CSS3 弹簧
福州司马懿 发表于 2021/11/19 03:15:00 2021/11/19
【摘要】 <!DOCTYPE html> <html> <head> <meta charset="utf-8"> <m...
<!DOCTYPE html>
<html>
    <head>
        <meta name="viewport" content="initial-scale=1.0, maximum-scale=1.0, user-scalable=no" />
        <style>
            body{
                background: black;
                color: white;
            .rangeDiv {
                height: 150px;
            input[type=range] {
                width: 100px;
                height: 30px;
                /* 设置旋转中心(默认的旋转中心是元素中部) */
                transform-origin: 0 0;
                /* 旋转只是改变显示的位置, 元素实际占的位置还是旋转之前的位置 */
                transform: rotate(90deg);
                margin-left: 60px;
                position: absolute;
                float: left;
            label {
                position: absolute;
                float: left;
                margin-top: 110px;
                font-size: 14px;
            #cssload-wrap {
                position: absolute;
                left: 50%;
                top:10%;
                /* rotateX 是元素绕着X轴3D旋转 */
                transform: rotateX(70deg);
                /* scale 是对元素进行缩放
                transform: scale(1, 0.25); */
            .cssload-circle {
                position: absolute;
                float: left;
                border-radius: 50%;
                border-width: 3px;
                border-style: solid;
                animation-name:             bounce      动画名称
                animation-timing-function:  ease-in-out 动画以低速开始和结束
                animation-direction:        alternate   动画应该轮流反向播放
                animation: bounce 1.73s infinite ease-in-out alternate;
            @keyframes bounce {
                0% {
                    transform: translateY(0px);
                100% {
                    transform: translateY(600px);
        </style>
    </head>
    <body>
        <div id="cssload-wrap"></div>
        <div class="rangeDiv">
            <input id="borderRadiusRange" type="range" min="0" max="50" step="1" value="50">
            <label id="borderRadiusLabel">border-radius: 50%</label>
        </div>
            <input id="translateYRange" type="range" min="0" max="1000" step="100" value="600">
            <label id="translateYLabel">translateY: 600px</label>
        </div>
            <input id="rotateXRange" type="range" min="0" max="90" step="1" value="70">
            <label id="rotateXLabel">rotateX: 70px</label>
        </div>
        <script>
            var cssloadWrap = document.getElementById("cssload-wrap");
            var count = 30;
            for(var i=0; i<count; i++) {
                var div = document.createElement("div");
                div.setAttribute("class", "cssload-circle");
                cssloadWrap.appendChild(div);
            //圆环从中间向外侧大小增加步长
            var sizeStep = 20;
            //圆环从中间向外侧延迟动画的时间步长
            var delayStep = 115;
            var horizontalMarginStep = -sizeStep / 2;
            var style = document.getElementsByTagName("style")[0];
            for(var i=1; i<=count; i++) {
                //nth-child()选择器的第一个子元素的下标是1
                var ruleName =  ".cssload-circle:nth-child(" + i + ")";
                var ruleValue = "margin: 0 " + (horizontalMarginStep * i) + "px;" +
                    "width: " + (sizeStep * i) + "px;" +
                    "height: " + (sizeStep * i) + "px;" +
                    "animation-delay: " + (delayStep * i) + "ms;" +
                    //z-index为负就会被body标签挡住,从而接收不到点击事件
                    "z-index: " + (-i) +";" +
                    "border-color:hsla(" + (360 / count * i) + ",100%,50%,0.7);";
                //区别是在chrome"检查"时,appendChild方法在源码上能看到添加的内容,而addRule并不能
                style.appendChild(document.createTextNode(ruleName + "{" + ruleValue + "}"));
                //document.styleSheets[0].addRule(ruleName, ruleValue)
            var borderRadiusRange = document.getElementById("borderRadiusRange");
            borderRadiusRange.addEventListener("change", function() {
                document.getElementById("borderRadiusLabel").innerHTML = "border-radius:" + event.target.value + "px";
                var rules = document.styleSheets[0].rules;
                for(var i=0; i<rules.length; i++) {
                    //类型常量的定义见MDN https://developer.mozilla.org/en-US/docs/Web/API/CSSRule
                    if(rules[i].type === CSSRule.STYLE_RULE && rules[i].selectorText === ".cssload-circle") {
                        rules[i].style.borderRadius = event.target.value + "%";
                        return;
            var translateYRange = document.getElementById("translateYRange");
            translateYRange.addEventListener("change", function() {
                document.getElementById("translateYLabel").innerHTML = "translateY: " + event.target.value + "px";
                    if(rules[i].type === CSSRule.KEYFRAMES_RULE && rules[i].name === "bounce") {
                        var cssRules = rules[i].cssRules;
                        for(var j=0; j<cssRules.length; j++) {
                            if(cssRules[j].keyText === "100%") {
                                cssRules[j].style.transform = "translateY(" + event.target.value + "px)";
                                return;
            var rotateXRange = document.getElementById("rotateXRange");
            rotateXRange.addEventListener("change", function() {
                document.getElementById("rotateXLabel").innerHTML = "rotateX: " + event.target.value + "deg";
                //由于要修改的是某个id的style,所以可以直接修改该元素的style。下面2种方式都不会对源码的相应style产生影响
                cssloadWrap.style.transform = "rotateX(" + event.target.value + "deg)";
                    if(rules[i].type === CSSRule.STYLE_RULE && rules[i].selectorText === "#cssload-wrap") {
                        rules[i].style.transform = "rotateX(" + event.target.value + "deg)";
                        return;
        </script>
    </body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
这里写图片描述
文章来源: blog.csdn.net,作者:福州-司马懿,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/chy555chy/article/details/54783925
