OceanBase 快速上手
snowofsummer 发表于 2021/12/04 09:05:05 2021/12/04
【摘要】 本文介绍通过OBD,自动化部署工具部署单节点OceanBase 数据库。#操作系统版本[root@db01 ~]# cat /etc/redhat-release CentOS Linux release 7.5.1804 (Core) 1,软件下载,配置第三方yum,安装OBD工具sudo yum install -y yum-utilssudo yum-config-manager --...
#操作系统版本
sudo yum-config-manager --add-repo https://mirrors.aliyun.com/oceanbase/OceanBase.repo
sudo yum install -y ob-deploy
2,编译配置文件
#模板地址:
https://github.com/oceanbase/obdeploy/blob/master/example/autodeploy/single-example.yaml
#参考模板:
## Only need to configure when remote login is required
# user:
#   username: your username
#   password: your password if need
#   key_file: your ssh-key file path if need
#   port: your ssh port, default 22
#   timeout: ssh connection timeout (second), default 30
oceanbase-ce:
  servers:
    # Please don't use hostname, only IP can be supported
    - 127.0.0.1
  global:
    #  The working directory for OceanBase Database. OceanBase Database is started under this directory. This is a required field.
    home_path: /home/admin/oceanbase-ce
    # The directory for data storage. The default value is $home_path/store.
    # data_dir: /data/1
    # The directory for clog, ilog, and slog. The default value is the same as the data_dir value.
    redo_dir: /data/log1
    # Please set devname as the network adaptor's name whose ip is  in the setting of severs.
    # if set severs as "127.0.0.1", please set devname as "lo"
    # if current ip is 192.168.1.10, and the ip's network adaptor's name is "eth0", please use "eth0"
    devname: lo
    mysql_port: 2881 # External port for OceanBase Database. The default value is 2881.
    rpc_port: 2882 # Internal port for OceanBase Database. The default value is 2882.
    zone: zone1
    cluster_id: 1
    # please set memory limit to a suitable value which is matching resource.
    memory_limit: 8G # The maximum running memory for an observer
    system_memory: 4G # The reserved system memory. system_memory is reserved for general tenants. The default value is 30G.
    stack_size: 512K
    cpu_count: 16
    cache_wash_threshold: 1G
    __min_full_resource_pool_memory: 268435456
    workers_per_cpu_quota: 10
    schema_history_expire_time: 1d
    # The value of net_thread_count had better be same as cpu's core number.
    net_thread_count: 4
    major_freeze_duty_time: Disable
    minor_freeze_times: 10
    enable_separate_sys_clog: 0
    enable_merge_by_turn: FALSE
    #datafile_disk_percentage: 20 # The percentage of the data_dir space to the total disk space. This value takes effect only when datafile_size is 0. The default value is 90.
    datafile_size: 5G
    syslog_level: ERROR # System log level. The default value is INFO.
    enable_syslog_wf: false # Print system logs whose levels are higher than WARNING to a separate log file. The default value is true.
    enable_syslog_recycle: true # Enable auto system log recycling or not. The default value is false.
    max_syslog_file_count: 4 # The maximum number of reserved log files before enabling auto recycling. The default value is 0.
    # observer cluster name, consistent with obproxy's cluster_name
    appname: obce-single
    root_password: rootPWD123 # root user password, can be empty
    proxyro_password:  proxyROPWD123 # proxyro user pasword, consistent with obproxy's observer_sys_password, can be empty
3,运行自动部署:
#需要设置系统参数
[root@db01 ~]# tail -5 /etc/security/limits.conf
#@student        -       maxlogins       4
# End of file
*		soft	nofile		99999
*		hard	nofile		99999
部署失败日志:
[root@db01 ~]# obd cluster autodeploy  test -c c.conf
Update OceanBase-community-stable-el7 ok
Update OceanBase-development-kit-el7 ok
Download oceanbase-ce-3.1.1-4.el7.x86_64.rpm (46.21 M): 100% [###################################################################################################################################################] Time: 0:00:12   3.94 MB/s
Package oceanbase-ce-3.1.1 is available.
install oceanbase-ce-3.1.1 for local ok
Cluster param config check ok
Open ssh connection ok
Generate observer configuration ok
oceanbase-ce-3.1.1 already installed.
|                                   Packages                                  |
| Repository   | Version | Release | Md5                                      |
| oceanbase-ce | 3.1.1   | 4.el7   | f19f8bfb67723712175fb0dfd60579196b3168f1 |
Repository integrity check ok
Parameter check ok
Remote oceanbase-ce-3.1.1-f19f8bfb67723712175fb0dfd60579196b3168f1 repository install ok
Remote oceanbase-ce-3.1.1-f19f8bfb67723712175fb0dfd60579196b3168f1 repository lib check !!
[WARN] 127.0.0.1 oceanbase-ce-3.1.1-f19f8bfb67723712175fb0dfd60579196b3168f1 require: libmariadb.so.3
Try to get lib-repository
Download oceanbase-ce-libs-3.1.1-4.el7.x86_64.rpm (155.15 K): 100% [#############################################################################################################################################] Time: 0:00:00 209.30 kB/s
Package oceanbase-ce-libs-3.1.1 is available.
install oceanbase-ce-libs-3.1.1 for local ok
Use oceanbase-ce-libs-3.1.1-58384f7ab4ee736e9d530f4bdd63c20ced0e7aba for oceanbase-ce-3.1.1-f19f8bfb67723712175fb0dfd60579196b3168f1
Remote oceanbase-ce-libs-3.1.1-58384f7ab4ee736e9d530f4bdd63c20ced0e7aba repository install ok
Remote oceanbase-ce-3.1.1-f19f8bfb67723712175fb0dfd60579196b3168f1 repository lib check ok
Cluster status check ok
Initializes observer work home ok
test deployed
Get local repositories and plugins ok
Check before start observer x
[WARN] (127.0.0.1) The recommended value of fs.aio-max-nr is 1048576 (Current value: 65536)
[ERROR] (127.0.0.1) open files number must not be less than 20000 (Current value: 1024)
#运行自动部署:
|                                   Packages                                  |
Parameter check ok
test deployed
Check before start observer ok
[WARN] (127.0.0.1) The recommended number of open files is 655350 (Current value: 99999)
Start observer ok
observer program health check ok
Connect to observer ok
Initialize cluster
Cluster bootstrap ok
Wait for observer init ok
|                   observer                  |
| ip        | version | port | zone  | status |
| 127.0.0.1 | 3.1.1   | 2881 | zone1 | active |
test running
#检查状态:
[root@db01 ~]# obd cluster display test
|                   observer                  |
4,安装客户端,并连接数据库
sudo yum install -y obclient
连接数据库:
[root@db01 ~]# obclient -h127.0.0.1 -P 2881 -uroot -prootPWD123
Welcome to the OceanBase.  Commands end with ; or \g.
Your MySQL connection id is 3221487723
Server version: 5.7.25 OceanBase 3.1.1 (r4-8c615943cbd25a6f7b8bdfd8677a13a21709a05e) (Built Oct 21 2021 10:33:14)
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MySQL [(none)]>
MySQL [(none)]> show databases;
| Database           |
| oceanbase          |
| information_schema |
| mysql              |
| SYS                |
| LBACSYS            |
| ORAAUDITOR         |
| test               |
7 rows in set (0.004 sec)
MySQL [(none)]>
