AB153x API----GPIO枚举
心跳包 发表于 2021/11/13 01:03:02 2021/11/13
【摘要】  枚举HAL » GPIO 枚举 枚举  hal_gpio_direction_t { HAL_GPIO_DIRECTION_INPUT = 0, HAL_GPIO_DIRECTION_OUTPUT = 1} 该枚举定义...
 枚举HAL » GPIO
枚举
  该枚举定义了GPIO方向。 更多...
枚举   hal_gpio_data_t { HAL_GPIO_DATA_LOW = 0, HAL_GPIO_DATA_HIGH = 1}
  该枚举定义了GPIO的数据类型。 更多...
枚举   hal_gpio_status_t {
  HAL_GPIO_STATUS_ERROR_CHECK = -4, HAL_GPIO_STATUS_ERROR = -3, HAL_GPIO_STATUS_ERROR_PIN = -2, HAL_GPIO_STATUS_INVALID_PARAMETER = -1,
  HAL_GPIO_STATUS_OK = 0
  该枚举定义了GPIO API的返回类型。 更多...
枚举   hal_pinmux_status_t {
  HAL_PINMUX_STATUS_ERROR_CHECK = -4, HAL_PINMUX_STATUS_ERROR = -3, HAL_PINMUX_STATUS_ERROR_PORT = -2, HAL_PINMUX_STATUS_INVALID_FUNCTION = -1,
  HAL_PINMUX_STATUS_OK = 0
  该枚举定义pinmux API的返回类型。 更多...
枚举   hal_gpio_driving_current_t { HAL_GPIO_DRIVING_CURRENT_8MA = 0, HAL_GPIO_DRIVING_CURRENT_16MA = 1, HAL_GPIO_DRIVING_CURRENT_24MA = 2, HAL_GPIO_DRIVING_CURRENT_32MA = 3}
  该枚举定义了驱动电流。 更多...
枚举   hal_pinmux_select_t {
  HAL_PINMUX_DEFAULT = 0, HAL_PINMUX_PWM1 = 1, HAL_PINMUX_PWM2, HAL_PINMUX_PWM3,
  HAL_PINMUX_PWM4, HAL_PINMUX_PWM5, HAL_PINMUX_PWM6, HAL_PINMUX_LED3,
  HAL_PINMUX_LED4, HAL_PINMUX_LED5, HAL_PINMUX_SDIO_LED, HAL_PINMUX_CLK_XO32k,
  HAL_PINMUX_CLK_XO16m, HAL_PINMUX_CLK_RCO128_64k, HAL_PINMUX_PER_CLK_24m, HAL_PINMUX_CLK_XO16m_divided_by_N,
  HAL_PINMUX_I2S_MCLK, HAL_PINMUX_UART_NRTS, HAL_PINMUX_SPDIF_TXO, HAL_PINMUX_DMIC_CLK,
  HAL_PINMUX_MDSP_UART_TX, HAL_PINMUX_CS_1, HAL_PINMUX_CS_2, HAL_PINMUX_CS_3,
  HAL_PINMUX_SDIO_BUS_PWR_CTL, HAL_PINMUX_I2S0_SDO1, HAL_PINMUX_I2S0_SDO2, HAL_PINMUX_UART2_TX,
  HAL_PINMUX_DBG_PORT = 31
  该枚举定义了用于的gpio。
枚举   hal_gpio_pin_t {
  HAL_GPIO_0 = 0, HAL_GPIO_1 = 1, HAL_GPIO_2 = 2, HAL_GPIO_3 = 3,
  HAL_GPIO_4 = 4, HAL_GPIO_5 = 5, HAL_GPIO_6 = 6, HAL_GPIO_7 = 7,
  HAL_GPIO_8 = 8, HAL_GPIO_9 = 9, HAL_GPIO_10 = 10, HAL_GPIO_11 = 11,
  HAL_GPIO_12 = 12, HAL_GPIO_13 = 13, HAL_GPIO_14 = 14, HAL_GPIO_15 = 15,
  HAL_GPIO_16 = 16, HAL_GPIO_17 = 17, HAL_GPIO_18= 18, HAL_GPIO_19 = 19,
  HAL_GPIO_20 = 20, HAL_GPIO_21 = 21, HAL_GPIO_22 = 22, HAL_GPIO_23 = 23,
  HAL_GPIO_24 = 24, HAL_GPIO_25 = 25, HAL_GPIO_26 = 26, HAL_GPIO_27 = 27,
  HAL_GPIO_28 = 28, HAL_GPIO_29 = 29, HAL_GPIO_30 = 30 , HAL_GPIO_31 = 31,
  HAL_GPIO_MAX
  该枚举定义了GPIO端口。该平台总共支持49个具有各种功能的GPIO引脚。 更多...
