Java+Swing实现通讯录管理系统
水坚石青 发表于 2021/10/30 01:01:32 2021/10/30
【摘要】 Java+Swing实现通讯录管理系统 一、系统介绍1.系统功能2.环境配置3.数据库4.工程截图 二、系统展示1.登录页2.主页3.查询信息4.新增信息5.修改信息 三、部分代码DBCo...
一、系统介绍
1.系统功能
1.登录系统
2.查询信息
3.新增信息
4.修改信息
5.删除信息
2.环境配置
JDK版本:1.8
Mysql:8.0.13
3.数据库
 Navicat Premium Data Transfer
 Source Server         : MySQL
 Source Server Type    : MySQL
 Source Server Version : 80013
 Source Host           : localhost:3306
 Source Schema         : swing_address
 Target Server Type    : MySQL
 Target Server Version : 80013
 File Encoding         : 65001
 Date: 10/06/2021 23:56:16
SET NAMES utf8mb4;
SET FOREIGN_KEY_CHECKS = 0;
-- Table structure for my_address_book
DROP TABLE IF EXISTS `my_address_book`;
CREATE TABLE `my_address_book`  (
  `id` int(11) NOT NULL AUTO_INCREMENT,
  `name` varchar(255) CHARACTER SET utf8 COLLATE utf8_bin NULL DEFAULT NULL,
  `sex` varchar(255) CHARACTER SET utf8 COLLATE utf8_bin NULL DEFAULT NULL,
  `telephone` varchar(255) CHARACTER SET utf8 COLLATE utf8_bin NULL DEFAULT NULL,
  `mail` varchar(255) CHARACTER SET utf8 COLLATE utf8_bin NULL DEFAULT NULL,
  `birthday` varchar(255) CHARACTER SET utf8 COLLATE utf8_bin NULL DEFAULT NULL,
  `note` varchar(255) CHARACTER SET utf8 COLLATE utf8_bin NULL DEFAULT NULL,
  PRIMARY KEY (`id`) USING BTREE
) ENGINE = InnoDB AUTO_INCREMENT = 5 CHARACTER SET = utf8 COLLATE = utf8_bin ROW_FORMAT = Compact;
-- Records of my_address_book
INSERT INTO `my_address_book` VALUES (2, '杨XX', '男', '18911616917', '1@163.com', '20200107', 'XX');
INSERT INTO `my_address_book` VALUES (3, '222', '女', '22', '22', '22', '22');
INSERT INTO `my_address_book` VALUES (4, '1', '女', '1', '1', '1', '1');
-- Table structure for my_address_login
DROP TABLE IF EXISTS `my_address_login`;
CREATE TABLE `my_address_login`  (
  `username` varchar(255) CHARACTER SET utf8 COLLATE utf8_bin NULL DEFAULT NULL,
  `password` varchar(255) CHARACTER SET utf8 COLLATE utf8_bin NULL DEFAULT NULL,
) ENGINE = InnoDB AUTO_INCREMENT = 2 CHARACTER SET = utf8 COLLATE = utf8_bin ROW_FORMAT = Compact;
-- Records of my_address_login
INSERT INTO `my_address_login` VALUES (1, '1', '1');
SET FOREIGN_KEY_CHECKS = 1;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
4.工程截图
二、系统展示
1.登录页
2.主页
3.查询信息
4.新增信息
5.修改信息
三、部分代码
DBConn.java
package com.txl;
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.ResultSet;
import java.sql.SQLException;
import java.sql.Statement;
public class DBConn {
	private static String driverName = "com.mysql.cj.jdbc.Driver";
	private static String url = "jdbc:mysql://localhost:3306/swing_address?serverTimezone=UTC";
	private static String userName = "root";
	private static String password = "admin";
	private Connection conn;
	private Statement stmt;
	public DBConn() {
		try {
			Class.forName(driverName);
		} catch (ClassNotFoundException e) {
			e.printStackTrace();
	 * 连接数据库
	 * @return
	 * @throws SQLException
	public Connection getConnection() throws SQLException {
		return DriverManager.getConnection(url, userName, password);
	 * 释放资源
	public void dispose() {
		try {
			if (conn != null) {
				conn.close();
			if (stmt != null) {
				stmt.close();
		} catch (SQLException e) {
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
Login.java
package com.txl;
import java.awt.FlowLayout;
import java.awt.event.MouseAdapter;
import java.awt.event.MouseEvent;
import java.util.Vector;
import javax.swing.JLabel;
import javax.swing.JOptionPane;
