Android 通过广播监听USB连接状态的改变
福州司马懿 发表于 2021/11/19 04:57:09 2021/11/19
【摘要】 一、原理讲解       Android通过广播监听USB连接状态的改变的动作在UsbManager.java文件里,为ACTION_USB_...
一、原理讲解
      Android通过广播监听USB连接状态的改变的动作在UsbManager.java文件里,为ACTION_USB_STATE。然而在UsbManager中,该常量的注释中包含{@hide},该注释是控制该API是否开放用的。未开发的API意味着google可以随时调整该API的定义或实现方式,而不用保证向下兼容。
      所以尽量避免调用未开发的API,因为一旦系统升级导致其实现方式改变,程序很有可能就直接崩溃了。
注意:
  • 目前仍未发现 ACTION_USB_ACCESSORY_XXX 这种广播
  • 插拔手机与电脑之间的USB线:ACTION_USB_STATE(主要参数是 Boolean connected)
  • 插拔U盘发送的是OTG广播:ACTION_USB_DEVICE_XXX,XXX代表了ATTACH 或 DETACH,这种情况是手机是主,u盘是从,手机给U盘供电。
二、代码如下
1、MyUsbManager.java
package com.example.testapp;
public class MyUsbManager {
	 * Broadcast Action: A sticky broadcast for USB state change events when in device mode.
	 * This is a sticky broadcast for clients that includes USB connected/disconnected state,
	 * <ul>
	 * <li> {@link #USB_CONNECTED} boolean indicating whether USB is connected or disconnected.
	 * <li> {@link #USB_CONFIGURED} boolean indicating whether USB is configured. currently zero if not configured, one for configured.
	 * <li> {@link #USB_FUNCTION_ADB} boolean extra indicating whether the adb function is enabled
	 * <li> {@link #USB_FUNCTION_RNDIS} boolean extra indicating whether the RNDIS ethernet function is enabled
	 * <li> {@link #USB_FUNCTION_MTP} boolean extra indicating whether the MTP function is enabled
	 * <li> {@link #USB_FUNCTION_PTP} boolean extra indicating whether the PTP function is enabled
	 * <li> {@link #USB_FUNCTION_PTP} boolean extra indicating whether the accessory function is enabled
	 * <li> {@link #USB_FUNCTION_AUDIO_SOURCE} boolean extra indicating whether the audio source function is enabled
	 * <li> {@link #USB_FUNCTION_MIDI} boolean extra indicating whether the MIDI function is enabled
	 * </ul>
	public static final String ACTION_USB_STATE = "android.hardware.usb.action.USB_STATE";
	 * Boolean extra indicating whether USB is connected or disconnected.
	 * Used in extras for the {@link #ACTION_USB_STATE} broadcast.
	public static final String USB_CONNECTED = "connected";
	 * Boolean extra indicating whether USB is configured.
	public static final String USB_CONFIGURED = "configured";
	 * Boolean extra indicating whether confidential user data, such as photos, should be
	 * made available on the USB connection. This variable will only be set when the user
	 * has explicitly asked for this data to be unlocked.
	public static final String USB_DATA_UNLOCKED = "unlocked";
	 * A placeholder indicating that no USB function is being specified.
	 * Used to distinguish between selecting no function vs. the default function in {@link #setCurrentFunction(String)}.
	public static final String USB_FUNCTION_NONE = "none";
	 * Name of the adb USB function.
	public static final String USB_FUNCTION_ADB = "adb";
	 * Name of the RNDIS ethernet USB function.
	public static final String USB_FUNCTION_RNDIS = "rndis";
	 * Name of the MTP USB function.
	public static final String USB_FUNCTION_MTP = "mtp";
	 * Name of the PTP USB function.
	public static final String USB_FUNCTION_PTP = "ptp";
	 * Name of the audio source USB function.
	public static final String USB_FUNCTION_AUDIO_SOURCE = "audio_source";
	 * Name of the MIDI USB function.
	public static final String USB_FUNCTION_MIDI = "midi";
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
2、UsbActivity.java
import android.app.Activity;
import android.content.BroadcastReceiver;
import android.content.Context;
import android.content.Intent;
import android.content.IntentFilter;
import android.content.pm.PackageManager;
import android.hardware.usb.UsbAccessory;
import android.hardware.usb.UsbDevice;
import android.hardware.usb.UsbManager;
import android.os.Bundle;
import android.widget.LinearLayout;
import android.widget.ScrollView;
import android.widget.TextView;
public class UsbActivity extends Activity {
	private TextView textView;
	private UsbManager usbManager;
	private BroadcastReceiver receiver;
	private IntentFilter intentFilter;
	@Override
	protected void onCreate(Bundle savedInstanceState) {
		super.onCreate(savedInstanceState);
		ScrollView scrollView = new ScrollView(this);
		LinearLayout linearLayout = new LinearLayout(this);
		linearLayout.setOrientation(LinearLayout.VERTICAL);
		textView = new TextView(this);
		scrollView.addView(linearLayout);
		linearLayout.addView(textView);
		setContentView(scrollView);
		usbManager = (UsbManager) getSystemService(Context.USB_SERVICE);
		receiver = new BroadcastReceiver() {
			@Override
			public void onReceive(Context context, Intent intent) {
				String action = intent.getAction();
				addText("action : " + action);
				if(intent.hasExtra(UsbManager.EXTRA_PERMISSION_GRANTED)) {
					boolean permissionGranted = intent.getBooleanExtra(UsbManager.EXTRA_PERMISSION_GRANTED, false);
					addText("permissionGranted : " + permissionGranted);
				switch(action) {
				case UsbManager.ACTION_USB_ACCESSORY_ATTACHED:
				case UsbManager.ACTION_USB_ACCESSORY_DETACHED:
					//Name of extra for ACTION_USB_ACCESSORY_ATTACHED and ACTION_USB_ACCESSORY_DETACHED broadcasts containing the UsbAccessory object for the accessory.
