OceanBase 集群故障测试-模拟节点故障
snowofsummer 发表于 2021/12/11 09:43:14 2021/12/11
【摘要】 1,系统信息sys租户副本信息:为2分布在zone1,zone.sys租户副本数量为2:MySQL [oceanbase]> select * from __all_tenant where tenant_id=1\G;*************************** 1. row *************************** gmt_crea...
1,系统信息
sys租户副本数量为2:
                 gmt_create: 2021-12-07 16:42:12.523525
               gmt_modified: 2021-12-07 16:42:12.523525
                  tenant_id: 1
                tenant_name: sys
                replica_num: -1
                  zone_list: zone1;zone2
               primary_zone: zone1;zone2
                     locked: 0
             collation_type: 0
                       info: system tenant
                  read_only: 0
      rewrite_merge_version: 0
                   locality: FULL{1}@zone1, FULL{1}@zone2
        logonly_replica_num: 0
          previous_locality:
     storage_format_version: 0
storage_format_work_version: 0
      default_tablegroup_id: -1
         compatibility_mode: 0
           drop_tenant_time: -1
                     status: TENANT_STATUS_NORMAL
              in_recyclebin: 0
1 row in set (0.001 sec)
ERROR: No query specified
2,observer信息
集群信息(1-1-1)
zone1    192.168.5.200    2881    2882
zone1    192.168.5.200    3881    3882
zone1    192.168.5.200    4881    4882
MySQL [oceanbase]> select * from __all_server;
| gmt_create                 | gmt_modified               | svr_ip        | svr_port | id | zone  | inner_port | with_rootserver | status | block_migrate_in_time | build_version                                                          | stop_time | start_service_time | first_sessid | with_partition | last_offline_time |
| 2021-12-07 15:52:36.583969 | 2021-12-07 15:52:48.009135 | 192.168.5.200 |     2882 |  1 | zone1 |       2881 |               1 | active |                     0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |   1638863566011754 |            0 |              1 |                 0 |
| 2021-12-07 15:56:07.681043 | 2021-12-07 16:17:55.557006 | 192.168.5.200 |     3882 |  2 | zone2 |       3881 |               0 | active |                     0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |   1638863788395674 |            0 |              1 |                 0 |
| 2021-12-07 15:56:11.908905 | 2021-12-07 16:24:29.110670 | 192.168.5.200 |     4882 |  3 | zone3 |       4881 |               0 | active |                     0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |   1638863789811151 |            0 |              1 |                 0 |
3 rows in set (0.002 sec)
3,故障模拟:2个节点kill
对外不能提供服务,只有zone1,zone2正常才能正常提供服务。
3.1 kill  zone2,zone2
[admin@db01 ~]$ ps -ef|grep observer |grep -v grep
admin      727     1 99 02:52 ?        20:43:00 /home/admin/oceanbase/bin/observer -r 192.168.5.200:2882:2881 -o __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10 -z zone1 -p 2881 -P 2882 -c 1 -d /data/observer01/store -i ens192 -l INFO
admin     1559     1 99 02:55 ?        19:04:39 /home/admin/oceanbase/bin/observer -r 192.168.5.200:3882:3881 -o __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10 -z zone2 -p 3881 -P 3882 -c 1 -d /data/observer02/store -i ens192 -l INFO
admin     2141     1 80 02:55 ?        13:37:51 /home/admin/oceanbase/bin/observer -r 192.168.5.200:4882:4881 -o __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10 -z zone3 -p 4881 -P 4882 -c 1 -d /data/observer03/store -i ens192 -l INFO
[admin@db01 ~]$ kill -9 1559 2141
admin      727     1 99 02:52 ?        20:43:22 /home/admin/oceanbase/bin/observer -r 192.168.5.200:2882:2881 -o __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10 -z zone1 -p 2881 -P 2882 -c 1 -d /data/observer01/store -i ens192 -l INFO
[admin@db01 ~]$
3.2,登陆数据库,发现系统已经不能正常提供服务
3.3,启动zone2
[admin@db01 ~]$ cd /data/observer02/ && /home/admin/oceanbase/bin/observer -r "192.168.5.200:2882:2881;192.168.5.200:3882:3881;192.168.5.200:4882:4881" -o __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10 -z zone2 -p 3881 -P 3882 -c 1 -d /data/observer02/store -i ens192 -l INFO
/home/admin/oceanbase/bin/observer -r 192.168.5.200:2882:2881;192.168.5.200:3882:3881;192.168.5.200:4882:4881 -o __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10 -z zone2 -p 3881 -P 3882 -c 1 -d /data/observer02/store -i ens192 -l INFO
rs list: 192.168.5.200:2882:2881;192.168.5.200:3882:3881;192.168.5.200:4882:4881
optstr: __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10
zone: zone2
mysql port: 3881
rpc port: 3882
cluster id: 1
data_dir: /data/observer02/store
devname: ens192
log level: INFO
[admin@db01 observer02]$
[admin@db01 observer02]$ ps -ef|grep obs|grep -v grep
admin      727     1 99 02:52 ?        20:47:35 /home/admin/oceanbase/bin/observer -r 192.168.5.200:2882:2881 -o __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10 -z zone1 -p 2881 -P 2882 -c 1 -d /data/observer01/store -i ens192 -l INFO
admin    11948     1 99 19:56 ?        00:00:16 /home/admin/oceanbase/bin/observer -r 192.168.5.200:2882:2881;192.168.5.200:3882:3881;192.168.5.200:4882:4881 -o __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10 -z zone2 -p 3881 -P 3882 -c 1 -d /data/observer02/store -i ens192 -l INFO
3.4,查询系统表,发现正常提供服务
[admin@db01 ~]$ sh c.sh
Enter password:
Welcome to the OceanBase.  Commands end with ; or \g.
