yii(curd)接口开发
陈业贵 发表于 2021/12/10 10:33:52 2021/12/10
【摘要】 简单的接口开发
第一步:在这里插入图片描述
理解这里的意思.
第二步:
写自己的域名.
比如http://www.demonstration.com.(本地地址的哈)。
在nginx里面新建一个文件demonstration.php(直接复制粘贴)
server {
    listen 80;
    charset utf-8;
    server_name www.demonstration.com;
    access_log C:/Wnmp/logs/demonstration_access.log;
    set  $webroot C:/Wnmp/html/demonstration/frontend;
     root $webroot/web;
    index index.php index.html index.htm;
    location / {
        try_files $uri $uri/ /index.php?$args;
    location ~ \.php$ {
		try_files  $uri =404;
		fastcgi_pass   php_processes;
		fastcgi_index  index.php;
		fastcgi_param  SCRIPT_FILENAME    $document_root$fastcgi_script_name;
		include        fastcgi_params;
    location ~ ^/(js|css|images|image|files)/ {
		root $webroot;
		expires 1h;
		log_not_found off;
		access_log off;
    location ~ ^/(attachments)/ {
        root $webroot;
		expires 1h;
		log_not_found off;
		access_log off;
    location ~ /\.(ht|svn|git) {
        deny all;
第三步:
在frontend/config/新建一个路由文件.名字为(rules.php)复制粘贴.
<?php
 * Created by PhpStorm.
 * User: Chan
 * Date: 2018/6/8
 * Time: 14:14
use yii\rest\UrlRule;
return [
        'class'=>UrlRule::class,
        'controller'=>'navigation',
        'extraPatterns' =>[
            'form'=>'form',
第四步:在frontend/controllers里面新建一个文件.NavigationController.php
<?php
namespace frontend\controllers;
use common\models\Form;
class NavigationController extends Controller
//增加
   public function actionForm()
        $form=new Form();
        $datetime = new \DateTime;
        $request = \Yii::$app->request;
        $form->name = $request->post("name");
        $form->phone= $request->post("phone");
        $form->address = $request->post("address");
        $form->time =$datetime->format('Y-m-d H:i:s');
        if($form->save())
            return $this->data(['form'=>$form],"保存成功",0);
        else
            return $this->error("保存失败");
    }//查询
   public  function actionIndex()
        $gets = \Yii::$app->db->createCommand('SELECT * FROM form')
            ->queryAll();
        if($gets)
            return $this->data($gets,"查询成功",0);
        else
            return $this->error("查询失败");
    }//删除
    public  function actionDelete($id)
        $form = Form::findOne([ 'id' => $id ]);
        if($form==null)
            return $this->error('抱歉,这条数据在数据表是里面是没有的,不能删除!');
        if($form->delete())
            return $this->msg("删除成功");
        else
            return $this->error("数据不存在或已经删除!");
    }//更新
  public function actionUpdate($id)
  {//前端的数据
      //第一步:先链接数据库看看表里有没有这条数据
      $id1= \Yii::$app->db->createCommand("SELECT * FROM form where id=$id")->queryOne();
      if(!$id1)
          return $this->error("抱歉,这条数据在数据表是里面是没有不能更新!");
      //第二步,数据表里面有这条数据怎么进行二次更新也能行,重复更新也能行
      else
      {$datetime = new \DateTime;
      $name = $request->getBodyParam("name");
      $phone= $request->getBodyParam("phone");
      $address = $request->getBodyParam("address");
      $time =$datetime->format('Y-m-d H:i:s');
      //自己数据库里面的数据
     $result= \Yii::$app->db->createCommand()->update("{{%form}}",[
            'name'=>$name,
            'phone'=>$phone,
          "address"=>$address,
          "time"=>$time,
          'id'=>$id
      ],['id'=>$id])->execute();
          return $this->msg("更新成功");
mysql表结构:
第五步:
自动生成一个form.php在commom/model/文件下.
怎么运行呢?增加
查询:
删除;
更新:
postman里面的数据
核心在于:
创建需要放数据,查询不用。更新用。删除不用.(因为删除是删除数据库中的某一条数据).
更新是必须数据库里面有的才能更新!!!
