HDU 2586 How far away?(LCA使用详解)
用户已注销 发表于 2021/11/19 05:03:16 2021/11/19
【摘要】 题目: Description There are n houses in the village and some bidirectional roads connecting them. Every day peole always like to ask like this "How far is it if ...
题目:
Description
There are n houses in the village and some bidirectional roads connecting them. Every day peole always like to ask like this "How far is it if I want to go from house A to house B"? Usually it hard to answer. But luckily int this village the answer is always unique, since the roads are built in the way that there is a unique simple path("simple" means you can't visit a place twice) between every two houses. Yout task is to answer all these curious people.
Input
First line is a single integer T(T<=10), indicating the number of test cases.
  For each test case,in the first line there are two numbers n(2<=n<=40000) and m (1<=m<=200),the number of houses and the number of queries. The following n-1 lines each consisting three numbers i,j,k, separated bu a single space, meaning that there is a road connecting house i and house j,with length k(0<k<=40000).The houses are labeled from 1 to n.
  Next m lines each has distinct integers i and j, you areato answer the distance between house i and house j.
Output
For each test case,output m lines. Each line represents the answer of the query. Output a bland line after each test case.
Sample Input
2
3 2
1 2 10
3 1 15
1 2
2 3
2 2
1 2 100
1 2
2 1
Sample Output
10
25
100
100
题意:
n个房子用n-1条路连接起来(也就是一棵树),对于每一个询问,
求出2个房子直接的线路距离
思路:
这个题目只要建立一个树,然后查询任意2个点之间的距离,没有更新操作,所以可以用LCA来做。
LCA就是寻找最近公共祖先,这有什么用呢?
这是因为有一个性质,假设B和C的最近公共祖先是A,那么对于整个树的根节点D,
都有:|BD|+|CD|-|AD|*2=|BC|
也就是说,只要事先求出所有点到D的距离dist(dist的大小为n),
然后对于输入的B和C,只需要求出最近公共祖先,即可利用上式得到答案。
步骤:
1,存边
每次输入1条边,把2个点都存入对方的儿子列表中
因为儿子的数量未知,但是总数是2n-2,所以用向量数组v来存比较合适。(v的大小为n)
2,建树
建树的方法有很多,而且n个点都是可以用来当做根节点的。
这里我采用的是以第一个节点作为根节点,利用深度优先搜索建树
因为在计算dist之前需要找到根节点,所以需要1个数组fa记录父亲的标号(fa的大小为n)
3,深度优先搜索
既然有儿子列表,那么就可以深度优先搜索了。
利用深度优先,把树映射到一维数组,这是哈希的一种。
得到这个表有什么用呢?
也不知道是哪个神人想出来的,仅用这个表就可以得到最近公共祖先。
比如B的遍历数为3,C的遍历数为6,从3到6,深度依次为3 2 3 4,
最小的是2,对应的是A,所以A就是B和C的最近公共祖先。
注意,遍历数不一定是唯一的,比如求A和I的最近公共祖先,A有3个不同的遍历数,
但是不管选哪个,结果都是一样的。
所以说,只需要用动态规划的RMQ方法求出区间的最小值,即可求出公共祖先。
4,空间分析
首先,我们需要对每个点存1个遍历数,任选1个存起来即可。(visitn的大小为n)
然后,我们还需要把所有的遍历数对应的是哪个点存起来。
那么,一共有多少个遍历数呢?
