iOS 获取屏幕的朝向
福州司马懿 发表于 2021/11/19 06:56:58 2021/11/19
【摘要】 //检测屏幕朝向变化-(void)startDeviceOrientationChangeListener { [[UIDevice currentDevice] beginGeneratingDeviceOrientationNotifications]; [[NSNotificationCenter defaultCen...
  1. //检测屏幕朝向变化
  2. -(void)startDeviceOrientationChangeListener {
  3. [[UIDevice currentDevice] beginGeneratingDeviceOrientationNotifications];
  4. [[NSNotificationCenter defaultCenter] addObserver:self selector:@selector(deviceOrientationDidChange) name:UIDeviceOrientationDidChangeNotification object:nil];
  5. }
  6. -(void)deviceOrientationDidChange {
  7. /*
  8. typedef NS_ENUM(NSInteger, UIDeviceOrientation) {
  9. UIDeviceOrientationUnknown,
  10. UIDeviceOrientationPortrait, // Device oriented vertically, home button on the bottom
  11. UIDeviceOrientationPortraitUpsideDown, // Device oriented vertically, home button on the top
  12. UIDeviceOrientationLandscapeLeft, // Device oriented horizontally, home button on the right
  13. UIDeviceOrientationLandscapeRight, // Device oriented horizontally, home button on the left
  14. UIDeviceOrientationFaceUp, // Device oriented flat, face up
  15. UIDeviceOrientationFaceDown // Device oriented flat, face down
  16. };
  17. */
  18. UIDeviceOrientation orientation = [UIDevice currentDevice].orientation;
  19. NSMutableString *orientationDescription = [[NSMutableString alloc] initWithFormat:@"%ld ", orientation];
  20. switch (orientation) {
  21. case UIDeviceOrientationUnknown:
  22. [orientationDescription appendFormat:@"%@", @"UIDeviceOrientationUnknown"];
  23. break;
  24. case UIDeviceOrientationPortrait:
  25. [orientationDescription appendFormat:@"%@", @"UIDeviceOrientationPortrait"];
  26. break;
  27. case UIDeviceOrientationPortraitUpsideDown:
  28. [orientationDescription appendFormat:@"%@", @"UIDeviceOrientationPortraitUpsideDown"];
  29. break;
  30. case UIDeviceOrientationLandscapeLeft:
  31. [orientationDescription appendFormat:@"%@", @"UIDeviceOrientationLandscapeLeft"];
  32. break;
  33. case UIDeviceOrientationLandscapeRight:
  34. [orientationDescription appendFormat:@"%@", @"UIDeviceOrientationLandscapeRight"];
  35. break;
  36. case UIDeviceOrientationFaceUp:
  37. [orientationDescription appendFormat:@"%@", @"UIDeviceOrientationFaceUp"];
  38. break;
  39. case UIDeviceOrientationFaceDown:
  40. [orientationDescription appendFormat:@"%@", @"UIDeviceOrientationFaceDown"];
  41. break;
  42. }
  43. NSLog(@"%@", orientationDescription);
  44. }
我在模拟器上进行测试时发现:第一次会先打印“UIDeviceOrientationUnknown”,接着立马打印“UIDeviceOrientationPortrait”,间隔只有3毫秒左右(当时并没有改变设备方向)
2016-06-21 00:34:31.782 SensorDemo[599:15448] 0 UIDeviceOrientationUnknown
2016-06-21 00:34:31.785 SensorDemo[599:15448] 1 UIDeviceOrientationPortrait
文章来源: blog.csdn.net,作者:福州-司马懿,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/chy555chy/article/details/51724284
