基于证书的sqlserver镜像搭建
LD的SQL路 发表于 2021/12/03 15:21:09 2021/12/03
【摘要】 Sqlserver数据库镜像的搭建步骤0、首先在hosts文件中添加IP映射(主库和镜像库上都添加)192.168.3.13  node1192.168.3.10  node21、创建主密钥(主库和镜像库上都执行)use mastergocreate master key encryption by password='$a123456'go2、创建主库和镜像库的证书(分别在主库和镜像库上执...
Sqlserver数据库镜像的搭建步骤
192.168.3.13  node1
192.168.3.10  node2
1、创建主密钥(主库和镜像库上都执行)
use master
go
go
2、创建主库和镜像库的证书(分别在主库和镜像库上执行)
主库上执行:
use master
go
create certificate mirror01_cert with subject='mirror01 certificate',expiry_date='2099-1-1'
go
镜像库上执行:
use master
go
create certificate mirror02_cert with subject='mirror02 certificate',expiry_date='2099-1-1'
go
3、创建主库和镜像库的端点
主库上执行:
use master
go
create endpoint Endpoint_Mirroring
state=started
as tcp ( listener_port = 5022,listener_ip = all )
for database_mirroring ( authentication = certificate mirror01_cert, encryption = required algorithm aes, role = all )
go
镜像库上执行:
use master
go
state=started
for database_mirroring ( authentication = certificate mirror02_cert, encryption = required algorithm aes, role = all )
go
4、备份证书(主库和镜像的库的都备份,并互相拷贝过去,保证每个服务器上都有2个证书)
主库上执行:
use master
go
backup certificate mirror01_cert to file = 'D:\cert\mirror01_cert.cer'
go
镜像库上执行:
use master
go
backup certificate mirror02_cert to file = 'D:\cert\mirror02_cert.cer'
go
5、创建登录名(这个要和证书关联,所以1创建2的,2创建1的)
主库上执行:
use master
go
create login mirror02_login with password='abc@123456'
go
镜像库上执行:
use master
go
create login mirror01_login with password='abc@123456'
go
6、创建使用该登录名的用户
主库上执行:
use master
go
create user mirror02_user for login mirror02_login
go
镜像库上执行:
use master
go
create user mirror01_user for login mirror01_login
go
7、证书与用户关联
主库上执行:
use master
go
authorization mirror02_user
from file='D:\cert\mirror02_cert.cer'
go
镜像库上执行:
use master
go
authorization mirror01_user
from file='D:\cert\mirror01_cert.cer'
go
8、授予对远程数据库端点的登录名的CONNECT权限
命令:
主库上执行:
use master
go
GRANT CONNECT ON ENDPOINT::Endpoint_Mirroring TO [mirror02_login];
go
镜像库上执行:
use master
go
GRANT CONNECT ON ENDPOINT::Endpoint_Mirroring TO [mirror01_login];
go
9、对需要做镜像的数据库做完整备份和事务日志备份,
1.完整备份
BACKUP DATABASE [test] TO  DISK = N'D:\bak\test.bak' WITH NOFORMAT, INIT,  NAME = N'test-完整 数据库 备份', SKIP, NOREWIND, NOUNLOAD, COMPRESSION,  STATS = 10
GO
declare @backupSetId as int
select @backupSetId = position from msdb..backupset where database_name=N'test' and backup_set_id=(select max(backup_set_id) from msdb..backupset where database_name=N'test' )
if @backupSetId is null begin raiserror(N'验证失败。找不到数据库“test”的备份信息。', 16, 1) end
RESTORE VERIFYONLY FROM  DISK = N'D:\bak\test.bak' WITH  FILE = @backupSetId,  NOUNLOAD,  NOREWIND
GO
2.事物日志备份
BACKUP LOG [test] TO  DISK = N'D:\bak\test_log.tran' WITH NOFORMAT, INIT,  NAME = N'test-完整 数据库 备份', SKIP, NOREWIND, NOUNLOAD, COMPRESSION,  STATS = 10
GO
RESTORE VERIFYONLY FROM  DISK = N'D:\bak\test_log.tran' WITH  FILE = @backupSetId,  NOUNLOAD,  NOREWIND
GO
10、把主库上的备份在镜像库上做还原(先还原完整备份,再还原事务日志),使用NORECOVERY模式
1.还原完整备份
USE [master]
RESTORE DATABASE [test] FROM  DISK = N'D:\bak\test.bak' WITH  FILE = 1,  NORECOVERY,  NOUNLOAD,  STATS = 5
GO
2.还原事物日志
RESTORE LOG [test] FROM  DISK = N'D:\bak\ test.tran' WITH  FILE = 1,  NORECOVERY,  NOUNLOAD,  STATS = 10
GO
注:同样的操作方式把其他库也备份一下
11、连接镜像(先在镜像库上操作,然后在主库上操作)
镜像库上执行:(做完这个操作后,数据库的状态:正在恢复)
use master
go
ALTER DATABASE test SET PARTNER = 'TCP://node1:5022';
go
主库上执行:(做完这个操作,镜像就搭建好了)
use master
go
ALTER DATABASE test SET PARTNER = 'TCP://node2:5022';
go
注:同样的操作方式把其他库弄一下即可
12、灾备切换方式
主库宕机后,只要在镜像库上执行如下2个SQL即可
第一步:脱离镜像
alter database test set partner off
第二步;修改数据库的状态为recovery
restore database test with recovery
