12/16
【摘要】 framerate = 24 def timecode_to_frames(timecode): return sum(f * int(t) for f,t in zip((3600*framerate, 60*framerate, framerate, 1), timecode.split(':'))) print ti...
  1. framerate = 24
  2. def timecode_to_frames(timecode):
  3. return sum(f * int(t) for f,t in zip((3600*framerate, 60*framerate, framerate, 1), timecode.split(':')))
  4. print timecode_to_frames('15:41:08:02') - timecode_to_frames('15:41:07:00')
  5. # returns 26
  6. def frames_to_timecode(frames):
  7. return '{0:02d}:{1:02d}:{2:02d}:{3:02d}'.format(frames / (3600*framerate),
  8. frames / (60*framerate) % 60,
  9. frames / framerate % 60,
  10. frames % framerate)
  11. print frames_to_timecode(26)
  12. # returns "00:00:01:02"
文章来源: blog.csdn.net,作者:fengda2870,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/fengda2870/article/details/69389141
