05 Android系统之删除Android原生内置APK
王建峰 发表于 2021/11/19 01:19:21 2021/11/19
【摘要】 两种方法 为了在编译阶段将内置apk给异常,下面提供2中方法。 直接找到添加这个apk的mk文件,从 PRODUCT_PACKAGES 中删除通过添加模块,LOCAL_OVERRIDES_PACKAG...
两种方法
  • 直接找到添加这个apk的mk文件,从 PRODUCT_PACKAGES 中删除
  • 通过添加模块,LOCAL_OVERRIDES_PACKAGES定义要覆盖的apk
目录结构
hinzer@ubuntu:android-10$ tree ./device/mi/pure/
./device/mi/pure/
├── Android.mk
├── AndroidProducts.mk
├── BoardConfig.mk
├── product01.mk
操作过程
1、 直接从 PRODUCT_PACKAGES 中删除
# step1 找到apk添加到 PRODUCT_PACKAGES 的那个mk文件
$ mgrep Contacts
# step2 从改mk文件中移除配置项
# step3 清理system目录,重新编译
$ rm -rf out/target/product/pure/system
# step4 验证
make -j4 && emulator
2、 通过 LOCAL_OVERRIDES_PACKAGES 删除
  1. 在Product下添加一个模块remove_unused_module
$ vim Android.mk
include $(CLEAR_VARS)
LOCAL_MODULE := remove_unused_module
LOCAL_MODULE_TAGS := optional
LOCAL_MODULE_CLASS := FAKE     # 指定编译输出的目录为 $(PRODUCT_OUT)/fake_packages
LOCAL_MODULE_SUFFIX := $(COMMON_ANDROID_PACKAGE_SUFFIX)
LOCAL_OVERRIDES_PACKAGES += \
   Contacts \
   Email  			#这里添加要覆盖的apk
include $(BUILD_SYSTEM)/base_rules.mk
$(LOCAL_BUILT_MODULE):
	$(hide) echo "Fake: $@"
	$(hide) mkdir -p $(dir $@)
	$(hide) touch $@
PACKAGES.$(LOCAL_MODULE).OVERRIDES := $(strip $(LOCAL_OVERRIDES_PACKAGES))
  1. 将remove_unused_module添加到对应product文件的PRODUCT_PACKAGES配置
PRODUCT_PACKAGES += remove_unused_module
  1. 清理out/target/product/pure/system目录,验证
$ make -j4 && emulator
原理补充(PRODUCT_PACKAGES)
对于第一种方法,通过mgrep命令能够搜索到这个mk文件定义了PRODUCT_PACKAGES,直接移除就ok。对于第二种方法,在 main.mk 里面有对 OVERRIDES_PACKAGES 进行处理(在android-10源码中对这个关键词进行检索)
# Lists most of the files a particular product installs, including:
# - PRODUCT_PACKAGES, and their LOCAL_REQUIRED_MODULES
# - PRODUCT_COPY_FILES
# The base list of modules to build for this product is specified
# by the appropriate product definition file, which was included
# by product_config.mk.
# Name resolution for PRODUCT_PACKAGES:
#   foo:32 resolves to foo_32;
#   foo:64 resolves to foo;
#   foo resolves to both foo and foo_32 (if foo_32 is defined).
# Name resolution for LOCAL_REQUIRED_MODULES:
#   If a module is built for 2nd arch, its required module resolves to
#   32-bit variant, if it exits. See the select-bitness-of-required-modules definition.
# $(1): product makefile
define product-installed-files
  $(eval _mk := $(strip $(1))) \
  $(eval _pif_modules := \
    $(PRODUCTS.$(_mk).PRODUCT_PACKAGES) \
    $(if $(filter eng,$(tags_to_install)),$(PRODUCTS.$(_mk).PRODUCT_PACKAGES_ENG)) \
    $(if $(filter debug,$(tags_to_install)),$(PRODUCTS.$(_mk).PRODUCT_PACKAGES_DEBUG)) \
    $(if $(filter tests,$(tags_to_install)),$(PRODUCTS.$(_mk).PRODUCT_PACKAGES_TESTS)) \
    $(if $(filter asan,$(tags_to_install)),$(PRODUCTS.$(_mk).PRODUCT_PACKAGES_DEBUG_ASAN)) \
    $(call auto-included-modules) \
  $(eval ### Filter out the overridden packages and executables before doing expansion) \
  $(eval _pif_overrides := $(call module-overrides,$(_pif_modules))) \
  $(eval _pif_modules := $(filter-out $(_pif_overrides), $(_pif_modules))) \
  $(eval ### Resolve the :32 :64 module name) \
  $(eval _pif_modules_32 := $(patsubst %:32,%,$(filter %:32, $(_pif_modules)))) \
  $(eval _pif_modules_64 := $(patsubst %:64,%,$(filter %:64, $(_pif_modules)))) \
  $(eval _pif_modules_rest := $(filter-out %:32 %:64,$(_pif_modules))) \
  $(eval ### Note for 32-bit product, 32 and 64 will be added as their original module names.) \
  $(eval _pif_modules := $(call get-32-bit-modules-if-we-can, $(_pif_modules_32))) \
  $(eval _pif_modules += $(_pif_modules_64)) \
  $(eval ### For the rest we add both) \
  $(eval _pif_modules += $(call get-32-bit-modules, $(_pif_modules_rest))) \
  $(eval _pif_modules += $(_pif_modules_rest)) \
  $(call expand-required-modules,_pif_modules,$(_pif_modules),$(_pif_overrides)) \
  $(filter-out $(HOST_OUT_ROOT)/%,$(call module-installed-files, $(_pif_modules))) \
  $(call resolve-product-relative-paths,\
    $(foreach cf,$(PRODUCTS.$(_mk).PRODUCT_COPY_FILES),$(call word-colon,2,$(cf))))
endef
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
有定义
filter-out是Makefile语法支持的函数,从$(_pif_modules)中 反选过滤出$(_pif_overrides)之外的所有modules。
涉及到android build系统,我现在也还没搞清楚逻辑链,有待补充。
参考资料
文章来源: blog.csdn.net,作者:hinzer,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/feit2417/article/details/105237647
