CodeForces 706C Hard problem
用户已注销 发表于 2021/11/19 05:06:01 2021/11/19
【摘要】 题目:   Description Vasiliy is fond of solving different tasks. Today he found one he wasn't able to solve himself, so he asks you to help. Vasiliy is g...
题目:
Description
Vasiliy is given n strings consisting of lowercase English letters. He wants them to be sorted in lexicographical order (as in the dictionary), but he is not allowed to swap any of them. The only operation he is allowed to do is to reverse any of them (first character becomes last, second becomes one before last and so on).
To reverse the i-th string Vasiliy has to spent ci units of energy. He is interested in the minimum amount of energy he has to spent in order to have strings sorted in lexicographical order.
String A is lexicographically smaller than string B if it is shorter than B (|A| < |B|) and is its prefix, or if none of them is a prefix of the other and at the first position where they differ character in A is smaller than the character in B.
For the purpose of this problem, two equal strings nearby do not break the condition of sequence being sorted lexicographically.
Input
The first line of the input contains a single integer n (2 ≤ n ≤ 100 000) — the number of strings.
The second line contains n integers ci (0 ≤ ci ≤ 109), the i-th of them is equal to the amount of energy Vasiliy has to spent in order to reverse the i-th string.
Then follow n lines, each containing a string consisting of lowercase English letters. The total length of these strings doesn't exceed100 000.
Output
If it is impossible to reverse some of the strings such that they will be located in lexicographical order, print  - 1. Otherwise, print the minimum total amount of energy Vasiliy has to spent.
Sample Input
Input
  1. 2
  2. 1 2
  3. ba
  4. ac
Output
1
Input
  1. 3
  2. 1 3 1
  3. aa
  4. ba
  5. ac
Output
1
Input
  1. 2
  2. 5 5
  3. bbb
  4. aaa
Output
-1
Input
  1. 2
  2. 3 3
  3. aaa
  4. aa
Output
-1
代码:
  1. #include<iostream>
  2. #include<string>
  3. #include<cstring>
  4. using namespace std;
  5. int c[100000];
  6. bool ok(string s1,int k1, string s2,int k2)
  7. {
  8. string s3;
  9. int l1 = s1.length(), l2 = s2.length();
  10. if (k1)
  11. {
  12. s3 = s1;
  13. for (int i = 0; i < l1; i++)s1[i] = s3[l1 - i - 1];
  14. }
  15. if (k2)
  16. {
  17. s3 = s2;
  18. for (int i = 0; i < l2; i++)s2[i] = s3[l2 - i - 1];
  19. }
  20. int i = 0;
  21. while (i < l1 && i < l2)
  22. {
  23. if (s1[i] < s2[i])return true;
  24. if (s1[i] > s2[i])return false;
  25. i++;
  26. }
  27. if (l1 <= l2)return true;
  28. return false;
  29. }
  30. int main()
  31. {
  32. int n;
  33. long long sum1 = 0, sum2 = 0, t1, t2;
  34. scanf("%d", &n);
  35. for (int i = 0; i < n; i++)scanf("%d", &c[i]);
  36. string s1="", s2;
  37. for (int i = 0; i < n; i++)
  38. {
  39. cin >> s2;
  40. t1 = -1, t2 = -1;
  41. if (sum1 >= 0)
  42. {
  43. if (ok(&s1[0], 0, &s2[0], 0))t1 = sum1;
  44. if (ok(&s1[0], 0, &s2[0], 1))t2 = sum1 + c[i];
  45. }
  46. if (sum2 >= 0)
  47. {
  48. if (ok(&s1[0], 1, &s2[0], 0))
  49. if (t1<0 || t1>sum2)t1 = sum2;
  50. if (ok(&s1[0], 1, &s2[0], 1))
  51. if (t2<0 || t2>sum2 + c[i])t2 = sum2 + c[i];
  52. }
  53. sum1 = t1;
  54. sum2 = t2;
  55. s1 = s2;
  56. }
  57. if (sum1 < 0 && sum2 < 0)cout << -1;
  58. else if (sum1 < 0)cout << sum2;
  59. else if (sum2 < 0)cout << sum1;
  60. else cout << ((sum1 < sum2) ? sum1 : sum2);
  61. cout << endl;
  62. return 0;
  63. }
用了空间压缩,把一维数组压成了sum1、sum2、t1、t2这4个变量。
所以看起来动态规划的特征不是很明显,不过仔细想想,本质上还是动态规划。
文章来源: blog.csdn.net,作者:csuzhucong,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/nameofcsdn/article/details/52199737
