HTML5 五种密码框
福州司马懿 发表于 2021/11/19 02:49:46 2021/11/19
【摘要】 <html> <head> <meta charset="utf8"> <title>五种密码类型</titl...
<html>
    <head>
        <title>五种密码类型</title>
        <style>
            body {
                font-size: 16px;
            .container {
                border: 1px groove black;
                padding: 10px;
                margin-bottom: 10px;
            label {
                display: block;
            input[type=password],input[type=text] {
                border-radius: 2px;
                border: 1px solid #ccc;
                transition: box-shadow .5s;
            input[type=password]:hover,input[type=text]:hover {
                /* 添加边框阴影 */
                box-shadow: inset 0 1px 3px rgba(0,0,0,.05),0 0 8px rgba(82,168,236,.6);
            #customPwdContainer {
                /* 如果这里不声明relative,那么限制不了内部的absolute元素 */
                position: relative;
            #plain5 {
                /* 这样才能让2个元素重叠 */
                position: absolute;
                /* 为了让上边框重合,否则会差一个上边框的宽度 */
                top: 0;
                z-index: 1;
        </style>
    </head>
    <body>
        <div class="container">
            <label>普通密码框</label>
            <input type="password">
        </div>
            <label>带占位符的密码框</label>
            <input type="password" placeholder="请输入密码">
        </div>
            <label>限制长度的密码框</label>
            <input type="password" maxlength="6">
        </div>
            <label>可更改可见性的密码框</label>
            <input type="password" id="pwd4">
            <input type="checkbox" onchange="changePwd4Visible()" id="cb4">是否显示密码
        </div>
            <label>自定义密码框</label>
            <span id="customPwdContainer">
                <!-- 明文 -->
                <input type="text" id="plain5">
                <!-- 密文 -->
                <input type="text" id="pwd5">
            </span>
            <input type="checkbox" onchange="changePwd5Visible()" id="cb5">是否显示密码
        </div>
        <script>
            var pwd4 = document.getElementById("pwd4");
            var cb4 = document.getElementById("cb4");
            function changePwd4Visible() {
                pwd4.type = event.target.checked ? "text" : "password";
            var plain5 = document.getElementById("plain5");
            var pwd5 = document.getElementById("pwd5");
            var cb5 = document.getElementById("cb5");
            //如果没有onkeydown,那么一直按着按键不会触发
            //onkeydown的时候并不会立马更新value,所以必须有onkeyup
            //如果只有onkeydown和onkeyup,那么删除文本不会触发;
            plain5.onkeydown = plain5.onkeyup = plain5.onchange = function() {
                pwd5.value = plain5.value.replace(/./g, "*");
                这里一旦设置selection,那么就把聚焦的对话框转移了.所以输入密文密码时无法显示光标
                if(!cb5.checked) {
                    pwd5.selectionStart = plain5.selectionStart;
                    pwd5.selectionEnd = plain5.selectionEnd;
            function changePwd5Visible() {
                //显示明文,密文框在下层
                //显示密文,明文框在上层,透明度为0
                plain5.style.opacity = cb5.checked ? 1 : 0;
            changePwd5Visible();
        </script>
    </body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
这里写图片描述
文章来源: blog.csdn.net,作者:福州-司马懿,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/chy555chy/article/details/54882467
