Windows配置gitee
CodeAllen 发表于 2021/10/30 00:12:41 2021/10/30
【摘要】 安装git 下载之后一路next就可以 官网: https://git-scm.com/downloads 生成公钥 ssh-keygen -t rsa -C "allen5g@qq.com" 查看生成公钥 cat /c/Users/Administrator/.ssh/id_rsa.pub 复制打印出来的公...
安装git
下载之后一路next就可以
生成公钥
查看生成公钥
复制打印出来的公钥
注册gitee
登录网址,按照知识填信息一步步就好了,不多赘述。官网: Gitee(gitee.com)
配置公钥
先进入设置,在主页头像下,或者右上角
 输入公钥
到这步已经完成了配置,下边可以拿之前的一个项目试试(右上角新创建一个也行)
 复制clone网址
 测试
git clone git@gitee.com:Allen5g/linux-c-cpp-collection.git
clone成功,本地多了项目文件
测试修改提交
可以本地尝试修改文件,然后按照git流程提交修改
  1. $ git status
  2. On branch master
  3. Your branch is up to date with 'origin/master'.
  4. Changes not staged for commit:
  5. (use "git add <file>..." to update what will be committed)
  6. (use "git restore <file>..." to discard changes in working directory)
  7. modified: README.md
  8. no changes added to commit (use "git add" and/or "git commit -a")
  9. Administrator@Allen-Windows MINGW64 /d/000-Workspace/linux-c-cpp-collection (master)
  10. $ git add README.md
  11. Administrator@Allen-Windows MINGW64 /d/000-Workspace/linux-c-cpp-collection (master)
  12. $ git commit
  13. [master ff701bf] modify readme txt
  14. 1 file changed, 1 insertion(+)
  15. Administrator@Allen-Windows MINGW64 /d/000-Workspace/linux-c-cpp-collection (master)
  16. $ git push -u origin master
  17. Enumerating objects: 5, done.
  18. Counting objects: 100% (5/5), done.
  19. Delta compression using up to 8 threads
  20. Compressing objects: 100% (3/3), done.
  21. Writing objects: 100% (3/3), 284 bytes | 284.00 KiB/s, done.
  22. Total 3 (delta 2), reused 0 (delta 0), pack-reused 0
  23. remote: Powered by GITEE.COM [GNK-6.0]
  24. To gitee.com:Allen5g/linux-c-cpp-collection.git
  25. 89483ed..ff701bf master -> master
  26. Branch 'master' set up to track remote branch 'master' from 'origin'.
成功结束
文章来源: allen5g.blog.csdn.net,作者:CodeAllen的博客,版权归原作者所有,如需转载,请联系作者。
原文链接:allen5g.blog.csdn.net/article/details/119842636