规律很明显,总结如下:1个叶子节点只有1个遍历数,每个节点的遍历数等于出度加1
所以遍历数一共有:节点总数+出度总数=n+n-1(visitnum的大小为n+n-1)
(mins第一个维度的大小为n+n-1,第二个维度约为log2(n)+1)
上面的9个节点就有17个遍历数。
5,计算每个点到根节点的距离。
visit函数是一个递归调用的函数,用来实现深度优先搜索。
搜索的过程中,除了要计算visitn和visitnum,还要计算deep和dist(deep的大小为n)
(至此,7个数组的用途和大小都用蓝色粗体标注了)
deep和dist都可以利用递归的参数d和dis非常方便的计算出来。
6,RMQ
用RMQ求的是什么,这个倒是不要搞错了。
RMQ求的是visitnum数组的一段区间中,拥有最小deep的那个点对应的visitnum
而不是求deep的最小值,也不是求visitnum的最小值。
7,LCA
这个和RMQ对应,求的是visitnum数组的一段区间中,拥有最小deep的那个点对应的visitnum。
只需要根据visitnum便可知道到底哪个点是最近公共祖先
8,查询
输入x,y,取出他们的遍历数visitn,由此求出他们的最近公共祖先。
需要注意的是,因为遍历数有很多个,随便取一个存到visitn数组中,
那么x和y的遍历数谁大谁小就完全不知道了,需要判断。
代码:
  1. #include<iostream>
  2. #include<vector>
  3. using namespace std;
  4. struct node
  5. {
  6. int son;
  7. int distance;
  8. };
  9. int n;
  10. vector<node>v[40001];//存儿子标号
  11. int deep[40001];//每个点的深度
  12. int visitnum[80001];//遍历数是2*n-1
  13. int visitn[40001];//每个点的任意一个遍历数
  14. int vnum;
  15. int mins[80001][18]; //区间最小值
  16. int dist[40001]; //每个点到祖先的距离distance
  17. int fa[40001];
  18. void visit(int m, int d, int dis) //遍历重编号、计算distance
  19. {
  20. vector<node>::iterator p;
  21. deep[m] = d;
  22. dist[m] = dis;
  23. for (p = v[m].begin(); p != v[m].end(); p++)
  24. {
  25. if (fa[(*p).son]>-1)continue;
  26. fa[(*p).son] = m;
  27. visitnum[vnum++] = m; //存入访问的第vnum个点是哪个点
  28. visit((*p).son, d + 1, dis + (*p).distance);
  29. }
  30. visitn[m] = vnum; //注意这2句的顺序
  31. visitnum[vnum++] = m;
  32. }
  33. void rmq() //计算区间最小值
  34. {
  35. for (int i = 1; i <= 2 * n - 1; i++)mins[i][0] = visitnum[i];
  36. for (int j = 1; (1 << j) <= 2 * n - 1; j++)
  37. {
  38. for (int i = 1; i <= 2 * n - 1; i++)
  39. {
  40. mins[i][j] = mins[i][j - 1];
  41. int k = i + (1 << (j - 1));
  42. if (k <= 2 * n - 1 && deep[mins[i][j]] > deep[mins[k][j - 1]])
  43. mins[i][j] = mins[k][j - 1];
  44. }
  45. }
  46. }
  47. int lca(int x, int y) //求最近公共祖先
  48. {
  49. x = visitn[x], y = visitn[y];
  50. if (x > y)x ^= y ^= x ^= y;
  51. int j = 0;
  52. while ((1 << j) <= y - x + 1)j++;
  53. j--;
  54. int min = mins[y + 1 - (1 << j)][j];
  55. if (deep[min] > deep[mins[x][j]])min = mins[x][j];
  56. return min;
  57. }
  58. int main()
  59. {
  60. int t, m, x, y, l;
  61. cin >> t;
  62. while (t--)
  63. {
  64. cin >> n >> m;
  65. vnum = 1;
  66. for (int i = 1; i <= n; i++)
  67. {
  68. v[i].clear(); //初始化
  69. fa[i] = -1;
  70. }
  71. for (int i = 1; i < n; i++)
  72. {
  73. scanf("%d%d%d", &x, &y, &l);
  74. node nod1, nod2;
  75. nod1.distance = l, nod1.son = y;
  76. v[x].insert(v[x].end(), nod1);
  77. nod2.distance = l, nod2.son = x;
  78. v[y].insert(v[y].end(), nod2);
  79. }
  80. fa[1] = 1;
  81. visit(1, 1, 0);
  82. rmq();
  83. while (m--)
  84. {
  85. scanf("%d%d", &x, &y);
  86. printf("%d\n", dist[x] + dist[y] - dist[lca(x, y)] * 2);
  87. }
  88. }
  89. return 0;
  90. }
文章来源: blog.csdn.net,作者:csuzhucong,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/nameofcsdn/article/details/52230548