					UsbAccessory accessory = intent.getParcelableExtra(UsbManager.EXTRA_ACCESSORY);
					addText(accessory.toString());
					break;
				case UsbManager.ACTION_USB_DEVICE_ATTACHED:
				case UsbManager.ACTION_USB_DEVICE_DETACHED:
					//Name of extra for ACTION_USB_DEVICE_ATTACHED and ACTION_USB_DEVICE_DETACHED broadcasts containing the UsbDevice object for the device.
					UsbDevice device = intent.getParcelableExtra(UsbManager.EXTRA_DEVICE);
					addText(device.toString());
					break;
				case MyUsbManager.ACTION_USB_STATE:
				     * currently zero if not configured, one for configured.
				     * adb function is enabled
				     * RNDIS ethernet function is enabled
				     * MTP function is enabled
				     * PTP function is enabled
				     * accessory function is enabled
				     * audio source function is enabled
				     * MIDI function is enabled
				     * </ul>
					boolean connected = intent.getBooleanExtra(MyUsbManager.USB_CONNECTED, false);
					addText("connected : " + connected);
					boolean configured = intent.getBooleanExtra(MyUsbManager.USB_CONFIGURED, false);
					addText("configured : " + configured);
					boolean function_adb = intent.getBooleanExtra(MyUsbManager.USB_FUNCTION_ADB, false);
					addText("function_adb : " + function_adb);
					boolean function_rndis = intent.getBooleanExtra(MyUsbManager.USB_FUNCTION_RNDIS, false);
					addText("function_rndis : " + function_rndis);
					boolean function_mtp = intent.getBooleanExtra(MyUsbManager.USB_FUNCTION_MTP, false);
					addText("function_mtp : " + function_mtp);
					boolean function_ptp = intent.getBooleanExtra(MyUsbManager.USB_FUNCTION_PTP, false);
					addText("usb_function_ptp : " + function_ptp);
					boolean function_audio_source = intent.getBooleanExtra(MyUsbManager.USB_FUNCTION_AUDIO_SOURCE, false);
					addText("function_audio_source : " + function_audio_source);
					boolean function_midi = intent.getBooleanExtra(MyUsbManager.USB_FUNCTION_MIDI, false);
					addText("function_midi : " + function_midi);
					break;
		intentFilter = new IntentFilter();
		intentFilter.addAction(UsbManager.ACTION_USB_ACCESSORY_ATTACHED);
		intentFilter.addAction(UsbManager.ACTION_USB_ACCESSORY_DETACHED);
		intentFilter.addAction(UsbManager.ACTION_USB_DEVICE_ATTACHED);
		intentFilter.addAction(UsbManager.ACTION_USB_DEVICE_DETACHED);
		intentFilter.addAction(MyUsbManager.ACTION_USB_STATE);
		registerReceiver(receiver, intentFilter);
		boolean hasUsbHost = getPackageManager().hasSystemFeature(PackageManager.FEATURE_USB_HOST);
		boolean hasUsbAccessory = getPackageManager().hasSystemFeature(PackageManager.FEATURE_USB_ACCESSORY);
		addText("hasUsbHost : " + hasUsbHost);
		addText("hasUsbAccessory : " + hasUsbAccessory);
	@Override
	protected void onDestroy() {
		unregisterReceiver(receiver);
		super.onDestroy();
	private void addText(String str) {
		textView.setText(textView.getText().toString() + str + "\n");
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
三、运行截图
这里写图片描述
四、ACTION_USB_DEVICE_ATTACHED 和 ACTION_USB_DEVICE_DETACHED的缺点
广播是去监测U盘插入和拔出的,也就意味着,你只要一插入或者一拔出U盘,就是收到这两个广播。它不会管你的设备有没有准备好,有没有mounted或者unmounted。
因此就需要引入一个新的广播 android.os.storage.extra.VOLUME_STATE。
这个广播就是用来监听Volume状态的。当外置Usb设备在Mounted或者UnMounted的时候则就可以用来做监听 int 类型的 VolumeInfo.EXTRA_VOLUME_STATE。
注意:android.os.storage.extra.VOLUME_STATE 一定要声明读写权限,否则是收不到的。
<uses-permission android:name="android.permission.READ_EXTERNAL_STORAGE" />
<uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" />
文章来源: blog.csdn.net,作者:福州-司马懿,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/chy555chy/article/details/52350810