枚举类型文档
◆ hal_gpio_data_t
该枚举定义了GPIO的数据类型。
枚举器
HAL_GPIO_DATA_LOW
GPIO数据低。
HAL_GPIO_DATA_HIGH
GPIO数据为高。
◆ hal_gpio_direction_t
该枚举定义了GPIO方向。
枚举器
GPIO输入方向。
GPIO输出方向。
◆ hal_gpio_driving_current_t
该枚举定义了驱动电流。
枚举器
将GPIO驱动电流定义为8mA。
将GPIO驱动电流定义为16mA。
将GPIO驱动电流定义为24mA。
将GPIO驱动电流定义为32mA。
◆ hal_gpio_pin_t
枚举器
HAL_GPIO_0
GPIO引脚0。
HAL_GPIO_1
GPIO引脚1。
HAL_GPIO_2
GPIO引脚2。
HAL_GPIO_3
GPIO引脚3。
HAL_GPIO_4
GPIO引脚4。
HAL_GPIO_5
GPIO引脚5。
HAL_GPIO_6
GPIO引脚6。
HAL_GPIO_7
GPIO引脚7。
HAL_GPIO_8
GPIO引脚8。
HAL_GPIO_9
GPIO引脚9。
HAL_GPIO_10
GPIO引脚10。
HAL_GPIO_11
GPIO引脚11。
HAL_GPIO_12
GPIO引脚12。
HAL_GPIO_13
GPIO引脚13。
HAL_GPIO_14
GPIO引脚14。
HAL_GPIO_15
GPIO引脚15。
HAL_GPIO_16
GPIO引脚16。
HAL_GPIO_17
GPIO引脚17。
HAL_GPIO_18
GPIO引脚18。
HAL_GPIO_19
GPIO引脚19。
HAL_GPIO_20
GPIO引脚20。
HAL_GPIO_21
GPIO引脚21。
HAL_GPIO_22
GPIO引脚22。
HAL_GPIO_23
GPIO引脚23。
HAL_GPIO_24
GPIO引脚24。
HAL_GPIO_25
GPIO引脚25。
HAL_GPIO_26
GPIO引脚26。
HAL_GPIO_27
GPIO引脚27。
HAL_GPIO_28
GPIO引脚28。
HAL_GPIO_29
GPIO引脚29。
HAL_GPIO_30
GPIO引脚30。
HAL_GPIO_31
GPIO引脚31。
HAL_GPIO_MAX
GPIO引脚的总数(无效的GPIO引脚号)。
◆ hal_gpio_status_t
枚举器
GPIO功能冲突检查失败。
GPIO功能执行失败。
输入引脚号无效。
输入参数无效。
HAL_GPIO_STATUS_OK
GPIO功能成功执行。
◆ hal_pinmux_status_t
枚举器
pinmux函数无法进行冲突检查。
pinmux功能无法执行。
输入引脚端口无效。
输入功能无效。
pinmux功能已成功执行。
文章来源: xintiaobao.blog.csdn.net,作者:心跳包,版权归原作者所有,如需转载,请联系作者。
原文链接:xintiaobao.blog.csdn.net/article/details/106653520
