《PyTorch深度学习实践》-泰坦尼克号作业
淼 发表于 2021/12/10 15:13:29 2021/12/10
【摘要】 试着做了一下泰坦尼克号的练习,如有不足不对之处还望轻喷。1.准备数据集import numpy as np import pandas as pd from torch.utils.data import Datasetimport torchclass MyDataset(Dataset):’‘’定义数据集类‘’‘    def __init__(self,filepath):      ...
1.准备数据集
import numpy as np
import pandas as pd
import torch
’‘’定义数据集类‘’‘
        # 从原始数据集中取五个特征
        features = ["Pclass", "Sex", "SibSp", "Parch", "Fare"]
        data = pd.read_csv(filepath)
        self.len = data.shape[0]  # shape(多少行,多少列)
        # data[features]的类型是DataFrame,先进行独热表示,然后转成array,最后转成tensor用于进行矩阵计算。
        self.x_data = torch.from_numpy(np.array(pd.get_dummies(data[features])))
        self.y_data = torch.from_numpy(np.array(data["Survived"]))
    def __getitem__(self, index):
        return self.x_data[index], self.y_data[index]
    def __len__(self):
        return self.len
# 建立数据集
dataset = MyDataset('./titanic/train.csv')
# 建立数据集加载器
from torch.utils.data import DataLoader
train_loader = DataLoader(dataset=dataset, batch_size=1, shuffle=True, num_workers=0)
2.定义模型
class Model(torch.nn.Module):
    def __init__(self):
        super(Model, self).__init__()
        # 选取的五个特征经过独热表示后变为6维。
        self.linear1 = torch.nn.Linear(6, 3)
        self.linear2 = torch.nn.Linear(3, 1)
        self.sigmoid = torch.nn.Sigmoid()
    def forward(self, x):
        x = self.sigmoid(self.linear1(x))
        x = self.sigmoid(self.linear2(x))
        return x
    # 定义的预测函数。
    def predict(self, x):
        with torch.no_grad():
            y = []
            for i in x:
                if i>0.5:
                    y.append(1)
                else:
                    y.append(0)
            return y
model = Model()
3.构造损失函数、优化器
criterion = torch.nn.BCELoss(reduction='mean')
optimizer = torch.optim.SGD(model.parameters(), lr=0.005)
4.进行训练
if __name__ == '__main__':
    for epoch in range(100):
        for i, data in enumerate(train_loader, 0):
            inputs, labels = data
            # 这里先转换了一下数据类型。
            inputs = inputs.float()
            labels = labels.float()
            y_pred = model(inputs)
            # 将维度压缩至1维。
            y_pred = y_pred.squeeze(-1)
            loss = criterion(y_pred, labels)
            print(epoch, i, loss.item())
            optimizer.zero_grad()
            loss.backward()
            optimizer.step()
5.进行预测保存。
# 读取test文件
test_data = pd.read_csv("./titanic/test.csv")
test = torch.from_numpy(np.array(pd.get_dummies(test_data[features])))
# 进行预测
y = model.predict(test.float())
# 输出预测结果到文件
output = pd.DataFrame({'PassengerId': test_data.PassengerId, 'Survived': y})
output.to_csv('my_predict.csv', index=False)
最后提交结果,分值0.75837 可以继续调参优化。
第一次写文章,更多是想对自己的学习的一个记录,代码中肯定有很多不规范,或者更漂亮的写法,欢迎各位大佬点评指正。
版权声明:本文为CSDN博主「不废江流」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/weixin_42320758/article/details/113930316
