Cyclic Nacklace HDU - 3746(字符串周期)
用户已注销 发表于 2021/11/19 06:34:45 2021/11/19
【摘要】 题目: Description CC always becomes very depressed at the end of this month, he has checked his credit card yesterday, without any surprise, there are only 9...
题目:
Description
CC always becomes very depressed at the end of this month, he has checked his credit card yesterday, without any surprise, there are only 99.9 yuan left. he is too distressed and thinking about how to tide over the last days. Being inspired by the entrepreneurial spirit of "HDU CakeMan", he wants to sell some little things to make money. Of course, this is not an easy task.
As Christmas is around the corner, Boys are busy in choosing christmas presents to send to their girlfriends. It is believed that chain bracelet is a good choice. However, Things are not always so simple, as is known to everyone, girl's fond of the colorful decoration to make bracelet appears vivid and lively, meanwhile they want to display their mature side as college students. after CC understands the girls demands, he intends to sell the chain bracelet called CharmBracelet. The CharmBracelet is made up with colorful pearls to show girls' lively, and the most important thing is that it must be connected by a cyclic chain which means the color of pearls are cyclic connected from the left to right. And the cyclic count must be more than one. If you connect the leftmost pearl and the rightmost pearl of such chain, you can make a CharmBracelet. Just like the pictrue below, this CharmBracelet's cycle is 9 and its cyclic count is 2:
Now CC has brought in some ordinary bracelet chains, he wants to buy minimum number of pearls to make CharmBracelets so that he can save more money. but when remaking the bracelet, he can only add color pearls to the left end and right end of the chain, that is to say, adding to the middle is forbidden.
CC is satisfied with his ideas and ask you for help.
Input
The first line of the input is a single integer T ( 0 < T <= 100 ) which means the number of test cases.
Each test case contains only one line describe the original ordinary chain to be remade. Each character in the string stands for one pearl and there are 26 kinds of pearls being described by 'a' ~'z' characters. The length of the string Len: ( 3 <= Len <= 100000 ).
Output
For each case, you are required to output the minimum count of pearls added to make a CharmBracelet.
Sample Input
  1. 3
  2. aaa
  3. abca
  4. abcde
Sample Output
  1. 0
  2. 2
  3. 5
题意:给一个字符串,求至少添加多少字符才能变成周期串。
字符串周期问题用简单的next数组即可,不用改进的next数组
代码:
  1. #include<iostream>
  2. #include<string.h>
  3. using namespace std;
  4. char c[100005];
  5. int next_[100005];
  6. int l;
  7. void get_next(char *t, int m, int next[])
  8. {
  9. int i = 1, j = 0;
  10. next[0]=next[1] = 0;
  11. while (i < m)
  12. {
  13. if (j == 0 || t[i] == t[j])next[++i] = ++j;
  14. else j = next[j];
  15. }
  16. }
  17. int main()
  18. {
  19. int t;
  20. cin >> t;
  21. gets(c + 1);
  22. while (t--)
  23. {
  24. gets(c + 1);
  25. l = strlen(c + 1);
  26. get_next(c, l, next_);
  27. int dif = l - next_[l];
  28. if (c[l] == c[next_[l]])cout << (dif - l%dif) % dif;
  29. else cout << l;
  30. cout << endl;
  31. }
  32. return 0;
  33. }
这个代码是AC的,不过却是错的
对于aabaaa这种字符串,上面的代码结果是6,实际上应该是2
于是新的代码如下:
  4. char c[100005];
  6. int l;
  8. {
  10. next[0] = next[1] = 0;
  11. while (i < m)
  12. {
  15. }
  16. }
  17. int main()
  18. {
  19. int t;
  20. cin >> t;
  21. gets(c + 1);
  22. while (t--)
  23. {
  24. gets(c + 1);
  27. int k = next_[l];
  28. while (k && c[l] != c[k])k = next_[k];
  29. int dif = l - k;
  30. cout << (dif - l % dif) % dif + (!k)*l << endl;
  31. }
  32. return 0;
  33. }
这个代码也是AC的,看来标程并没有问题,只是数据太水
文章来源: blog.csdn.net,作者:csuzhucong,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/nameofcsdn/article/details/52131848