Your MySQL connection id is 3221567989
Server version: 5.7.25 OceanBase 3.1.1 (r4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e) (Built Oct 21 2021 10:33:14)
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
ERROR 4012 (HY000): Timeout
| gmt_create                 | gmt_modified               | svr_ip        | svr_port | id | zone  | inner_port | with_rootserver | status   | blo        ck_migrate_in_time | build_version                                                          | stop_time | start_service_time | first_sessid | wit        h_partition | last_offline_time |
| 2021-12-07 15:56:07.681043 | 2021-12-08 08:52:52.289833 | 192.168.5.200 |     3882 |  2 | zone2 |       3881 |               0 | inactive |        0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |                  0 |            0 |        1 |                 0 |
3 rows in set (3.090 sec)
| 2021-12-07 15:52:36.583969 | 2021-12-08 08:57:05.281970 | 192.168.5.200 |     2882 |  1 | zone1 |       2881 |               1 | active   |        0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |   1638863566011754 |            0 |        1 |                 0 |
| 2021-12-07 15:56:07.681043 | 2021-12-08 08:57:11.281488 | 192.168.5.200 |     3882 |  2 | zone2 |       3881 |               0 | active   |        0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |   1638925030293827 |            0 |        1 |                 0 |
| 2021-12-07 15:56:11.908905 | 2021-12-08 08:57:05.278698 | 192.168.5.200 |     4882 |  3 | zone3 |       4881 |               0 | inactive |        0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |   1638863789811151 |            0 |        1 |                 0 |
3 rows in set (0.001 sec)
3 rows in set (0.000 sec)
MySQL [oceanbase]>[admin@db01 ~]$ sh c.sh
Enter password:
MySQL [oceanbase]>
#状态截图:
4,故障模拟:kill zone2
4.1检查租户副本信息
sys租户副本分布在:locality: FULL{1}@zone1, FULL{1}@zone2
                  tenant_id: 1
                tenant_name: sys
                replica_num: -1
                     locked: 0
             collation_type: 0
                       info: system tenant
                  read_only: 0
          previous_locality:
              in_recyclebin: 0
4.2,模拟zone2故障
4.3,故障现在,不能正常对外提供服务
4.4 启动zone2
[admin@db01 observer03]$
[admin@db01 observer03]$ cd /data/observer02/ && /home/admin/oceanbase/bin/observer -r "192.168.5.200:2882:2881;192.168.5.200:3882:3881;192.168.5.200:4882:4881" -o __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10 -z zone2 -p 3881 -P 3882 -c 1 -d /data/observer02/store -i ens192 -l INFO
zone: zone2
mysql port: 3881
rpc port: 3882
cluster id: 1
devname: ens192
log level: INFO
[admin@db01 observer02]$ ps -ef|grep 3882
admin    15281     1 99 20:25 ?        00:07:57 /home/admin/oceanbase/bin/observer -r 192.168.5.200:2882:2881;192.168.5.200:3882:3881;192.168.5.200:4882:4881 -o __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10 -z zone2 -p 3881 -P 3882 -c 1 -d /data/observer02/store -i ens192 -l INFO
admin    16343 14059  0 20:32 pts/3    00:00:00 grep --color=auto 3882
4.4查看服务状态
zone2 的observer2启动之后,可以正常查询。
ERROR 4012 (25000): Statement is timeout
| 2021-12-07 15:52:36.583969 | 2021-12-08 09:26:07.204402 | 192.168.5.200 |     2882 |  1 | zone1 |       2881 |               1 | active |                     0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |   1638863566011754 |            0 |              1 |                 0 |
| 2021-12-07 15:56:07.681043 | 2021-12-08 09:26:07.207814 | 192.168.5.200 |     3882 |  2 | zone2 |       3881 |               0 | active |                     0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |                  0 |            0 |              1 |                 0 |
| 2021-12-07 15:56:11.908905 | 2021-12-08 09:26:07.208028 | 192.168.5.200 |     4882 |  3 | zone3 |       4881 |               0 | active |                     0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |   1638926371893289 |            0 |              1 |                 0 |
5,故障模拟:kill zone3
对外正常提供服务。
5.1检查server状态
| 2021-12-07 15:56:07.681043 | 2021-12-08 09:26:15.207936 | 192.168.5.200 |     3882 |  2 | zone2 |       3881 |               0 | active |                     0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |   1638926774220189 |            0 |              1 |                 0 |
5.2 模拟zone3 故障
[admin@db01 observer02]$ ps -ef|grep '\-P 4882'|grep -v grep
admin    14080     1 90 20:17 ?        00:19:29 /home/admin/oceanbase/bin/observer -r 192.168.5.200:4882:4881 -o __min_full_resource_pool_memory=268435456,memory_limit=8G,system_memory=4G,stack_size=512K,cpu_count=16,cache_wash_threshold=1G,workers_per_cpu_quota=10,schema_history_expire_time=1d,net_thread_count=4,sys_bkgd_migration_retry_num=3,minor_freeze_times=10,enable_separate_sys_clog=0,enable_merge_by_turn=False,datafile_size=50G,enable_syslog_recycle=True,max_syslog_file_count=10 -z zone3 -p 4881 -P 4882 -c 1 -d /data/observer03/store -i ens192 -l INFO
[admin@db01 observer02]$ kill -9 14080
5.3 查询系统表
数据库状态正常,对外正常提供服务
| 2021-12-07 15:56:11.908905 | 2021-12-08 09:39:00.647693 | 192.168.5.200 |     4882 |  3 | zone3 |       4881 |               0 | inactive |                     0 | 3.1.1_4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e(Oct 21 2021 10:33:14) |         0 |                  0 |            0 |              1 |                 0 |
