Easy Finding POJ - 3740(十字交叉双向循环链表dancing links)
用户已注销 发表于 2021/11/19 04:58:21 2021/11/19
【摘要】 题目: Given a  M×  N matrix  A.  A  ij ∈ {0, 1} (0 ≤ i < M, 0 ≤ j < N), could you find some rows that let every cloumn con...
题目:
Given a  M×  N matrix  A.  A  ij ∈ {0, 1} (0 ≤ i < M, 0 ≤ j < N), could you find some rows that let every cloumn contains and only contains one 1.
There are multiple cases ended by  EOF. Test case up to 500.The first line of input is  M,  N (  M ≤ 16,  N ≤ 300). The next  M lines every line contains  N integers separated by space.
For each test case, if you could find it output "Yes, I found it", otherwise output "It is impossible" per line.
3 3
0 1 0
0 0 1
1 0 0
4 4
0 0 0 1
1 0 0 0
1 1 0 1
0 1 0 0
Yes, I found it
It is impossible
单纯的精确覆盖问题,用来作为学习dancing links的第一个题目再合适不过了。
代码:
  1. #include<iostream>
  2. #include<stdio.h>
  3. using namespace std;
  4. int m, n, num[17][301];
  5. const int maxx = 6000, mr = 17;
  6. int key, up[maxx], down[maxx], lef[maxx], rig[maxx];//上下左右
  7. int row[maxx], col[maxx], rhead[mr];//行,列,每行第一个元素
  8. void init()
  9. {
  10. for (int i = 0; i <= n; i++)
  11. {
  12. up[i] = i, down[i] = i;
  13. lef[i] = i - 1, rig[i] = i + 1;
  14. row[i] = 0, col[i] = i;
  15. }
  16. lef[0] = n, rig[n] = 0;
  17. key = n;
  18. for (int i = 0; i <= m; i++)rhead[i] = 0;
  19. }
  20. void push(int r, int c)//新增坐标在(r,c)的一个节点
  21. {
  22. row[++key] = r, col[key] = c;
  23. up[key] = c, down[key] = down[c];
  24. up[down[c]] = key, down[c] = key;
  25. if (rhead[r] == 0)rhead[r] = lef[key] = rig[key] = key;
  26. else
  27. {
  28. lef[key] = rhead[r], rig[key] = rig[rhead[r]];
  29. lef[rig[rhead[r]]] = key, rig[rhead[r]] = key;
  30. }
  31. }
  32. void del(int c)//删除第c列的所有元素和他们所在行的所有元素
  33. {
  34. lef[rig[c]] = lef[c], rig[lef[c]] = rig[c];
  35. for (int i = down[c]; i != c; i = down[i])
  36. for (int j = rig[i]; j != i; j = rig[j])
  37. down[up[j]] = down[j], up[down[j]] = up[j];
  38. }
  39. void reback(int c)
  40. {
  41. lef[rig[c]] = rig[lef[c]] = c;
  42. for (int i = down[c]; i != c; i = down[i])
  43. for (int j = rig[i]; j != i; j = rig[j])
  44. down[up[j]] = up[down[j]] = j;
  45. }
  46. bool dfs()
  47. {
  48. if (rig[0] == 0)return true;
  49. int c = rig[0];
  50. del(c);
  51. for (int i = down[c]; i != c; i = down[i])
  52. {
  53. for (int j = rig[i]; j != i; j = rig[j])del(col[j]);
  54. if (dfs())return true;
  55. for (int j = rig[i]; j != i; j = rig[j])reback(col[j]);
  56. }
  57. reback(c);
  58. return false;
  59. }
  60. int main()
  61. {
  62. while (scanf("%d%d",&m,&n)!=EOF)
  63. {
  64. init();
  65. for (int i = 1; i <= m; i++)for (int j = 1; j <= n; j++)
  66. {
  67. scanf("%d", &num[i][j]);
  68. if (num[i][j])push(i, j);
  69. }
  70. if (dfs())printf("Yes, I found it\n");
  71. else printf("It is impossible\n");
  72. }
  73. return 0;
  74. }
文章来源: blog.csdn.net,作者:csuzhucong,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/nameofcsdn/article/details/79890911
