Leetcode最大和最小子序和
herosunly 发表于 2021/11/19 01:18:58 2021/11/19
【摘要】 最大子序和,动态规划时间复杂度为O(n),则假设每一步为step, s ...
s f ( x 1 ) = x 1 sf(x_1)=x_1 sf(x1​)=x1​
s f ( x 2 ) = { s f ( x 1 ) + x 2 , s f ( x 1 ) + x 2 > x 2 x 2 , s f ( x 1 ) + x 2 < = x 2 sf (x_2 ) = \left\{
sf(x1)+x2,sf(x1)+x2>x2x2,sf(x1)+x2<=x2 s f ( x 1 ) + x 2 , s f ( x 1 ) + x 2 > x 2 x 2 , s f ( x 1 ) + x 2 <= x 2
sf(x2​)={sf(x1​)+x2​,sf(x1​)+x2​>x2​x2​,sf(x1​)+x2​<=x2​​
s f ( x 3 ) = { s f ( x 2 ) + x 3 , s f ( x 2 ) + x 3 > x 3 x 3 , s f ( x 2 ) + x 3 < = x 3 sf (x_3 ) = \left\{
sf(x2)+x3,sf(x2)+x3>x3x3,sf(x2)+x3<=x3 s f ( x 2 ) + x 3 , s f ( x 2 ) + x 3 > x 3 x 3 , s f ( x 2 ) + x 3 <= x 3
sf(x3​)={sf(x2​)+x3​,sf(x2​)+x3​>x3​x3​,sf(x2​)+x3​<=x3​​
f ( x 1 , x 2 ) = m a x ( s f ( x 1 ) , s f ( x 2 ) ) f(x_1, x_2) = max(sf(x_1), sf(x_2)) f(x1​,x2​)=max(sf(x1​),sf(x2​))
f ( x 1 , x 2 , x 3 ) = m a x ( s f ( x 1 ) , s f ( x 2 ) , s f ( x 3 ) ) f(x_1, x_2,x_3) = max(sf(x_1), sf(x_2), sf(x_3)) f(x1​,x2​,x3​)=max(sf(x1​),sf(x2​),sf(x3​))
class Solution:
    def maxSubArray(self, nums: List[int]) -> int:
        if len(nums) == 0:
            return 0
        global_max = nums[0]
        step_max = nums[0]
        if len(nums) == 1:
            return global_max
        for i in range(1, len(nums)):
            if step_max + nums[i] < nums[i]:
                step_max = nums[i]
            else:
                step_max += nums[i]
            if step_max > global_max:
                global_max = step_max
        return global_max
class Solution:
    def minSubArray(self, nums: List[int]) -> int:
        if len(nums) == 0:
            return 0
        global_min = nums[0]
        step_min = nums[0]
        if len(nums) == 1:
            return global_min
            if step_min + nums[i] < nums[i]:
                step_min += nums[i]
            else:
                step_max = nums[i]
            if step_min < global_min:
                global_min = step_min
        return global_min
https://www.zhihu.com/question/23995189/answer/35324479
https://www.zhihu.com/question/52165201
文章来源: blog.csdn.net,作者:herosunly,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/herosunly/article/details/106641003
