HDU 1089-1096 A+B for Input-Output Practice(IO系列)
用户已注销 发表于 2021/11/19 05:11:01 2021/11/19
【摘要】 题目: Description Your task is to Calculate a + b.  Too easy?! Of course! I specially designed the problem for acm beginners.  You must ...
题目:
Description
You must have found that some problems have the same titles with this one, yes, all these problems were designed for the same aim.
Input
The input will consist of a series of pairs of integers a and b, separated by a space, one pair of integers per line.
Output
For each pair of input integers a and b you should output the sum of a and b in one line, and with one line of output for each line in input.
Sample Input
1 5
10 20
Sample Output
6
30
代码:
#include<iostream>
using namespace std;
int main()
	int a, b;
	while (cin >> a >> b)cout << a + b << endl;
	return 0;
题目:
Description
Input
Input contains an integer N in the first line, and then N lines follow. Each line consists of a pair of integers a and b, separated by a space, one pair of integers per line.
Output
Sample Input
2
1 5
10 20
Sample Output
6
30
代码:
#include<iostream>
int main()
	int n, a, b;
	cin >> n;
	while (n--)
		cin >> a >> b;
	return 0;
题目:
Description
Input
Input contains multiple test cases. Each test case contains a pair of integers a and b, one pair of integers per line. A test case containing 0 0 terminates the input and this test case is not to be processed.
Output
Sample Input
1 5
10 20
0 0
Sample Output
6
30
代码:
#include<iostream>
int main()
	int a, b;
		if (a == 0 && b == 0)break;
	return 0;
题目:
Description
Your task is to Calculate the sum of some integers.
Input
Input contains multiple test cases. Each test case contains a integer N, and then N integers follow in the same line. A test case starting with 0 terminates the input and this test case is not to be processed.
Output
For each group of input integers you should output their sum in one line, and with one line of output for each line in input.
Sample Input
4 1 2 3 4
5 1 2 3 4 5
0
Sample Output
10
15
代码:
#include<iostream>
int main()
	int n, a, sum;
	while (cin >>n)
		if (n == 0)break;
		sum = 0;
		while (n--)
			cin >> a;
			sum += a;
		cout << sum << endl;
	return 0;
题目:
Description
Your task is to calculate the sum of some integers.
Input
Input contains an integer N in the first line, and then N lines follow. Each line starts with a integer M, and then M integers follow in the same line.
Output
Sample Input
2
4 1 2 3 4
5 1 2 3 4 5
Sample Output
10
15
代码:
#include<iostream>
int main()
	int t, n, a, sum;
	cin >> t;
	while (t--)
		cin >> n;
		sum = 0;
		while (n--)
			cin >> a;
			sum += a;
	return 0;
题目:
Description
Input
Input contains multiple test cases, and one case one line. Each case starts with an integer N, and then N integers follow in the same line.
Output
For each test case you should output the sum of N integers in one line, and with one line of output for each line in input.
Sample Input
4 1 2 3 4
5 1 2 3 4 5
Sample Output
10
15
代码:
#include<iostream>
int main()
	int n, a, sum;
	while (cin >> n)
		sum = 0;
		while (n--)
			cin >> a;
			sum += a;
	return 0;
题目:
Description
Input
Output
For each pair of input integers a and b you should output the sum of a and b, and followed by a blank line.
Sample Input
1 5
10 20
Sample Output
6
30
代码:
#include<iostream>
int main()
	int a, b;
	while (cin >> a >> b)cout << a + b << endl << endl;
	return 0;
题目:
Description
Input
Output
For each group of input integers you should output their sum in one line, and you must note that there is a blank line between outputs.
Sample Input
3
4 1 2 3 4
5 1 2 3 4 5
3 1 2 3
Sample Output
10
15
6
代码:
#include<iostream>
int main()
	int t, n, a, sum;
	cin >> t;
	while (t--)
		cin >> n;
		sum = 0;
		while (n--)
			cin >> a;
			sum += a;
		if (t)cout << endl;
	return 0;
文章来源: blog.csdn.net,作者:csuzhucong,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/nameofcsdn/article/details/52162676
