iOS UIAlertController 警告框详解
福州司马懿 发表于 2021/11/19 04:11:42 2021/11/19
【摘要】 在Xcode的iOS8 SDK中,UIAlertView和UIActionSheet都被UIAlertController取代。官方库解释:“UIAlertView is deprecated. Use UIAlertController with a preferredStyle of UIAlertControllerStyleAl...
在Xcode的iOS8 SDK中,UIAlertView和UIActionSheet都被UIAlertController取代。官方库解释:“UIAlertView is deprecated. Use UIAlertController with a preferredStyle of UIAlertControllerStyleAlert instead.”、“UIActionSheet is deprecated. Use UIAlertController with a preferredStyle of UIAlertControllerStyleActionSheet instead.”。说明了在iOS8+开发,UIALertView和UIActionSheet已经过时了,UIAlertController以一种模块化替换的方式来代替这两这两个控件的功能和作用。如何创建及使用UIAlertController成为我们所关注的问题。
1、当前环境
Mac OS X EI Capitan
XCode 7.1 beta(7B60)
2、关键代码如下
  1. -(void)alterTextFieldDidChange:(NSNotification*)notification {
  2. UIAlertController *alertController = (UIAlertController*)self.presentedViewController;
  3. if(alertController) {
  4. UITextField *textfield = alertController.textFields[1];
  5. //添加限制,如果输入长度在5个字节以内,则不允许点击最后一个按钮
  6. UIAlertAction *action = alertController.actions.lastObject;
  7. action.enabled = textfield.text.length >=5;
  8. }
  9. }
  10. -(void)showAlertController {
  11. //UIAlertController有2种属性,UIAlertControllerStyleAlert和 UIAlertControllerStyleActionSheet(不能添加editfield)
  12. //(1)当样式为UIAlertControllerStyleAlert的时候,如果只有2个按钮并且"字一行够排"的话就水平排列,否则竖直排列
  13. //(2)cancel按钮固定在最下面,其他按钮按添加顺序排列
  14. UIAlertController *alertController = [UIAlertControlleralertControllerWithTitle:@"title"message:@"message"preferredStyle:UIAlertControllerStyleAlert];
  15. //UIAlertActionStyleCancel 该风格字体颜色为蓝色加粗
  16. UIAlertAction *UIAlertActionStyleCancelAction = [UIAlertActionactionWithTitle:@"UIAlertActionStyleCancel"style:UIAlertActionStyleCancelhandler:^(UIAlertAction *action) {
  17. NSLog(@"UIAlertActionStyleCancel");
  18. }];
  19. //UIAlertActionStyleDefault 该风格字体颜色为蓝色
  20. UIAlertAction *UIAlertActionStyleDefaultAction = [UIAlertActionactionWithTitle:@"UIAlertActionStyleDefault"style:UIAlertActionStyleDefaulthandler:^(UIAlertAction *action) {
  21. NSLog(@"UIAlertActionStyleDefault");
  22. }];
  23. //UIAlertActionStyleDestructive 该风格字体颜色红色(Destructive表示有破坏性的)
  24. UIAlertAction *UIAlertActionStyleDestructiveAction = [UIAlertActionactionWithTitle:@"UIAlertActionStyleDestructive"style:UIAlertActionStyleDestructivehandler:^(UIAlertAction *action) {
  25. NSLog(@"UIAlertActionStyleDestructive");
  26. }];
  27. [UIAlertActionStyleDestructiveAction setEnabled:NO];
  28. [alertController addAction:UIAlertActionStyleCancelAction];
  29. [alertController addAction:UIAlertActionStyleDestructiveAction];
  30. [alertController addAction:UIAlertActionStyleDefaultAction];
  31. //注意:需要添加textField的话,样式只能设为UIALertControllerStyleAlert
  32. [alertController addTextFieldWithConfigurationHandler:^(UITextField * textField) {
  33. textField.placeholder = @"用户名";
  34. }];
  35. [alertController addTextFieldWithConfigurationHandler:^(UITextField * textField) {
  36. textField.placeholder = @"密码";
  37. textField.secureTextEntry = YES;
  38. [[NSNotificationCenter defaultCenter] addObserver:selfselector:@selector(alterTextFieldDidChange:)name:UITextFieldTextDidChangeNotificationobject:textField];
  39. }];
  40. [selfpresentViewController:alertController animated:YEScompletion:nil];
  41. }
文章来源: blog.csdn.net,作者:福州-司马懿,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/chy555chy/article/details/51620689
