Linux下Python备份mysql脚本代码
DevFeng 发表于 2021/11/17 17:14:54 2021/11/17
【摘要】 前言需要在linux下备份mysql数据代码#!/usr/bin/python# vim: set fileencoding=utf-8import osimport timeDB_HOST = 'localhost'DB_USER = '用户名'DB_USER_PASSWORD = '密码'#DB_NAME = '/backup/dbnames.txt'DB_NAME = 'zhongsh...
前言
需要在linux下备份mysql数据
代码
#!/usr/bin/python
import os
import time
DB_USER = '用户名'
DB_NAME = '数据库名称'
BACKUP_PATH = '/backup/dbbackup/'
DATETIME = time.strftime('%m%d%Y-%H%M%S')
TODAYBACKUPPATH = BACKUP_PATH + DATETIME
print("创建备份文件夹")
print(TODAYBACKUPPATH)
if not os.path.exists(TODAYBACKUPPATH):
    os.makedirs(TODAYBACKUPPATH)
print("检查数据库名称文件.")
if os.path.exists(DB_NAME):
    file1 = open(DB_NAME)
    multi = 1
    print("数据库文件发现...")
    print("开始备份文件中列出的所有dbs " + DB_NAME)
else:
    print("未找到数据库文件...")
    print("启动数据库备份 " + DB_NAME)
    multi = 0
#启动实际的数据库备份进程。
if multi:
   in_file = open(DB_NAME,"r")
   flength = len(in_file.readlines())
   in_file.close()
   p = 1
   dbfile = open(DB_NAME,"r")
   while p <= flength:
       db = dbfile.readline()   # reading database name from file
       db = db[:-1]         # deletes extra line
       dumpcmd = "mysqldump  -u " + DB_USER + " -p" + DB_USER_PASSWORD + " " + db + " > " + TODAYBACKUPPATH + "/" + db + ".sql"
       os.system(dumpcmd)
       p = p + 1
   dbfile.close()
else:
   db = DB_NAME
   os.system(dumpcmd)
print("备份脚本完成")
print("您的备份已在 '" + TODAYBACKUPPATH + "' 目录")
结论
#!/usr/bin/python
linux上需要的代码,如果需要在windows下执行去掉即可
