【愚公系列】2021年11月 C#版 数据结构与算法解析(映射)
愚公搬代码 发表于 2021/11/26 00:10:06 2021/11/26
【摘要】 using System;using System.Collections.Generic;using System.Linq;using System.Text;namespace Badao.Entity.Helper{ public class StepStateHelper { #region 单例实现 private static strin...
using System;
using System.Linq;
using System.Text;
        #region 单例实现
        private static string _lockFlag = "StepStateHelperLock";
        private static StepStateHelper _instance;
        private StepStateHelper()
        public static StepStateHelper Instance
            get
                lock(_lockFlag)
                    if (_instance == null)
                        _instance = new StepStateHelper();
                    return _instance;
        #endregion
        #region 字段定义
        private Dictionary<short, string> _dicStepStates = new Dictionary<short, string>()
            { 0x04, "霸道" },
            { 0x05, "流氓" },
            { 0x06, "气质" },
        #endregion
        #region 属性定义
        public Dictionary<short, string> DicStepStates
            get
                return _dicStepStates;
        #endregion
string StepState = "";
StepStateHelper.Instance.DicStepStates.TryGetValue((short)obj, out StepState);
以上就是基本类映射的实现
