Hadoop hdfs客户端配置
snowofsummer 发表于 2021/12/14 11:29:46 2021/12/14
【摘要】 hdfs单节点安装配置参考:https://bbs.huaweicloud.cn/blogs/315874新建用户tdsql,并解压hadoop软件:#地址修改hdfs 的地址。修改配置文件:(core-site.xml)<configuration> <property> <name>fs.defaultFS</name> <value>hdfs://1...
hdfs单节点安装配置参考:
#地址修改hdfs 的地址。
<configuration>
    <property>
        <value>hdfs://192.168.5.200:9000</value>
    </property>
</configuration>
#测试是否可以正常访问
查看目录:
[tdsql@db02 hadoop-3.3.0]$ ./bin/hdfs dfs -ls /
Found 1 items
drwxrwxrwx   - hadoop supergroup          0 2021-12-14 11:13 /test
#上传文件测试
[hadoop@db01 hadoop-3.3.0]$ ./bin/hdfs dfs -mkdir /tdsql
[hadoop@db01 hadoop-3.3.0]$ ./bin/hdfs dfs -chown tdsql:tdsql /tdsql
[hadoop@db01 hadoop-3.3.0]$ ./bin/hdfs dfs -ls /
##上次文件
[tdsql@db02 hadoop-3.3.0]$ ./bin/hdfs dfs -ls /tdsql
[tdsql@db02 hadoop-3.3.0]$ ./bin/hdfs dfs -put README.txt /tdsql
Found 1 items
-rw-r--r--   3 tdsql tdsql        175 2021-12-14 11:20 /tdsql/README.txt
手动指定fs地址:
-fs <file:///|hdfs://namenode:port> specify default filesystem URL to use, overrides 'fs.defaultFS' property from configurations.
[tdsql@db02 hadoop-3.3.0]$  ./bin/hdfs dfs -fs hdfs://192.168.5.200:9000 -ls /
Found 2 items
drwxr-xr-x   - tdsql  tdsql               0 2021-12-14 11:20 /tdsql