import javax.swing.JTextField;
import javax.swing.JPasswordField;
public class Login {
	public static void main(String args[]) {
		Login l=new Login();
		l.showUI();
	public void showUI() {
		javax.swing.JFrame login=new javax.swing.JFrame();
		login.setTitle("登录通讯录");
		login.setSize(340,230);
		login.setDefaultCloseOperation(3);
		login.setLocationRelativeTo(null);
		login.setResizable(false);
		java.awt.FlowLayout fl=new java.awt.FlowLayout(FlowLayout.CENTER,5,5);
		login.setLayout(fl);
		JLabel labname=new JLabel();
		labname.setText("用户名:");
		labname.setPreferredSize(new java.awt.Dimension(60, 60));
		login.add(labname);
		JTextField textname=new JTextField();
		textname.setPreferredSize(new java.awt.Dimension(250, 30));
		login.add(textname);
		JLabel labpassword=new JLabel();
		labpassword.setText("密     码:");
		labpassword.setPreferredSize(new java.awt.Dimension(60, 60));
		login.add(labpassword);
		JPasswordField jp=new JPasswordField();
		jp.setPreferredSize(new java.awt.Dimension(250, 30));
		login.add(jp);
		javax.swing.JButton button=new javax.swing.JButton();
		button.setText("登录");
		button.setPreferredSize(new java.awt.Dimension(100, 40));
		login.add(button);
		login.setVisible(true);
		button.addMouseListener(new MouseAdapter() {
			public void mouseClicked(MouseEvent e) {
				DBConn dbconn = new DBConn();
				Statement stmt = null;
				ResultSet rs = null;
				try {
					stmt = dbconn.getConnection().createStatement();
					rs = stmt.executeQuery("select * from my_address_login where username='"+textname.getText()+"' and password='"+jp.getText()+"'");
					if (rs.next()) {
						new MyAddressBook();
						login.dispose();
					}else{
						JOptionPane.showMessageDialog(null, "用户名或密码不正确!!!");
					rs.close();
				} catch (SQLException e1) {
					e1.printStackTrace();
				} finally {
					try {
						if (stmt != null) {
							stmt.close();
						if (rs != null) {
							rs.close();
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
Test.java
package com.txl;
import java.sql.PreparedStatement;
import javax.swing.table.DefaultTableModel;
import javax.swing.table.TableColumn;
public class Test {
		DBConn dbconn = new DBConn();;;;;
		try {
			for(int i =0 ;i<1000000;i++){
				String sql = "insert into student(name, age)values('XXX"+i+"',30)";
				PreparedStatement pstmt = dbconn.getConnection().prepareStatement(sql);
				System.out.println(sql);
				pstmt.execute(sql);
				pstmt.close();
			// TODO Auto-generated catch block
		} finally {
  • 26
  • 27
  • 28
四、其他
1.其他系统实现
JavaWeb系统系列实现
Java+JSP实现学生图书管理系统
Java+JSP实现学生信息管理系统
Java+JSP实现用户信息管理系统
Java+Servlet+JSP实现航空订票系统
Java+Servlet+JSP实现学生选课管理系统
Java+Servlet+JSP实现学生成绩管理系统
Java+Servlet+JSP实现宠物诊所管理系统
Java+SSM+Easyui实现网上考试系统
Java+Springboot+H-ui实现营销管理系统
Java+Springboot+Mybatis+Bootstrap实现网上商城系统
JavaSwing系统系列实现
Java+Swing实现斗地主游戏
Java+Swing实现图书管理系统
Java+Swing实现医院管理系统
Java+Swing实现仓库管理系统
Java+Swing实现考试管理系统
Java+Swing实现通讯录管理系统
Java+Swing实现停车场管理系统
Java+Swing实现学生信息管理系统
Java+Swing实现学生宿舍管理系统
Java+Swing实现学生选课管理系统
Java+Swing实现学生成绩管理系统
Java+Swing实现学校教材管理系统
Java+Swing实现学校教务管理系统
Java+Swing实现企业人事管理系统
Java+Swing实现电子相册管理系统
Java+Swing实现自助取款机(ATM)系统
Java+Swing实现超市管理系统-TXT存储信息
Java+Swing实现宠物商店管理系统-TXT存储信息
2.获取源码
点击以下链接获取源码,数据库文件在sql文件下面。
Java+Swing+Mysql实现通讯录管理系统源码
3.备注
如有侵权请联系我删除。
4.鸡汤
我们的目的是清晰的,我们的道路是光明的!
文章来源: blog.csdn.net,作者:水坚石青,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/helongqiang/article/details/117793756
