h5逐步实现 <<canvas系统>>(html逻辑 css逻辑 js逻辑)
陈业贵 发表于 2021/12/14 23:22:48 2021/12/14
【摘要】 <!DOCTYPE html> <html lang="en"> <head> <meta charset="UTF-8"> <meta na...
<!DOCTYPE html>
<html lang="en">
<head>
	<meta name="viewport" content="width=device-width, initial-scale=1.0">
	<title>Document</title>
	<style type="text/css">
		*{padding: 0px;margin: 0px;}
		body
			overflow: hidden;
	</style>
</head>
<body>
	<canvas id="draw" ></canvas>
	<script type="text/javascript">
		//获取canvas.
		const canvas=document.querySelector("#draw");
		if(canvas.getContext)
			var ctx=canvas.getContext("2d");
			console.log("支持666");
		else
			console.log("不支持");
		/*支持就执行余下的语句能够用起来,不支持的话,页面上会什么效果都没有。*/
		canvas.width=window.innerWidth;
		canvas.height=window.innerHeight;
		ctx.lineWidth=90;//线条的颜色.
		ctx.lineCap="round";/*线条结束时的形状*/
		ctx.lineJoin="round";/*当两条线条相交时.*/
		ctx.strokeStyle="red";
		let isDrawing=false;//还没开始画
		let x=0;let y=0;
		let lastX = 0;
    	let lastY = 0;
    	let hue = 0;
    	let direction = true;
		function draw(e)
			if(!isDrawing)
				return;
			x=e.offsetX;//获取移动后停下的坐标点.
			y=e.offsetY;//获取移动后停下的坐标点.
			//彩虹效
			ctx.strokeStyle=`hsl(${hue},90%,50%)`;
			if(hue>360)hue=0;
			hue++;
			//		控制笔触大小
			if(ctx.lineWidth>120||ctx.lineWidth<10)
				direction=!direction;
			if(direction)
				ctx.lineWidth++;
			else
				ctx.lineWidth--;
			/*这段思路时:开始direction = true,++到大于120就direction=!direction;,为false,就else--到小于10时就	direction=!direction;,true,就++至此循环.*/
			ctx.beginPath();
			ctx.moveTo(lastX,lastY);//开始画了
			ctx.lineTo(x,y);
			ctx.stroke();
			[lastX,lastY]=[x,y]
		canvas.addEventListener('mousedown',e=>
			isDrawing=true;//开始画.
			[lastX,lastY]=[e.offsetX,e.offsetY];//获取按下的开始xy坐标点
		canvas.addEventListener("mousemove",draw);
		canvas.addEventListener('mouseup',()=>isDrawing=false);//这两个都false
		canvas.addEventListener('mouseout',()=>isDrawing=false);
	</script>
</body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
第一:写一个canvas对象,用canvas来做.
```javascript
注意一下:它默认宽300 高150。
<!DOCTYPE html>
<html lang="en">
<head>
</head>
<body>
	<canvas id="canvas"></canvas>
		console.log(canvas.offsetWidth,canvas.offsetHeight);
	</script>
</body>
</html>
第二·:判断所用的浏览器是否支持canvas.
		else
			console.log("不支持");
第三:让canvas绘图可以画整个body.并且要设置线条的宽度+线条结束时候的形状+两天线条相交时的形状.+线条的颜色.
		ctx.lineWidth=90;
第四;当点击body某一处的时候就开始作画.然后是获取按下去时候的xy坐标点.
			isDrawing=true;
第五:移动的时候触发draw函数,
第六:记录移动完毕后的xy坐标.
x=e.offsetX;
y=e.offsetY;
第七;多姿多彩的效果:
			if(hue>360)hue=0;
			hue++;
第八:控制笔触的宽.(口诀;太大了就小,太小了就大)
			if(direction)
				ctx.lineWidth++;
			else
				ctx.lineWidth--;
第九:开始绘制
ctx.beginPath();
			ctx.lineTo(x,y);
			ctx.stroke();
			[lastX,lastY]=[x,y]//核心
注意一下·;lastx与lasty是down的时候的xy坐标,x,y是move完毕后的坐标.
有一个问题
第十:怎么办?[lastX,lastY]=[x,y]
就行了,代表按下了一直移动能够完美续接.
不然的话,会按下然后移动会像上面的图一样。
这里解决了上面的图片的问题.
文章来源: blog.csdn.net,作者:贵哥的编程之路(陈业贵),版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_37805832/article/details/109020236
