Leetcode 83 Remove Duplicates from Sorted List
herosunly 发表于 2021/11/18 23:42:50 2021/11/18
【摘要】 题意描述 Given a sorted linked list, delete all duplicates such that each element appear only once. Exam...
题意描述
Example 1:
Input: 1->1->2
Output: 1->2
思路解析
该题只需要两个指针,prev和cur即可。为什么不需要nex呢?
这个问题值得思考。
是因为在之前的问题中,cur.next = prev,这样就会导致cur无法后移。而在这个问题中,如果prev.val == cur.val,只是将prev.next = cur.next,并不会影响cur的后移。
C++代码
 * Definition for singly-linked list.
 * struct ListNode {
 *     int val;
 *     ListNode *next;
 *     ListNode(int x) : val(x), next(NULL) {}
class Solution {
public:
    ListNode* deleteDuplicates(ListNode* head) {
        if (head == NULL || head->next == NULL) {
            return head;
        ListNode* prev = head;
        ListNode* cur = head->next;
        while (cur) {
            if (prev->val == cur->val) {
                prev->next = cur->next;
                cur = cur->next;
            else {
                prev = cur;
                cur = cur->next;
        return head;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
但是这样其实会有个小问题,也就是重复数据节点只是跳过了,并没有释放相应的内存。
这时候就需要用nex保存cur.next。
 * struct ListNode {
 *     int val;
 *     ListNode *next;
class Solution {
public:
            return head;
        while (cur) {
                ListNode* nex = cur->next;
                cur->next = NULL;
                delete(cur);
                cur = nex;
            else {
                prev = cur;
                cur = cur->next;
        return head;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
Java代码
 * public class ListNode {
 *     int val;
 *     ListNode next;
 *     ListNode(int x) { val = x; }
import java.util.*;
class Solution {
    public ListNode deleteDuplicates(ListNode head) {
        if (head == null || head.next == null) {
            return head;
        ListNode prev = head;
        ListNode cur = head.next;
        while (cur != null) {
            if (prev.val == cur.val) {
                prev.next = cur.next;
                cur = prev.next;
            else {
                prev = cur;
                cur = cur.next;
        return head;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
Python代码
# Definition for singly-linked list.
# class ListNode(object):
#     def __init__(self, x):
#         self.val = x
#         self.next = None
class Solution(object):
    def deleteDuplicates(self, head):
        :type head: ListNode
        :rtype: ListNode
        if head == None or head.next == None:
            return head
        prev = head
        cur = head.next
        while cur:
            if prev.val == cur.val:
                nex = cur.next
                cur.next = None
                cur = nex
            else:
                prev = cur
                cur = cur.next
        return head
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
文章来源: blog.csdn.net,作者:herosunly,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/herosunly/article/details/87542820
