Excel 每5行选择一行的VBA代码
wh_bn 发表于 2021/12/15 22:20:59 2021/12/15
【摘要】 Sub 选取行5() Application.ScreenUpdating = False Dim curRow As Long Dim selRan As Range For curRow = 1 To 5000 If (curRow) Mod 5 = 0 Then If selRan Is Noth...
  1. Sub 选取行5()
  2. Application.ScreenUpdating = False
  3. Dim curRow As Long
  4. Dim selRan As Range
  5. For curRow = 1 To 5000
  6. If (curRow) Mod 5 = 0 Then
  7. If selRan Is Nothing Then
  8. Set selRan = Range("A" & curRow)
  9. Else
  10. Set selRan = Union(selRan, Range("A" & curRow))
  11. End If
  12. End If
  13. Next
  14. selRan.EntireRow.Select
  15. Application.ScreenUpdating = True
  16. End Sub
文章来源: blog.csdn.net,作者:fengda2870,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/fengda2870/article/details/89250735
