哈希表---C语言实现
CodeAllen 发表于 2021/10/29 23:11:42 2021/10/29
【摘要】 哈希的基本理解---按照某种函数存储地址   冲突问题: #include <stdio.h> #include <string.h> #include <stdlib.h> #include <stdbool.h> #define SIZE 20 struct ...
冲突问题:
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#define SIZE 20
struct DataItem {  //键值
   int data;
   int key;
struct DataItem* hashArray[SIZE];
struct DataItem* dummyItem;
struct DataItem* item;
int hashCode(int key) {
   return key % SIZE;
struct DataItem *search(int key){
   //get the hash
   int hashIndex = hashCode(key);  //key%SIZE
   //move in array until an empty
   while(hashArray[hashIndex] != NULL){
      if(hashArray[hashIndex]->key == key)
         return hashArray[hashIndex];
      //go to next cell
      ++hashIndex;
      //wrap around the table
      hashIndex %= SIZE;
   return NULL;
void insert(int key,int data){
   struct DataItem *item = (struct DataItem*) malloc(sizeof(struct DataItem));
   item->data = data;
   item->key = key;
   //get the hash
   //move in array until an empty or deleted cell
   while(hashArray[hashIndex] != NULL && hashArray[hashIndex]->key != -1){
      //go to next cell
      ++hashIndex;
      hashIndex %= SIZE;
   hashArray[hashIndex] = item;
struct DataItem* delete(struct DataItem* item){
   int key = item->key;
   //get the hash
      if(hashArray[hashIndex]->key == key){
         struct DataItem* temp = hashArray[hashIndex];
         //assign a dummy item at deleted position
         hashArray[hashIndex] = dummyItem;
         return temp;
      //go to next cell
      ++hashIndex;
      hashIndex %= SIZE;
   return NULL;
// 显示所示数据项
void display(){
   int i = 0;
   for(i = 0; i<SIZE; i++) {
      if(hashArray[i] != NULL)
         printf(" (%d,%d)",hashArray[i]->key,hashArray[i]->data);
      else
         printf(" ~~ ");
   printf("\n");
int main(){
   dummyItem = (struct DataItem*) malloc(sizeof(struct DataItem));
   dummyItem->data = -1;
   dummyItem->key = -1;
   insert(1, 20);
   insert(2, 70);
   insert(42, 80);
   insert(4, 25);
   insert(12, 44);
   insert(14, 32);
   insert(17, 11);
   insert(13, 78);
   insert(37, 97);
   display();
   item = search(37);
   if(item != NULL){
      printf("Element found: %d\n", item->data);
   }else{
      printf("Element not found\n");
   delete(item);
   item = search(37);
   if(item != NULL){
   }else{
文章来源: allen5g.blog.csdn.net,作者:CodeAllen的博客,版权归原作者所有,如需转载,请联系作者。
原文链接:allen5g.blog.csdn.net/article/details/82356679
