CentOS 6 yum安装软件报错 YumRepo Error
【摘要】 CentOS 6 yum安装软件报错 YumRepo Error解决方案。
很多小伙伴可能发现了,以前在CentOS 6
的机器上使用yum
安装软件还是正常的,可是最近却无法使用了。一般都会报下面这样的错误:
[root@665daec6fea1 ~]# yum install apr
Loaded plugins: fastestmirror, ovl
Setting up Install Process
Loading mirror speeds from cached hostfile
YumRepo Error: All mirror URLs are not using ftp, http[s] or file.
Eg. Invalid release/repo/arch combination/
removing mirrorlist with no valid mirrors: /var/cache/yum/x86_64/6/base/mirrorlist.txt
Error: Cannot find a valid baseurl for repo: base
使用yum update
命令也是一样:
[master0@master0-server ~]$ sudo yum update
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for master0:
Loaded plugins: fastestmirror, security
Setting up Update Process
看错误提示,似乎是说找不到有效的baseurl
。所以要解决这个问题,还要从baseurl
着手。
从官方邮件可知,CentOS 6
自从2020年11月30日开始,官方不再维护,所以连带着原来的yum
存储库也不能用了。
但是邮件里说得很明白,它给出了迁移后的存储库的链接地址,这时候我们只需要更新yum
存储库的镜像列表,就可以正常使用了。
步骤如下:
进入到/etc/yum.repos.d
目录下:
cd /etc/yum.repos.d
备份原来的CentOS-Base.repo文件:
cp CentOS-Base.repo CentOS-Base.repo.old
修改CentOS-Base.repo文件:
vi CentOS-Base.repo
主要修改内容如下:
[base]
name=CentOS-$releasever - Base
# mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=os&infra=$infra
# baseurl=http://mirror.centos.org/centos/$releasever/os/$basearch/
baseurl=https://vault.centos.org/6.10/os/$basearch/
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-6
# released updates
[updates]
name=CentOS-$releasever - Updates
# mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=updates&infra=$infra
# baseurl=http://mirror.centos.org/centos/$releasever/updates/$basearch/
baseurl=https://vault.centos.org/6.10/updates/$basearch/
gpgcheck=1
# additional packages that may be useful
[extras]
name=CentOS-$releasever - Extras
# mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=extras&infra=$infra
# baseurl=http://mirror.centos.org/centos/$releasever/extras/$basearch/
baseurl=https://vault.centos.org/6.10/extras/$basearch/
gpgcheck=1
清理yum
缓存
yum clean all
执行 yum update
yum update
再次安装成功:
Resolving Dependencies
--> Running transaction check
---> Package apr.x86_64 0:1.3.9-5.el6_9.1 will be installed
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Installing:
apr x86_64 1.3.9-5.el6_9.1 base 124 k
Transaction Summary
Install 1 Package(s)
Total download size: 124 k
Installed size: 296 k
Is this ok [y/N]: y
Downloading Packages:
apr-1.3.9-5.el6_9.1.x86_64.rpm | 124 kB 00:00
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Installing : apr-1.3.9-5.el6_9.1.x86_64 1/1
/sbin/ldconfig: /usr/lib/libcriterion.so.3 is not a symbolic link
/sbin/ldconfig: /usr/lib64/libcriterion.so.3 is not a symbolic link
Verifying : apr-1.3.9-5.el6_9.1.x86_64 1/1
Installed:
Complete!
问题成功解决。
【版权声明】本文为华为云社区用户原创内容,转载时必须标注文章的来源(华为云社区)、文章链接、文章作者等基本信息, 否则作者和本社区有权追究责任。如果您发现本社区中有涉嫌抄袭的内容,欢迎发送邮件进行举报,并提供相关证据,一经查实,本社区将立刻删除涉嫌侵权内容,举报邮箱:
cloudbbs@huaweicloud.com
