CSS3 counter 计数器
福州司马懿 发表于 2021/11/19 03:05:18 2021/11/19
【摘要】 参考 http://www.zhangxinxu.com/wordpress/2014/08/css-counters-automatic-number-content/ 参考 https://www....
参考 https://www.w3cplus.com/css3/css-counters.html
定义
name syntax description
counter-reset [<indentifier> <integer>?]+|none |inherit 定义计数器和初始值,当元素display:none时,该属性失效
counter-increment [<indentifier> <integer>?]+|none 增加计数器
counter [counter(name)] | [counter(name,list-style-type)] 在content属性中使用,用来调用计数器求值
counters [counters(name,string)] | [counters(name,string,list-style-type)] 在content属性中使用,用来调用计数器求值
counter-style 计数器样式
content 在 ::before 和 ::after 中生成内容
counter-style
系统预定义的计数器样式
disc | circle | square | decimal | lower-roman | upper-roman | lower-alpha | upper-alpha | none | armenian | cjk-ideographic | georgian | lower-greek | hebrew | hiragana | hiragana-iroha | katakana | katakana-iroha | lower-latin | upper-latin
<html>
<head>
<meta charset="utf-8">
<style>
div{
    counter-reset: value 1;
.disc::before{ content: counter(value, disc) ' - '}
.circle::before { content:counter(value, circle) ' - '}
.square::before { content:counter(value, square) ' - '}
.decimal::before { content:counter(value, decimal) ' - '}
.lower-roman::before { content:counter(value, lower-roman) ' - '}
.upper-roman::before { content:counter(value, upper-roman) ' - '}
.lower-alpha::before { content:counter(value, lower-alpha) ' - '}
.upper-alpha::before { content:counter(value, upper-alpha) ' - '}
.none::before { content:counter(value, none) ' - '}
.armenian::before { content:counter(value, armenian) ' - '}
.cjk-ideographic::before { content:counter(value, cjk-ideographic) ' - '}
.georgian::before { content:counter(value, georgian) ' - '}
.lower-greek::before { content:counter(value, lower-greek) ' - '}
.hebrew::before { content:counter(value, hebrew) ' - '}
.hiragana::before { content:counter(value, hiragana) ' - '}
.hiragana-iroha::before { content:counter(value, hiragana-iroha) ' - '}
.katakana::before { content:counter(value, katakana) ' - '}
.katakana-iroha::before { content:counter(value, katakana-iroha) ' - '}
.lower-latin::before { content:counter(value, lower-latin) ' - '}
.upper-latin::before { content:counter(value, upper-latin) ' - '}
</style>
</head>
<body>
<table>
<div class="disc">This is the disc</div>
<div class="circle">This is the circle</div>
<div class="square">This is the square</div>
<div class="decimal">This is the decimal</div>
<div class="lower-roman">This is the lower-roman</div>
<div class="upper-roman">This is the upper-roman</div>
<div class="lower-alpha">This is the lower-alpha</div>
<div class="upper-alpha">This is the upper-alpha</div>
<div class="none">This is the none</div>
<div class="armenian">This is the armenian</div>
<div class="cjk-ideographic">This is the cjk-ideographic</div>
<div class="georgian">This is the georgian</div>
<div class="lower-greek">This is the lower-greek</div>
<div class="hebrew">This is the hebrew</div>
<div class="hiragana">This is the hiragana</div>
<div class="hiragana-iroha">This is the hiragana-iroha</div>
<div class="katakana">This is the katakana</div>
<div class="katakana-iroha">This is the katakana-iroha</div>
<div class="lower-latin">This is the lower-latin</div>
<div class="upper-latin">This is the upper-latin</div>
</table>
</body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
这里写图片描述
自定义计数器样式表的格式
@counter-style counerStyleName{
    system:算法;
    range:使用范围;
    symbols:符号;
    additive-symbols:符号;
    prefix:前缀;
    suffix:后缀;
    pad:补零(eg.01,02,03);
    negative:负数策略;
    fallback:出错后的默认值;
    speakas:语音策略;
应用范例
<html>
<head>
<meta charset="utf8">
<style>
.reset {
    padding-left: 20px;
    counter-reset: wangxiaoer 0;
    line-height: 1.6;
    color: #666;
.counter:before {
    content: counters(wangxiaoer, '-', upper-roman) '. ';
    counter-increment: wangxiaoer 1;
    font-family: arial black;
</style>
</head>
<body>
<div class="reset">
    <div class="counter">我是王小二
        <div class="reset">
            <div class="counter">我是王小二的大儿子</div>
            <div class="counter">我是王小二的二儿子
                <div class="reset">
                    <div class="counter">我是王小二的二儿子的大孙子</div>
                    <div class="counter">我是王小二的二儿子的二孙子</div>
                    <div class="counter">我是王小二的二儿子的小孙子</div>
                </div>
            </div>
            <div class="counter">我是王小二的三儿子</div>
        </div>
    </div>
    <div class="counter">我是王小三</div>
    <div class="counter">我是王小四
        <div class="reset">
            <div class="counter">我是王小四的大儿子</div>
        </div>
    </div>
</div>
</body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
这里写图片描述
文章来源: blog.csdn.net,作者:福州-司马懿,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/chy555chy/article/details/79931369
