97 Things Every Programmer Should Know(每个程序员都应该知道的97件事)
CodeAllen 发表于 2021/10/30 00:49:59 2021/10/30
【摘要】 97 Things Every Programmer Should Know(每个程序员都应该知道的97件事) 作者 CodeAllen ,转载请注明出处 Act with Prude...
  1. Act with Prudence
  2. Apply Functional Programming Principles
  3. Ask, “What Would the User Do?” (You Are Not the User)
  4. Automate Your Coding Standard
  5. Beauty Is in Simplicity
  6. Before You Refactor
  7. Beware the Share
  8. Check Your Code First Before Looking to Blame Others
  9. Choose Your Tools with Care
  10. Code in the Language of the Domain
  11. Code Is Design
  12. Code Layout Matters
  13. Code Reviews
  14. Coding with Reason
  15. A Comment on Comments
  16. Comment Only What the Code Cannot Say
  17. Continuous Learning
  18. Convenience Is Not an -ility
  19. Deploy Early and Often
  20. Distinguish Business Exceptions from Technical
  21. Do Lots of Deliberate Practice
  22. Domain-Specific Languages
  23. Don’t Be Afraid to Break Things
  24. Don’t Be Cute with Your Test Data
  25. Don’t Ignore That Error!
  26. Don’t Just Learn the Language, Understand Its Culture
  27. Don’t Nail Your Program into the Upright Position
  28. Don’t Rely on “Magic Happens Here”
  29. Don’t Repeat Yourself
  30. Don’t Touch That Code!
  31. Encapsulate Behavior, Not Just State
  32. Floating-Point Numbers Aren’t Real
  33. Fulfill Your Ambitions with Open Source
  34. The Golden Rule of API Design
  35. The Guru Myth
  36. Hard Work Does Not Pay Off
  37. How to Use a Bug Tracker
  38. Improve Code by Removing It
  39. Install Me
  40. Interprocess Communication Affects Application Response Time
  41. Keep the Build Clean
  42. Know How to Use Command-Line Tools
  43. Know Well More Than Two Programming Languages
  44. Know Your IDE
  45. Know Your Limits
  46. Know Your Next Commit
  47. Large, Interconnected Data Belongs to a Database
  48. Learn Foreign Languages
  49. Learn to Estimate
  50. Learn to Say, “Hello, World”
  51. Let Your Project Speak for Itself
  52. The Linker Is Not a Magical Program
  53. The Longevity of Interim Solutions
  54. Make Interfaces Easy to Use Correctly and Hard to Use Incorrectly
  55. Make the Invisible More Visible
  56. Message Passing Leads to Better Scalability in Parallel Systems
  57. A Message to the Future
  58. Missing Opportunities for Polymorphism
  59. News of the Weird: Testers Are Your Friends
  60. One Binary
  61. Only the Code Tells the Truth
  62. Own (and Refactor) the Build
  63. Pair Program and Feel the Flow
  64. Prefer Domain-Specific Types to Primitive Types
  65. Prevent Errors
  66. The Professional Programmer
  67. Put Everything Under Version Control
  68. Put the Mouse Down and Step Away from the Keyboard
  69. Read Code
  70. Read the Humanities
  71. Reinvent the Wheel Often
  72. Resist the Temptation of the Singleton Pattern
  73. The Road to Performance Is Littered with Dirty Code Bombs
  74. Simplicity Comes from Reduction
  75. The Single Responsibility Principle
  76. Start from Yes
  77. Step Back and Automate, Automate, Automate
  78. Take Advantage of Code Analysis Tools
  79. Test for Required Behavior, Not Incidental Behavior
  80. Test Precisely and Concretely
  81. Test While You Sleep (and over Weekends)
  82. Testing Is the Engineering Rigor of Software Development
  83. Thinking in States
  84. Two Heads Are Often Better Than One
  85. Two Wrongs Can Make a Right (and Are Difficult to Fix)
  86. Ubuntu Coding for Your Friends
  87. The Unix Tools Are Your Friends
  88. Use the Right Algorithm and Data Structure
  89. Verbose Logging Will Disturb Your Sleep
  90. WET Dilutes Performance Bottlenecks
  91. When Programmers and Testers Collaborate
  92. Write Code As If You Had to Support It for the Rest of Your Life
  93. Write Small Functions Using Examples
  94. Write Tests for People
  95. You Gotta Care About the Code
  96. Your Customers Do Not Mean What They Say
文章来源: allen5g.blog.csdn.net,作者:CodeAllen的博客,版权归原作者所有,如需转载,请联系作者。
原文链接:allen5g.blog.csdn.net/article/details/99064798
