注册中心eureka的搭建
小鲍侃java 发表于 2021/11/19 00:10:50 2021/11/19
【摘要】 1.搭建项目 新建普通的springboot项目。 1.修改Application 修改EurekaServerApplication类:关键注解@EnableEurekaServer,声明为注册中...
1.搭建项目
新建普通的springboot项目。
1.修改Application
修改EurekaServerApplication类:关键注解@EnableEurekaServer,声明为注册中心。
package com.cloud;
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
import org.springframework.cloud.netflix.eureka.server.EnableEurekaServer;
@SpringBootApplication
@EnableEurekaServer
public class EurekaServerApplication {
		SpringApplication.run(EurekaServerApplication.class, args);
2.修改pom文件
然后修改pom文件:一定要看好版本,现在版本真的是乱七八糟,而且有的注解被干掉了。
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <parent>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>2.2.5.RELEASE</version>
        <relativePath/> <!-- lookup parent from repository -->
    </parent>
    <groupId>com.baocl</groupId>
    <artifactId>eureka-consumer-feign</artifactId>
    <version>0.0.1-SNAPSHOT</version>
    <name>eureka-consumer-feign</name>
    <description>Demo project for Spring Boot</description>
    <properties>
        <java.version>1.8</java.version>
        <spring-cloud.version>Hoxton.SR1</spring-cloud.version>
    </properties>
    <dependencies>
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
        <dependency>
            <groupId>org.springframework.cloud</groupId>
            <artifactId>spring-cloud-starter-netflix-eureka-server</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-test</artifactId>
            <scope>test</scope>
            <exclusions>
                <exclusion>
                    <groupId>org.junit.vintage</groupId>
                    <artifactId>junit-vintage-engine</artifactId>
                </exclusion>
            </exclusions>
        </dependency>
    </dependencies>
    <dependencyManagement>
        <dependencies>
            <dependency>
                <artifactId>spring-cloud-dependencies</artifactId>
                <version>${spring-cloud.version}</version>
                <type>pom</type>
                <scope>import</scope>
            </dependency>
        </dependencies>
    </dependencyManagement>
    <build>
        <plugins>
            <plugin>
                <artifactId>spring-boot-maven-plugin</artifactId>
            </plugin>
        </plugins>
    </build>
</project>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
3.修改application.properties
最后是最重要的配置文件application.properties,楼主总结了常用的配置。
spring.application.name=eureka-server
eureka.client.serviceUrl.defaultZone=http://localhost:${server.port}/eureka/
server.port=1001
eureka.instance.hostname=localhost
#是否向服务注册中心注册自己
eureka.client.register-with-eureka=false
#是否检索服务   ---表示是否从注册中心拉取服务列表
eureka.client.fetch-registry=false
#是否开启自我保护模式,默认为true。
#默认情况下,如果Eureka Server在一定时间内没有接收到某个微服务实例的心跳,Eureka Server将会注销该实例(默认90秒)。
#但是当网络分区故障发生时,微服务与Eureka Server之间无法正常通信,以上行为可能变得非常危险了——因为微服务本身其实是健康的,此时本不应该注销这个微服务。
#Eureka通过“自我保护模式”来解决这个问题——当Eureka Server节点在短时间内丢失过多客户端时(可能发生了网络分区故障),
#那么这个节点就会进入自我保护模式。一旦进入该模式,Eureka Server就会保护服务注册表中的信息,不再删除服务注册表中的数据(也就是不会注销任何微服务)。
#当网络故障恢复后,该Eureka Server节点会自动退出自我保护模式。
#综上,自我保护模式是一种应对网络异常的安全保护措施。它的架构哲学是宁可同时保留所有微服务(健康的微服务和不健康的微服务都会保留),
#也不盲目注销任何健康的微服务。使用自我保护模式,可以让Eureka集群更加的健壮、稳定。
#eureka.server.enable-self-preservation=false
#设置清理无效节点的时间间隔,默认60000,即是60s
#eureka.server.eviction-interval-timer-in-ms=5000
#自我保护续约百分比阀值因子。如果实际续约数小于续约数阀值,则开启自我保护
#eureka.server.renewalPercentThreshold = 0.85
#节点间连接的超时时间。
#eureka.server.peerNodeConnectTimeoutMs=200
#节点间读取信息的超时时间。
#eureka.server.peerNodeReadTimeoutMs=200
#每隔x秒更新自身缓存 作用于client从server获取缓存(1001页面跳过缓存不会生效)
#eureka.server.response-cache-update-interval-ms= 2000
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
然后启动服务,访问配置的端口号,出现这个界面,就代表ok啦。
4.大致原理
spring cloud通信主要是以http请求形式进行,当服务启动后向Eureka注册,Eureka Server会将注册信息向其他Eureka Server进行同步,当服务消费者要调用服务提供者,则向服务注册中心获取服务提供者地址,然后会将服务提供者地址缓存在本地,下次再调用时,则直接从本地缓存中取,完成一次调用。 当服务注册中心Eureka Server检测到服务提供者因为宕机、网络原因不可用时,则在服务注册中心将服务置为DOWN状态,并把当前服务提供者状态向订阅者发布,订阅过的服务消费者更新本地缓存。 服务提供者在启动后,周期性(默认30秒)向Eureka Server发送心跳,以证明当前服务是可用状态。Eureka Server在一定的时间(默认90秒)未收到客户端的心跳,则认为服务宕机,注销该实例。
文章来源: baocl.blog.csdn.net,作者:小黄鸡1992,版权归原作者所有,如需转载,请联系作者。
原文链接:baocl.blog.csdn.net/article/details/120794123
